Old 06-27-2013, 06:02 PM   #1
Crasher
Default FlySky CT6B Throttle travel limited
This question is for the owners/operators of the Fly Sky CT6B, 6 channel R/C TX that are using these on airplanes. I have 3 of these new systems and they are programed from software that I have on my PC; i.e., stick travel, servo direction, etc. I found on one of the TX's, that my left/vertical stick (mode 2) for electric throttle, will not shut the motor down to a stop, even with this stick trim set to minimum. (All three of these radios where attached, in turn, to the same airplane and motor/ESC for this test). This setting is seen when I have this TX attached to my PC running the software program; the minimum stick movement is not at zero. It is the same programing and settings that I am using in the other two TX's, and they work just fine. Therefore, I am wondering if there is a way that I can make a mechanical adjustment or trim pot setting, perhaps, to set the throttle stick for proper operation? Has anyone, with this radio or others, had the same problem and dealt with it, and how did you do it? Thanks to all who help, Crasher.
Crasher is offline
Old 06-27-2013, 11:16 PM   #2
Friends: (17)
Try here :
http://groups.yahoo.com/group/Flysky_RC_radio/
A group I started so owners of any FlySky radio could get other owners info and advice / help.
It's free to join ...
Old 08-04-2013, 08:14 PM   #3
Crasher
Thanks Nigel; this problem was my software set up, I have it corrected now. Karl
Crasher is offline
Setting up Castle Creations ESC's JetPlaneFlyer Power Systems 31 06-30-2012 03:58 PM
Using the FlySky CT6B as a Trainer/Student Crasher RC Radios, Transmitters, Receivers, Servos, gyros 1 03-15-2012 08:05 PM
EPA, ESC and throttle solentlife Power Systems 13 02-19-2012 12:13 AM
New guy asks - Anyone ever setup throttle fixed endpoints on CC ICE75 & DX6i? DanWard Beginners 2 03-11-2011 01:23 PM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.05837 seconds with 23 queries
