Old 03-01-2013, 05:01 AM   #1
dongshan
Default Replacing cordless drill battery pack Asus A53TA batteries
Okay, so I have a cordless drill and one of the battery packs went dead and I'm attempting to replace the batteries in the pack. I've read a few forums online and found that even an amateur can do this pretty simple. However, I do have a few questions that I wasn't able to find out.
The batteries in my pack are labeled " Asus A53TA ". From what I found this is a 1.2v Ni-Cd sub-c class battery and the S means high capacity (mAh?) and quick charging. However, I can't find much about this specific battery, like how many mAh it actually has.
1. My first question is, where could I find the specs for this specific battery or what is a good mAh for a cordless drill? I've seen them up to 2500, maybe higher.
2. I found many batteries setup to make into a battery pack with the tabs already included. My other question then, is can I just solder the tabs to the other battery or is there some other kind of "weld" or adhesive I should use? Maybe someone has done this already and suggests a good battery I can use? more detials : http://www.batterietutti.com/asus-a53ta.html
Thanks in advance!
dongshan is offline
Old 03-01-2013, 07:36 AM   #2
Thanks in advance!
It's a shame, you can buy a cordless drill, then buy a replacement battery for it and spend as much for the battery as the whole thing cost to begin with.
I've replaced the individual cells in the batteries for my Porter Cable cordless drill several times now. Also have rebuilt many other battery operated tools, it's not to hard if you have the proper replacement cells. Now days, you can obtain decent battery cells at reasonable cost. Check out www.voltmanbatteries.com, they sell individual 3300 Mah Nih cells for about $3.30 each, or lower capacity Nicads for a bit less. These cells come with straps that are easily soldered.
http://www.voltmanbatteries.com/serv...BATTERY/Detail
For a price, they will also rebuild your existing battery pack.
I've ordered many hundreds of dollars of A123 cells from voltmanbatteries, nice place to do business with.
Old 03-01-2013, 04:21 PM   #3
Friends: (19)
As Kyle says - easy once you have the cells ....
Personally I have 2 solutions ............ most of these are 12 - 14.4v operation ... sitting slap bang on a car battery voltage. You can remove the contacts of the battery pack so it doesn't make contact anymore. Take a reasonable 2 core flex and connect to contacts inside handle ... make a slot in battery case to allow it to click back in place. the other end of lead can have a 12v car ciggy plug attached so you can power from car .. boat ... emergency starter pack etc. (Reason I put battery back in - is balance weight ... )
Other solution is to install a battery pack of my own made from tagged cells as OP has found ... as Kyle says - these are just soldered up by the tags to make a pack ... being careful to make sure you shape / arrangement of original ...
You could of course fit a 3S - 4S LiPo in the handle .........
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 273 01-09-2017 03:23 AM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 01:56 AM
Dead Ni-Cad Cordless Drill Batteries, Revive Them CHELLIE Off Topic Chit Chat 16 01-29-2011 10:45 PM
Page generated in 0.07280 seconds with 23 queries
