Old 02-14-2013, 03:14 PM   #1
LonB
Default Newbie GWS Slow Stick Build
I'm building a 46" brushless Slow Stick (SS) from an NPS kit. This is what I have so far:
(See update on new items below.)
The instructions and specs in the GWS SS kit are not so good... perhaps "Lost in translation." And unfortunately the motor and ESC didn't come with any specs as well, which seems to be the case with Chinese stuff.
Thanks for any help!
LonB is offline
Old 02-15-2013, 03:09 AM   #2
hayofstacks
hayofstacks's Avatar
One nice thing about the slow stick, it flies well with just about any setup. I think the only part of the instructions I used was the cg.
I fly with a 2200 3 cell, and slid my servo tray all the way to the back of the plane againstthe tail so I could leave the battery up front against the wing between the motor. 300w is a lot of power, and a 8" prop is not very much on a 3 cell with 1000kv. I would probably try a 9X5 or 9X6 first and see how I liked it.
hayofstacks is offline
Old 02-15-2013, 03:57 AM   #3
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
You're going to get 10 more answers.
fly
flydiver is offline
Old 02-15-2013, 05:57 AM   #4
View mclarkson's Gallery26
Friends: (8)
I run a slightly smaller (well, okay, much smaller) 800kV motor on mine with a 1300mAh 3S battery.
That setup should work fine with either battery. As noted, you'll have to adjust battery placement to get the correct CG. With a 2-cell, I'd imagine you'll want a ginormous prop.
Old 02-17-2013, 08:24 PM   #5
LonB
Here's what I have so far:
- Eflite Park 400 920Kv Brushless Outrunner Motor (EFLM1305)
- Eflite 20A Brushless ESC (V2) (EFLA311B)
- Eflite Prop Saver (EFLM1914)
- Spektrum AR400
- Spektrum A3030 8.6g 23oz Torque Servos
- 2S 7.4V 1300mAh 20C Batteries
Still working on the best prop size. The motor specs out "9x7 to 11x4.7" but I'm leaning toward 9x6 or 9x7 slow fly.
In the future I would like to add ailerons and further reinforce the wing.
LonB is offline
Old 02-17-2013, 08:59 PM   #6
touche
A guy in our park in Florida build planes for people. Just built a slow stick for a guy here with 2 ducted fan jets attached to the wings, tricycle gear etc. He took some pics to go on the Radical RC site eventually. The club I joined here use slow sticks in the winter to horse around with. One has a ducted fan jet underslung between the landing gear. I've never seen a wing flex so much and not snap.
Another altered his to do 3d flying. the entire rudder swivels on a center point on a shortened fuse. He can sure make that plane do some amazing things. Ive seen them with the wing tips cut off. more dihederal etc and some just plain old slow sticks lolling about.
The thing with the slow stick is it is very adaptable to mods. These fellas are all very good flyers and have modded the c##p out of theirs.
A fun plane to fly and learn on.
touche is offline
Old 02-17-2013, 09:39 PM   #7
hangingon
hangingon's Avatar
Club: no clubs
Friends: (4)
I use 3s 1300mah 25-35c turnigy's from hobby king and they work great with plenty of flight time I have a 950kv gws brushless motor. My 2200 3cell adds a lot of weight to the plane. I get around 30+ mins. flights from the 1300s. Try what you got on hand and see what you like best. I would run a bigger prop than the 8x4.7
hangingon is offline
Old 02-18-2013, 01:08 AM   #8
hayofstacks
I have run 9gsub micro servo's on mine. Your servo's sound a bit big, but everything else should work fine.
Old 02-18-2013, 01:21 AM   #9
LonB
The Spektrum A3030 8.6g Sub-Micro Digital High Torque Servos are the same size as my 7.5g Spektrum servos but are made for larger slow and park flyers.
http://www.spektrumrc.com/Products/D...odID=SPMSA3030
LonB is offline
Old 02-18-2013, 02:25 AM   #10
LonB
9x7 or 10x4.7? Perhaps I'll get a couple of each.. what do think the difference would be?
LonB is offline
Old 02-18-2013, 02:46 AM   #11
hangingon
hangingon's Avatar
Club: no clubs
Friends: (4)
Default slow stick build
The slow stick doesn't need high torque or high speed servos this is an easy laid back and relaxed flyer to enjoy. I order mine from heads up with gws brushless motor included it's only 950kv and more than enough for the slow stick I was using 2s 900mah 25c batteries to fly it when I first got it. It's setup with 2 9g servos, 950kv, 30amp hobbywing esc, orange rx dsm receiver & the turnigy 3s 1300mah 25c batteries. The high torque servos might be over kill for the plane. and once it's built make sure when you give elev input that the elev. flap doesn't hit your tail rudder if so you will need to trim it with the tx.
Old 02-18-2013, 03:01 AM   #12
hangingon
hangingon's Avatar
Club: no clubs
Friends: (4)
part gws 1060 prop which is 10x6 should work. check out (heads up rc) that is the prop that comes in the ss/brushless kit. Did you not have a prop in your kit? Or are you wanting something besides the stock prop. With the 920kv the stock 10x6 will work fine. If you get new batteries later on for it go up to a 25c discharge it will give you a little more punch.
Old 02-18-2013, 02:49 PM   #13
LonB
What size prop did you run with this combo?
LonB is offline
Old 02-18-2013, 04:54 PM   #14
stevecooper
stevecooper's Avatar
View stevecooper's Gallery86
Club: Mullet Mauroders
Friends: (89)
It doesn't matter what you do to a SS they'll still be Great planes to have fun!bubsteve
ID:	166358   Click image for larger version
ID:	166359   Click image for larger version
ID:	166360   Click image for larger version
ID:	166361   Click image for larger version
Monkey Minion'air
stevecooper is offline
Old 02-18-2013, 06:25 PM   #15
LonB
Awesome!
Is that a GWS Tiger Moth? I like the looks of it but have read nothing but bad reviews on them.
LonB is offline
Old 02-18-2013, 11:56 PM   #16
hangingon
hangingon's Avatar
Club: no clubs
Friends: (4)
I run the 10x6 prop you can go very slow or hit the throttle and pull off a few loops. Most of my flying is at 1/2 throttle. It don't take much to keep the ss in the air it has a good glide ability which is the main reason for the longer flight times.
Old 02-19-2013, 07:39 AM   #17
stevecooper
Friends: (89)
Originally Posted by LonB View Post
Awesome!
It's the big GWS one, fly's great, had it for 5 years and love'in it, bubsteve
Name:	petty an red 424.jpg
ID:	166373   Click image for larger version
ID:	166374   Click image for larger version
Monkey Minion'air
Old 02-19-2013, 07:49 AM   #18
Friends: (8)
Awesome!
WHAT?!!!! Unpossible! The GWS Tiger Moth 400 is an awesome plane!
slow stick build thread and mods hayofstacks ParkFlyers 24 01-27-2014 07:10 AM
New Guy, Asking for help! propduster8 General Electric Discussions 21 12-13-2012 01:42 PM
Modified GWS Slow Stick, My latest build... svo ParkFlyers 11 03-25-2012 12:21 AM
my mini ultra stick escapades hayofstacks Crash and Safety Forum 0 03-05-2012 12:07 AM
$100 Scratch build: Micro Slow Stick Simon Scratch and Kit Built Aircraft 11 05-11-2011 12:38 AM
Page generated in 0.83860 seconds with 63 queries
