Old 06-26-2013, 07:28 PM   #1
skyler
Default How to repair this monocote covering of wing?
I have made repairs to the ribs of this Gentle Lady wing - center section and one of the two removable tips. When flown, the sections are attached with electrical tape.
How to repair the monocote?
Should I first shrink the existing monocote with the heat gun so it is tight?
Then apply new pieces of monocote overlapping the existing monocote...even though there is not hard surface below the existing monocote?
skyler is offline
Old 06-26-2013, 07:58 PM   #2
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Friends: (16)
I most times cut the monicote back to a rib then leave the good side a little long and iron it down the side of the rib then tighten the side you are leaving by shrinking it a bit . Cut a new piece for the repair and over lap it 1/8 to 3/16 and iron that down over the other covering and make sure that all edges are ironed down ,then shrink it to look like the rest. It will pull loose if you dont get the edges ironed down good .You can clean it up with preps all or thinner to get the glue off that squeezed out where you ironed it down so the seam hardly shows . Hopes this helps. joe
road king 97 is offline
Old 06-26-2013, 08:35 PM   #3
Its difficult to get good results joining covering without some supporting structure under the seam. Definitely cut back to the nearest supporting structure.
Attach the new covering before doing more shrinking than occurs from ensuring the old covering is secure to the structure. This will help prevent pulling the ribs out of line or other warping of the structure.
Acetone is the solvent for most covering brands' heat activated adhesive. Fingernail polish remover with acetone in it works well for clean up of smeared adhesive. Windex with ammonia or similar glass cleaners will also remove some minor smears.
Old 06-26-2013, 09:13 PM   #4
road king 97
old hat
Friends: (16)
While flying combat years ago and getting clipped by another plane a couple pieces of tyvek tape and i was good to go again. lmao If it was a bigger spot of torn off covering a black piece of garabage bag and tyvek tape .lol If your battery pack made it back to the field after a fight you got 10 points. joe
Old 06-26-2013, 09:16 PM   #5
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
+1 - as simple as that.
Old 06-27-2013, 12:42 AM   #6
road king 97
old hat
Friends: (16)
I know most dont have a trim iron but for this kind of work and getting into tight spots and along corners it cant be beat . I did not think when i bought one that i would use it alot but i use mine all the time . I cut my own pin stripes out of reg covering and seal them down with it also on low heat so it does not shrink then hit it with a little higher heat to make it stay forever . joe
Old 06-27-2013, 01:51 AM   #7
I've flown that Gentle Lady many times years ago. If memory is correct, the Gentle Lady wing structure doesn't have a lot of solid places to attach the monokote.
What will work, is go to your local hardware store, pick up some of that yellow carpenter (Titebond) glue, and get a few pieces of balsa sticks, perhaps 1/4 inch thick, and 3/4 inch wide. Exact size really isn't critical.
Cut and fit that balsa stick to be a snug fit between the ribs back under the existing busted monokote. Then, put a few drops of Titebond on the balsa stick and the ribs, and sneak it into place. Make certain it will be flush with the underside of the monokote. You could also use CA, but that might be harder to work with in the confined area of the wing.
Give it a half day to cure, then iron on the existing monokote to the new balsa sticks. Cut off what overlaps the balsa stick. Then, just iron on the monokote to the balsa stick or sticks, depending on how many sticks you need to add.
FYI, if you just try to attach monokote to existing monokote without an underlying structure, you run the risk of the existing monokote shrinking up, and making a real mess to fix.
Old 06-27-2013, 04:30 AM   #8
Adding sticks to support the edges of the torn covering can work. Just need 1/8 X 1/16 to 1/8 inch square for the purpose. No need to go heavier. Its not to repair damaged structure. Just something to help with making the covering joint.
Old 06-27-2013, 02:20 PM   #9
skyler
Ironing down the side of a rib is good advice - really helps...thanks.
skyler is offline
Old 06-27-2013, 02:23 PM   #10
skyler
Well I tried the repair without installing new balsa sticks, because I felt the existing monocote was taught enough, and the patch adheres fine, but when shrinking with the heat gun it all separated. So true to your advice extra support balsa is necessary unless I remove all the monocoate from the wing section and start again.
skyler is offline
Old 06-27-2013, 04:57 PM   #11
skyler
Well, the only way I was able to make the repair on the main wing body was following Dennis' direction. It took more time, but it made for a good solution. Not wanting to wait half a day for tightbond to dry, I used ca, assuing it would be just as good.
Thanks Dennis!
skyler is offline
B-47 1/10.2th Scale, Boeing Stratojet...In The Beginning Flite-Metal Electric Ducted Fan Jets 543 05-28-2016 05:22 PM
#26 Model airplane build clinic... Astro Hog pd1 Scratch and Kit Built Aircraft 106 08-24-2014 04:00 PM
dihedral on low or mid wing paulatgis Scratch and Kit Built Aircraft 26 12-19-2012 12:25 AM
Sold Eva Sport KIT NIB+ 2 rolls of covering. price dropped. 1987tc Airplanes - Electric For Sale & WTB 3 02-25-2011 07:59 PM
Page generated in 0.17712 seconds with 42 queries
