Old 06-25-2013, 01:49 AM   #1
jeff4912
Default Hobby Zone Champ flew off....
Went to the field today to fly my Alpha Sport 450, but first decided to fly my Champ since I had not flown it in a while. Hand launched it and it was flying nicely and then I would get intermittent loss of signal with it and it would not respond...then after a few seconds it responded again and continued doing this. I put a newly charged battery in the plane and changed the radios batteries with new ones but it continued to lose signal off and on.
Any ideas?
jeff4912 is offline
Old 06-25-2013, 02:10 AM   #2
hayofstacks
hayofstacks's Avatar
alpha is a fine bird for a trainer.
what radio and receiver?
I have had the same problems. I've decided it could the built in bec on the esc reaching low voltage cut off.
hayofstacks is offline
Old 06-25-2013, 02:14 AM   #3
jeff4912
Alpha has a Spektrum 5 channel receiver I think AR500 if that sounds right. I am using the Spektrum DX5e radio that I got with my Phoenix flight simulator.
I have only been flying rc for about 3 months.
Using 3S 2200 Mah battery 30C.
jeff4912 is offline
Old 06-25-2013, 02:59 AM   #4
Beemerider
Beemerider's Avatar
Club: Augusta County RC Club
When you say loss of signal--no response at all...throttle and control surfaces? Or just partially--no rudder for example. I have a Champ I bought for my grandson and we experienced difficulty with the rudder occasionally, seemed ok on the ground but sometimes the rudder would stick on right turns. I took the model apart and looked closely at the linear servo for the rudder. Found a bad tooth on the nylon gear on the servo shaft. It would cause the rudder to sometimes stick. A phone call to Horizon Hobby and they sent a new fuselage with the radio gear installed.
Does any of the above fit what your's is doing?
Beemerider is offline
Old 06-25-2013, 03:05 AM   #5
jeff4912
I think I probably had run down lipolies in it and misread the charger. The esc was probably getting a low voltage signal.
jeff4912 is offline
Old 06-26-2013, 09:22 PM   #6
Friends: (19)
Any ideas?
When this happens .. I know it's hard because you are trying to get control ... but it's good to note if it's same place it happens ... ie over a building, trees, near radar scanner, antenna etc. Next flight stay away from that area and see if it happens again.
When we flew at the airport ... we sometimes had strange things happen ... not just to one flyer ... but 2 or 3 .. and freq wasn't always same ... we had days when both 2.4 and 35 played up ..
Checking with each - we found it was nearly always when we passed near the remote radar scanner that was in the field next to the airfield ..
That scanner is linked to main ATC in Riga - 200kms away ... and is always operating.
Just posting ... most likely is poor LiPo such as bad connection or something..
Old 06-27-2013, 08:30 PM   #7
BBCorvette18
my champ literally flew away a week or so ago. Was at my cousins and we decided to go fly in wind that we obviously shouldn't of. Anyway got the little champ up in the air and then it wouldn't come down. it flew a long ways the last place we saw it was a bout 3/4 of mile from where I took off and my cousin spotted it at the top of a 300' tree. Luckilly I got that champ for 45 bucks so it doesnt hurt as much
BBCorvette18 is offline
Old 06-27-2013, 10:07 PM   #8
Beemerider
Beemerider's Avatar
I don't believe I've ever seen a 300' tree! They must grow 'em big where you live.
Old 06-28-2013, 01:30 AM   #9
hayofstacks
I lost signal on my ultra stick, possibly due to a bad antenna on my dx6i. range checked fine before flight, had no signal in range check mode after.
my flight was fine until I went for a long and low bank, which the plane wouldn't turn out of. as it came back around, I started getting random control of the aircraft, which ended with it flying off over the horizon inverted. with wot just seconds before losing it and a touch over 800watts, I feared.the worst.
I found the plane right side up on the landing gear. looked perfect from the 200' or so away I spotted it at. the wing tip hit some sage brush and somehow flipped the plane right side up with only the very outside edge of the wing broken up. I was excited to have it back in once peice, I didn't notice the broken wig dowels or broken up wing saddle.
Old 06-28-2013, 04:12 AM   #10
Turner
Turner's Avatar
Originally Posted by hayofstacks View Post
I lost signal on my ultra stick...
Which Rx were you using?
Turner is offline
Help with hobby zone super cub plz danauti1 General Electric Discussions 25 09-14-2014 06:19 PM
Looking for dx6i to buddy box hobby zone champ Rifled RC Radios, Transmitters, Receivers, Servos, gyros 1 08-26-2012 10:46 PM
For Sale Hobby Zone Super Cub LP Electronics simibill Radio Equipment For Sale & WTB 0 05-22-2012 05:17 PM
Hobbyzone Champ vs. Hobby Lobby Micro Stik t280708 Indoor & Micro Electric Planes 1 05-05-2012 12:27 PM
For Sale FS: Hobby Zone Super Cub BNF Kyonic Airplanes - Electric For Sale & WTB 2 07-05-2011 12:38 AM
Page generated in 0.13151 seconds with 37 queries
