Old 07-07-2013, 03:09 AM   #1
hkeelljr
Question Electric Hots
Howdy, one and all. Finally have some time to rest and catch up with things other than work,honey-dos, etc. As mentioned in a prior post I bought an electric hots and other items from a friend, who had built the hots and a Global Cessna Skylane(.60 version)., well maybe partially completed. After repairing the wingtip of the hots and adding the ailerons, and other flight surfaces. Now the big question, after weighting the hots with everything assembled, it weighted 14.5 ounces, of course the scales I'm using probally not all that precise. The research I've done indicates that the e-flite 450 ,brushless, is the way to go. Now, what about servos, esc,etc. Any suggestions will be appreciated.
hkeelljr is offline
Old 07-07-2013, 08:20 AM   #2
View CHELLIE's Gallery13
Friends: (327)
Hi use HXT 9 gram servos, they are very strong and inexpensive, Ues turnigy ESC they are the best ESC for the money, never had any problems with them, you may want to use a 25 to 30 Amp Turnigy Plush ESC
The Turnigy Lipos are very good too.
http://www.hobbyking.com/hobbyking/s...ontroller.html
http://www.hobbyking.com/hobbyking/s...cro_Servo.html
1350 to 1800amh 3 cell lipo should work well for you, it all depends if you want to build lite or heavy
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Pick Up Some XT60 female and male battery connectors, its the type of connector that comes with the HK Lipos
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
If You Need A Lipo Charger, This is a Nice one
http://www.hobbyking.com/hobbyking/s...cessories.html
you will need a power supply for the charger. or you can convert a old pc computer power supply for a charger power supply for free if you have a old pc laying around.
Old 07-07-2013, 08:49 AM   #3
Friends: (327)
450 motor or similar. at about 1000 to 1200kv
http://www.hobbyking.com/hobbyking/s...er_1050kv.html
http://www.hobbyking.com/hobbyking/s...er_1200kv.html
300 Watt motor
http://www.hobbyking.com/hobbyking/s...00kv_300w.html
if hk is sold out, they get the motors in very quickly, get on the email notify list.
Old 07-07-2013, 12:31 PM   #4
hkeelljr
Thank you Chellie, I will take your recommendations under consideration and they are a lot reasonable price wise.
hkeelljr is offline
Old 07-07-2013, 05:44 PM   #5
hayofstacks
hayofstacks's Avatar
seeing as many of those parts are from the international warehouse, that apparently.doubles your order.heads up has a 1800 3.cell 30c battery for $1 less, the 450power up sport motor from heads up pulls almost 50more watts for $2 more.
1800mah battery
http://www.headsuphobby.com/111v-180...tery-A-215.htm
450 sport motor
http://www.headsuphobby.com/Power-Up...otor-E-565.htm
30 amp esc with switch mode bec (superior to cheap esc)
http://www.headsuphobby.com/Sky-Powe...-BEC-H-100.htm
9g sub micro servo.
http://www.headsuphobby.com/Power-Up...ervo-H-400.htm
micro servo for a drop in installation if the kit suggest a micro servo. seems like its well within sub micro range for weight.
http://www.headsuphobby.com/iFlight-...ervo-G-535.htm
no soldering, no changing.connectors out, drop in, plug in and play, have it to you in 2-3 days with $2 shipping.
hayofstacks is offline
Old 07-07-2013, 05:48 PM   #6
hayofstacks
if you end up tail heavy, might want a bit more overweight.
http://www.headsuphobby.com/Power-Up...otor-E-570.htm
380 watts on 3 cells, and 450 on 4 cells, iron you get the need for speed.
Old 07-07-2013, 06:03 PM   #7
vicrider
vicrider's Avatar
Is this the midwest electric hots ?
I built the lectric hots from M.A.N. plans which is what the midwest version is based from. If this is the one you have you might find that a .450 might be lacking in power. Mine all up with a 2200 3 cell weights 33oz. Its powered with an os .10 and a castle 54 esc. This provides really good power while not being overly powered, just enough to pull it straight up.
