Old 02-25-2013, 06:57 PM   #1
bobby
bobby's Avatar
Club: Largo flying club FL.
Default pusher prop
Can I use a standard prop by turning it around for a pusher plane?
bobby is offline
Old 02-25-2013, 07:04 PM   #2
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
Yes....but you don't turn it 'backwards'. Props FACE the direction they are going.
Tractor > faces forward pulling
Pusher > faces forward pushing.
So called 'pusher props' would be better called 'reverse rotation' props primarily useful for multi-engine planes to use to run opposite directions to reduce prop torque. They still face the direction of travel just turn the opposite way.
fly
flydiver is offline
Old 02-25-2013, 07:08 PM   #3
Yep, for brushless electric there really is no need to use pusher props. You just reverse the direction of rotation of the motor and mount the prop exactly the same way as usual (i.e. the 'front' of the blade still points forward).
Pushers are required for i.c. engines that will only run properly in one direction.
Old 02-25-2013, 07:35 PM   #4
bobby
bobby's Avatar
Thanks everybody.
bobby is offline
Motor and prop for HK BD-5 pusher? Davethebluessinger Pusher Park Jets 6 01-26-2013 05:01 PM
Dunam HAwk sky glider with grayson v2 pusher upgrade Prop problems Alabama Flying Dude Pusher Park Jets 3 05-19-2012 04:13 PM
Setting up a PUSHER prop npowell28 Beginners 3 05-12-2012 09:16 AM
3mm prop adapter impossible? Prop saver issue? mclarkson General Electric Discussions 12 11-26-2011 10:09 PM
Page generated in 0.07974 seconds with 26 queries
