Old 06-14-2013, 02:53 AM   #1
Dukepiles
Default adding weight to balance
i built my first foamie and need to add weight to the nose to balance it out. Not wanting to drive to the hobby shop i did some brain storming and while i was looking around i spotted some airsoft bb's. they weigh .25 grams. so even number means i could space em out evenly. i figure pop em in the foam and add a drop of hot glue and it should be good to go. has anyone tried this? do you think it will work?
Name:	2013-06-13 18.39.22.jpg
ID:	169373   Click image for larger version
Name:	2013-06-13 18.37.38.jpg
ID:	169374   Click image for larger version
Name:	2013-06-09 01.57.25.jpg
Dukepiles is offline
Old 06-14-2013, 03:01 AM   #2
View mclarkson's Gallery26
Friends: (8)
No reason it won't work, if you can get them stuck on there. I generally go with something a little heavier as it would take a ton of bb's to add an ounce of weight (100+) but if you just need a gram or two, go for it.
If you can move the battery, rather than add dead weight, that's generally a better option.
Old 06-14-2013, 03:36 AM   #3
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Pennies might be easier as the are heavier...just glue them right to the foam.
Old 06-14-2013, 03:55 AM   #4
Dukepiles
battery is all the way forward. Weighed it out and just going get a bigger battery it needs 45 grams. I guess I should have got new batts with a new plane lol (being cheap)
Old 06-14-2013, 05:36 AM   #5
I'd be worried about the hot glue might melt the foam???
For me, I've used lead shot mixed with some 5 minute epoxy for weight. It works out very well.
But, nothing worse than dead weight in a model airplane, if you can fit heavier batteries up there, that would be the way to go.
Old 06-14-2013, 07:03 AM   #6
+1 on that, you are better making the weight work for it's living, so add weight in form of battery and/or larger motor. Are you using all the recommended hardware?
Old 06-14-2013, 01:04 PM   #7
pattern14
pattern14's Avatar
Friends: (8)
2nd that as well. I just rebuilt my Me 262 and shaved 1/2 a kilo off it, and was able to remove all the lead ballast in the nose. Sometimes though, it is not possible to do that, even with rearranging all the internals, bigger battery etc. It is still far more important get the correct COG by adding weight if needed, even if it is dead weight
pattern14 is offline
Old 06-14-2013, 02:36 PM   #8
Dukepiles
The hardware is all right. they didnt give any advice on motor or battery. i just tried to be cheap and use ones i had on hand. i ordered bigger batteries last night. thanks all
Old 06-14-2013, 03:04 PM   #9
Reason i asked is because the motor looks far too small for the size of model. The motor is lost in the recess and the prop also looks much too small for a 3D plane. Compare motor and prop size of this similar Su-26m: http://www.rcfoam.com/product_info.php?products_id=359 i appreciate this might be a larger version of the model but look at the motor and prop in proportion to the size of the plane....
Having far too small a motor prop and battery would explain the CG issues you are having.
Old 06-14-2013, 03:19 PM   #10
Dukepiles
its a park 450 920kv plane is 41" span 9mil depron. unsure of what the weight is. the manual doesnt give any specs of the plane.
** Yeah i see what you mean. **
Old 06-14-2013, 04:20 PM   #11
Dukepiles
on the hobbies edge website its calling for alot smaller motor.
Old 06-15-2013, 12:26 AM   #12
Friends: (19)
One of the best lead weight items are stick-on wheel balance weights. They are specific weights, stamped into them ... self-adhesive .... another are weights available in fishing shops ... again known weights.
But at end of day - I always as others say make my extra weight work by larger battery or motor .... if I cannot alter design to get battery more forward.
Old 06-15-2013, 01:17 AM   #13
hayofstacks
hayofstacks's Avatar
move the servo tray forwards is another one that works well.
hayofstacks is offline
Old 06-15-2013, 01:25 AM   #14
Brings back memories of electrifying some of my various sailplanes in the mid 1980's. And, several scratch built models. Two side panels for the motor mount were extended forward of the original firewall perhaps 6 inches or so. Then, the motor and battery packs were moved back and forth on those two side panels until the model balanced.
Then, the side panels were cut off at the proper length. That became the location of the motor and battery pack. It was just a matter of filling in the top and bottom panels, and sanding everything round, to look nice. Rather crude, but hey, it worked out very well several times.
Old 06-15-2013, 03:32 AM   #15
swimmer
I needed to add some weight to the nose of my 30" wing and used finish nails. I weighed out the correct number of nails to get the correct cg and then pushed them into the nose of the plane. I hate to add dead weight but the wing is short enough didn't have a choice.
swimmer is offline
Old 06-16-2013, 09:46 PM   #16
Friends: (19)
Nails are also a good way to correct lateral balance where one wing appears heavier than other ... you push them into wing tips.
Old 10-14-2014, 03:25 AM   #17
upuprcflyn
Default Adding weight to foamy
Thanks for the post, I was thinking about adding weight to my FMS Sky Trainer Cessna 182 55in W/P. The CG said 60mm which is a bit off causing it to be just bit tail heavy, cant move batt any further forward never cross my mind to just get a bigger batt
upuprcflyn is offline
Old 05-28-2015, 06:00 AM   #18
c.sitas
This is way old but, I'll go with Nigel. You can go from the nails all the way down to needles. They are brass and respond nicely. I guess I just like to TINKER.
c.sitas is offline
Old 05-28-2015, 11:52 AM   #19
Friends: (19)
Nails are fine for very small corrections ... but my previous about Wheel Balance weights from Auto Tyre guys are my choice up front.
My Mini4 where I extended the nose to get better battery access ... now has 15gr of wheel stick-on weights under the tail. With tape over - you wouldn't know they are there !
Old 05-28-2015, 06:36 PM   #20
c.sitas
Yes , that is cool for the main cg location. What I suggested is more for lateral balance.
c.sitas is offline
Old 05-28-2015, 06:51 PM   #21
upuprcflyn
Default CG Balance
Thanks all,
I cut away some of the foam that stopped me from being able to push the battery a bit more forward. This seam to have fixed the CG issue, Now I have some down angle on the nose
Old 05-28-2015, 07:47 PM   #22
I've used lead shot and epoxy for balancing on my models. Haven't had to use that in years with my acrobatic electric models though. Just carve out a home for it, mix it and pour it in. It will not move!
Old 05-28-2015, 11:12 PM   #23
1kW
Friends: (7)
foamy? nails
I don't have a short temper. I just have a quick reaction to B.S.
Rob
Soldering wires together FlyWheel Electronic Builders Workshop 73 09-28-2013 09:24 PM
Things to check on an arf AEAJR Beginners 8 08-13-2013 11:29 PM
Page generated in 0.61468 seconds with 68 queries
