Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > 3D Flying
Old 06-26-2013, 10:38 PM   #1
Opticplank
Default PZ Visionaire battery/prop upgrades?
Has anyone found a battery or prop combo that increases the flight time from 5 min you get with the recommend 3 cell 2200?
Opticplank is offline
Old 06-26-2013, 11:05 PM   #2
If you can afford them Thunder Power 'Pro-Lite' batteries are more compact and lighter than other brands, this means you can put in larger capacity batteries without adding extra weight. For instance a 2700mAh Pro-Lite battery is about the same size and weight as 2200mAh batteries made by most other manufacturers. You could add nearly 25% flight time with no weight impact by using 2700mAh Pro-Lites.
But they aren't cheap....
Tweaks for PZ Visionaire JZSlenker 3D Flying 12 09-11-2013 09:33 PM
PZ F4F Wildcat Cheap and Fast TopSpin Warbird Electrics 24 09-03-2013 04:02 AM
PZ Archer or PZ T-28 Trojan for flying in a baseball field njg ParkFlyers 4 02-15-2013 03:26 PM
Mod - PZ Messerschmitt Bf-109G reef_rc ParkFlyers 17 09-19-2011 10:06 PM
CX3 Upgrades calldaffer E-Flite Helicopters 7 04-04-2011 08:33 PM
Page generated in 0.05842 seconds with 21 queries
