Old 04-19-2013, 08:32 AM   #1
Dragon Master
Dragon Master's Avatar
Club: No club where I live
Default Building my first foamy
Hi
I started to build my first foamy
it is 36 in long with a 60 in wing span
the wings almost look to long
here is a pick that i covered 6 in of each wing
hoping it will fly when i get it done
Dragon Master is offline
Old 04-19-2013, 10:29 AM   #2
View mclarkson's Gallery26
Friends: (8)
Those are some crazy long wings! Are you using plans, or your own design, or ...?
Old 04-19-2013, 10:34 AM   #3
View CHELLIE's Gallery13
Friends: (327)
Very Nice Use some Square CF tube in the wing for a brace and Epoxy it in place, I Like using a Slow Stick Fuselage to brace my larger wing builds, The wing Looks Great, depending on what type of flying you want to do, leave the wing as is or cut it, a long wing will give you longer flights if you like to thermal, and a shorter wing will give you some better speed, I get to do the Maiden Flight on it Take care and have fun, Chellie
here are some of my scratch builds if your interested.
http://www.wattflyer.com/forums/show...652#post715652
Old 04-19-2013, 10:45 AM   #4
Friends: (327)
Originally Posted by Dragon Master View Post
Hi
It Will Fly Great when your done with it, put the CG at 25% of the wing cord from the leading edge, Do You know what motor you are going to use, if not, Here is a motor from Heads up Rc. use a 12x6 prop on 3 cells.
give the motor a little down thrust like about 3 percent.
http://www.headsuphobby.com/Power-Up...otor-E-585.htm
http://www.wattflyer.com/forums/showthread.php?t=39483
Old 04-19-2013, 11:35 AM   #5
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
You have a nice start there!
My only concern is with the size of your fin/rudder and stab/elevator. It may just be the picture making them look a bit small. If they are not large enough you will have control problems with the model.
If you could, give us the total area of the wing - or its dimensions as well as the area of the tail feathers.
Then we can tell you if they are large enough to work well.
I think I need a signature.
Larry
Larry3215 is offline
Old 04-19-2013, 12:39 PM   #6
Club: A lone flyer!
Friends: (7)
It is perfectly possible to fly big wings with a small tail
but it will probably be very tricky to control and keep in the air.
This certainly is but it is very light so flies pretty slowly.
How much will it weigh?
Its weight will determine how fast it has to fly and the faster it flies the less time you have to get it back under control before it hits the ground!
A reduced span will improve the control but less area will mean it flies faster.
You have to find a suitable compromise.
Do let us know how you get on
quorneng is offline
Old 04-19-2013, 06:29 PM   #7
Dragon Master
This is my own plan just trying to go of a pic
Old 04-19-2013, 06:36 PM   #8
Dragon Master
give the motor a little down thrust like about 3 percent on a 3 cell lipo 3300 mah.
the motor i was going to use is turnigy Park 480 brushless outrunner with a 11x8 prop
http://www.hobbyking.com/hobbyking/s...dProduct=22636
Old 04-19-2013, 06:55 PM   #9
Dragon Master
wing area is 450 sq in
ailerons 60 sq in each
fin/rutter total area 40 sq in the rutter itself is 19 sq in
stab/elevator total area 76.5 sq in. The elevatos are 20.5 Sq in each
this may be a better pic of tail feathers
Old 04-19-2013, 07:22 PM   #10
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Friends: (16)
Looks like one of my old school pattern planes and i like the full airfoil wing. joe
road king 97 is offline
Old 04-19-2013, 07:33 PM   #11
Dragon Master
Attachment 167963
estimated flight weight will be around 32.oz (907 g)
so best of to leave the wings at the length they are at now, as i can always cut them shorter later it i want more speed
Old 04-19-2013, 07:49 PM   #12
Should fly great.....looks a little like the:
http://twistedhobbys.com/Telink-48-E...k-Multifun.htm
I've flown the Telink....yours, at 32oz, (a bit heavier) may have some of the same characteristics, great glider and forgiving stall's..........!
Old 04-20-2013, 01:46 AM   #13
Larry3215
Larry3215's Avatar
Those numbers look close enough for me
Larry
Building light vs. durability & Wing Loading vs. Stability payne9999 Scratch and Kit Built Aircraft 98 12-28-2014 06:44 PM
Model Airplane Building Clinic >> Begins 29 Sep. All Skill Levels Welcomed Murocflyer General Electric Discussions 282 11-04-2012 11:35 AM
Model Airplane Building Clinic - - Instructors Needed Murocflyer ParkFlyers 9 09-21-2012 02:55 AM
TOO WINDY TO FLY YOUR FOAMY? - Try Slope Soaring AEAJR Foamies 6 11-13-2011 06:21 AM
Its On, Start Building, 100 Mph Under $100.00 Foamie Contest CHELLIE Scratch and Kit Built Aircraft 151 09-12-2011 07:14 AM
Page generated in 0.12803 seconds with 45 queries
