Old 07-03-2013, 11:30 PM   #1
FishHawk
Default Futaba radio question.
I recently crashed and lost my glider which had the R127DF receiver and S133 servos . Can you tell me what I can use to replace this equipment and still use my current radio. I have the Conquest FM Radio FP-T4NBF crystal is 72.270 MHZ . I would like to still use this radio if at all possible.
Thanks in advance . FishHawk
FishHawk is offline
Old 07-04-2013, 01:38 AM   #2
Sir Crash-A-Lot
Crash Specialist
Sir Crash-A-Lot's Avatar
Club: East Valley Aviators
I would test the items that were in the crash and if they are o.k. then reuse them. I have done this several times with servos and receivers in the past myself.
THE KEY IS TO VERIFY EVERYTHING IS WORKING CORRECTLY BEFORE YOU FLY IT AGAIN.
Also, be sure to do a proper range check.
Sir Crash-A-Lot is offline
Old 07-04-2013, 03:31 AM   #3
FishHawk
Default Lost the glider
I forgot to add that I lost the glider in a marsh and it is gone. So , I need a replacement RX to go with my radio. FishHawk
FishHawk is offline
Old 07-04-2013, 06:43 AM   #4
There is a wide assortment of compatible receivers and servos, depending on what you want to do. The 2 things to watch for is "pulse shift" (JR positive, Futaba negative) and proper frequency.
There are some auto-shift detecting receivers and even frequency synthesized receivers which could work with any 72 mhz FM radio.
If you are not afraid of used receivers you might be able to find some real bargains since many people are dumping 72 mhz stuff.
It may be better to get a complete RTF package deal which includes a new 2.4 ghz radio though.
Old 07-04-2013, 06:49 AM   #5
Past President of PSSF
Friends: (8)
You can get many brands of receivers that will work with your Futaba transmitter as long as you are on the same channel for both units.
Your LHS should be able to fix you up, or Ebay, and HK
Fm systems are not locked into the brand of transmitter like 2.4 g systems, so any good receiver should work. I have mixed several brands with no problems.
Dave R, Proud PGR rider.
http://www.pugetsoundsilentflyers.org/
Wildflyer is offline
Old 07-04-2013, 05:34 PM   #6
Rodneh
Club: Moonport Modelers
Fishhawk, you do not state your location. If in the USA your Futaba will be using negative shift so any receiver you get must work with negative shift. Airtronics and Jr are positive shift so their receivers will not work well with the Futaba. Several companies make receivers that have selectable shift, some automatic. Just make sure that the shift is compatible and you have many options for a receiver.
Rodneh is offline
Old 08-09-2013, 08:12 PM   #7
Friends: (9)
Cool
Futaba receiver $60 + $13 for crystal
http://www3.towerhobbies.com/cgi-bin...&I=LXLSX4&P=ML
Or you can take that $73 and apply it to a new radio with way more capability than an old Conquest radio.
Futaba 6J with receiver - $180
http://www3.towerhobbies.com/cgi-bin...&I=LXARLD&P=ML
Hobbico Tactic 650 with two receivers - $150
http://www3.towerhobbies.com/cgi-bin...&I=LWG101&P=ML
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 08-09-2013, 08:28 PM   #8
FishHawk
Default Thanks
I ordered the just ordered the receiver . Thanks
FishHawk is offline
How To Select Your First Radio AEAJR Beginners 25 02-27-2014 02:24 PM
For Sale Futaba 6EX 2.4ghz FASST radio + lipo battery Mysterious Radio Equipment For Sale & WTB 1 12-03-2012 07:43 PM
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 01:57 PM
hitec 05s micro receiver and futaba radio andyrew RC Radios, Transmitters, Receivers, Servos, gyros 2 07-05-2011 01:07 PM
Radio Question Futaba 10Cag vs. DX8 RCFlyer44 General Electric Discussions 19 03-01-2011 06:14 PM
Page generated in 0.08496 seconds with 33 queries
