Old 03-13-2013, 02:01 AM   #1
foamcruncher
foamcruncher
Default charging 1500 mah Life battery with iMax B6AC?
,Recently upgraded 8 AA tx battery pack with HK 1500 mah Life battery replacement . Trying to charge with imax B6AC dual powr.charger / balancer ,heeding warnings of mischarging ,I am confused to process to charge this Life . instruction manual not clear to me what rate / voltage / setting to charge with, charger is compatable acording to instructions , but what is proper safe charge procedure? your expertise can save a possible "smoke test" ,, Thank you for your always great help and advice > Foamchuncher
foamcruncher is offline
Old 06-10-2013, 05:09 PM   #2
Friends: (18)
I was looking at LIFE for a Glow model for Rx ... and Hobby King page for the pack gave details of settings changes for B6 charger ... as the Accucel 6 charger is basically same charger.
Here's a guy who answered on the Discussion part of a LiFePo4 page :
go to the program mode and pres enter it will now show voltage for lipo (3.7 ) press enter and it will start flashing, now press up or down to change voltage to (3.3v) press enter again now press end/stop now select battery type ( lipo /life ) and now set charge rate and cell count conferm and charge
I still haven't changed over from NiMH to LIFE but considering. TBH - my NiMh at 2300mAh provide more than a days heavy use flying on my 60 powered 4kg biplane ! With NO voltage drop-outs or problems despite the 4 standard servos and 1 micro ...
Old 06-10-2013, 06:10 PM   #3
flydiver
flydiver's Avatar
View flydiver's Gallery1
Outstanding Contributor Award
The procedure above is how to get at LiFe charge voltage setting. Finding that menu change is one of the more obscure changes for those chargers.
For rate 1C is certainly safe. I use 3C on mine without problem so far.
fly
flydiver is offline
Old 06-11-2013, 05:30 PM   #4
Friends: (18)
Without that first step as I posted ... OP is on wrong road ...
Once as I posted is done - then set the cell and amp rating to charge ...
One of the worries I have and is making me delay taking on LiFe packs - is this setting of end voltages and possibility of forgetting. I look for a dedicated LiFe charger ... that way as with other type of packs - safety is higher.
Deep Cycle Lead Acid Battery Life Span kyleservicetech Batteries & Chargers 90 03-22-2014 11:12 PM
3 cell Lipo Batteries- Bang for the Buck dahawk General Electric Discussions 30 03-11-2012 01:40 AM
Solid experience on RC Model Lipo Battery Accident & Charger Guide SimonXi Batteries & Chargers 0 08-12-2011 05:08 PM
LiFe vs Nih Receiver battery tests kyleservicetech RC Radios, Transmitters, Receivers, Servos, gyros 23 07-08-2011 02:40 AM
Page generated in 0.06511 seconds with 25 queries
