Old 02-25-2013, 05:41 PM   #1
chestnutree
Default Dynam RC & Receiver binding issues
Hi everyone,
I'm a complete newby here. I have my very first RC plane which i tried to put together a year ago, gave up and now here i am for another attempt.
I have a Dynam Extra 330. It comes with a Dynam 7 channel receiver and a Dynam 4ch 2.4Ghz RC. I cannot for the life of me seem to sync (bind) the RC to the receiver. I have followed the instructions that came with it.... these are translated badly and look complicated. I've also followed videos on youtube which look simple but still no luck.
The safety switch on the RC is down, the throttle is down. I turn on the RC and then quickly plug the battery into the plane. The red LED inside the receiver flashes and i get some beeps. Straight away the plane sounds 2 beeps every second. On the videos i have watched, the planes first produce 3 ascending beeps but mine doesn't. It does 2 quick beeps every second or 2 and the red LED inside the receiver flashes away. The RC eventually stops flashing but the plane continues and nothing happens.
The only other thing that does happen, is sometimes the servos move. If i plug in the battery to the receiver/plane WITHOUT turning on the RC/Transmitter.... the servos never move. When i follow the correct process for binding, the servos often move which suggests that some sort of communication is going on between the 2? But the beeping doesnt stop, the light on the receiver doesn't stop and none of the controls work.
Please any suggestions would be greatly received
Thanks,
Nick
chestnutree is offline
Old 02-25-2013, 06:52 PM   #2
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
The bad news is.....you can't get it flying.
The good news is.....the same.
I have that plane, but not the electronics. I replaced them all. The originals were not worth keeping.
That said as a new flier you don't have a prayer of keeping that plane in one piece. It's a decent flying plane, but it's a fast advanced performer. If you are quite talented and spend a goodly amount of time with a more suitable trainer this 'might' be a decent 2nd plane. It's probably better as a 3rd plane.
If you do get this one going and give it a try all you'll get for your efforts is foam rubble and discouragement.
Be glad you haven't got it going yet. Get a Champ, Super Cub, Bixler, even the Dynam Hawksky, etc. and learn flying basics first. Choose a plane with a BIG thread and a LOT of support, AND parts. Notice there is just about nothing on this plane at all. That alone tells you something about popularity.
Down the road consider the Dynam....maybe.
fly
flydiver is offline
Old 03-14-2013, 12:01 PM   #3
sid809
To fly RC plane you need much practice other wise same thing happens and you will crush you RC plane. First you have to buy some small RC plane and have practice on it then go for the new one..
sid809 is offline
Old 03-14-2013, 12:51 PM   #4
DCDetector
DCDetector's Avatar
View DCDetector's Gallery25
On several of my Dynam's I had to not only make sure the throttle stick was all the way down, but that the trim was also all the way down before it would bind.
DCDetector is offline
Old 03-14-2013, 04:36 PM   #5
I've only got the 5 ch that comes with the 1200 mm 5 ch P-51
I'm finding that the Dynam 2.4 ghz has to rebind EVERY time you turn on.
Power up the plane. RX blinks rapidly (TX on or off) There is no bind plug. There is no bind button on the TX.
So you have to power up the RX, wait a few seconds.
Then power up the TX and wait for it to go through bind.
Every flight.
Its not a good binding system.
note the beep codes are from the ESC and have nothing to do with binding.
the beep codes described are for the ESC NOT detecting low throttle on power-up. (rebind with low throttle)
Old 03-15-2013, 12:04 AM   #6
Club: AMA, Marks, Pomona Valley, Prado Dam
chestnutree....
I had a simular issue awhile back with a (Dynam 4ch TX/6ch RX) for a J3 Piper Cub....I believe it's the same TX/RX combo you have.
I found this at the rcdiscuss forum........it worked for me and I still have the TX/RX.......use it occasionally on a Slow Stick.....Have had no binding issues since.
(I would not recommend using it on anything you really value....the older Dynam 2.4ghz TX/RX combo's have a history of range and signal swapping issues. The ones that had the seperate manual binding switch on the TX face are more reliable).
Problem from the forum:
"I have a Dynam 4 channel 2.4 ghz transmitter. I am going to have to read the directions unless someone can give me the answer before I have to give in and read! LOL Anyway I bind it by turning on the TX and then turning on the RX and it beeps and pauses then beeps 3 times and then maybe beeps once more I don't remember now but when I get it to bind it operated all the servos but the only time I ever get the motor to run it runs full throttle and I can't slow it down. I have tried the motor kill switch in both positions on bind, I have put throttle on full on bind, just a lot of different things but I am missing something I guess on binding. I have 2 receivers and I have both receivers and both do the same. Does anyone on here know what I am missing?"
Solution from the forum:
"A. Put your throttle switch in the bank of reverse/normal switches in the up or off position as Dynam labels them
B. Put Throttle kill switch in down position.
C. Put Throttle to high.
D. Turn on TX and while TX bind lights are flashing plug in ESC.
E. You will her 3 note musical tone and then 3 short beeps and one long (if you are a ham radio operator and know code it is a V).
F. Next put throttle stick and it’s lowest point.
G. Flip the throttle kill switch up and then back down.
H. At that time the throttle maximum and minimum set points will be set in the ESC."
Hope this works for you!
AMA 928214
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 146 05-07-2013 03:24 PM
How to set up Dynam AirField RC 55" Sky Trainer Lompma Beginners 4 09-23-2011 12:52 PM
LiFe vs Nih Receiver battery tests kyleservicetech RC Radios, Transmitters, Receivers, Servos, gyros 23 07-08-2011 02:40 AM
Plug N Fly zzlentz Beginners 15 04-07-2011 02:34 AM
New Dynam Hawksky BL for Clearview, FMS and RC Desk Pilot ggunners Flight Simulators 1 12-30-2010 01:51 AM
Page generated in 0.20122 seconds with 29 queries