Here is a thread that I had posted concerning power for it, with a crappy video.
http://www.wattflyer.com/forums/show...t=lectric+hots
Is this like the one you have?
Name:	kd and plane 001.jpg
Is th
vicrider is offline
Old 07-07-2013, 11:38 PM   #8
Friends: (327)
If You Want Tons of Power, use a 480 motor of about 1000kv and a 4 cell lipo with a 40 amp esc. and a 11x5.5 apc prop and you cant go wrong using Heads Up Rc too
Old 07-08-2013, 12:26 AM   #9
vicrider
vicrider's Avatar
This is a good suggestion.
When I built mine, being tail heavy was my main concern. 3.6 oz motor and 3 cell worked out great. Didnt have to add any thing additional.
That motor weights the same as os .10 that I used. Its slightly smaller in diameter as the os but slightly longer.
vicrider is offline
Old 07-08-2013, 02:56 AM   #10
hayofstacks
the 450 sport motor I linked to should pull 37oz of thrust and the 480 about 55 oz. won't be under powered by any means if battery can support it .
Old 07-21-2013, 01:35 PM   #11
hkeelljr
Smile
Just read thru all post that posted and to Vicrider yes its the Midwest Hots would be interested in the plans though. Anyway, just finished the servo installation took awhile but doing it right the first time is always the best way. Mine is nose heavy even though the servos are located at the aft part of the wing. Will place whatever battery in the tray made by the bottom sheeting on the wing to hopefully get the balance right, won't know until I get the motor and install it. Used the old esc from my Gamma 370 to set up the servos so they should be close when it comes time to fly it for real. Probaly will get another aries rx so I won't have to swap it back and forth. Thanks all for the advice. Now on to other projects! Stay tuned for further updates.
hkeelljr is offline
Old 07-21-2013, 04:38 PM   #12
vicrider
vicrider's Avatar
Looking forward to it.
vicrider is offline
Old 07-21-2013, 10:10 PM   #13
road king 97
old hat
road king 97's Avatar
Club: joliet rc club rt 66
Friends: (16)
The electric hots was desighned by Don Sobbe and he is a friend of mine for many years. He retired from his full time job now and Midwest to but i seen him two years ago at a water funfly meet and he is doing well and still flying. Here is the hots 11 and the hots for hkeelljr also ,the hots 11 was 46 inch wing span and the hots was 48 , enjoy. joe
road king 97 is offline
Old 07-21-2013, 11:49 PM   #14
vicrider
vicrider's Avatar
Im a real fan of the hots.
My current one is the lectric hots built from model airplane news plans.
I have also had a super hots, also built from plans.
My first hots was the original, built from the midwest kit. I also had the hots 2, also built from the midwest kit.
All were great flyers.
vicrider is offline
Old 07-22-2013, 12:20 AM   #15
road king 97
old hat
Friends: (16)
I had the 60 nitro size one and it few great so i save the electrict hots plan to build some day. joe
Old 07-22-2013, 02:47 AM   #16
Dereck
Love the 'electric Hots' - especially the 'throttle', a servo driven on/off slide switch!
Haven't heard of that party trick since my first electric powered model back in 1985!
Wonder if there's a way to fit a topside battery hatch on an E Hots? Don't fancy a lipo buried down there... That aileron servo with bendy 'S' shaped pushrods would be gone too.
Neat model on the whole, though
D
Dereck is offline
Old 07-22-2013, 04:16 PM   #17
road king 97
old hat
Friends: (16)
D
It would be easy to build with a internal frame for a hatch and i know it would be a piece of cake to do by you Dereck. Here is another plane that started out as the Pizazz but now they call it the hanger-9 twist . Its tiled with alot of pages .lol joe
Old 07-23-2013, 03:36 PM   #18
hkeelljr
Default Electric Hots
Have question on motive power? Will a 480 be better and can it be run on 3 cells without any problems?
hkeelljr is offline
Old 07-23-2013, 06:36 PM   #19
road king 97
old hat
Friends: (16)
Iam sure others will reply cause iam not good on motor selections but i think its to small for what youi want this plane to do. I know you can run 480 on 3 cells iam doing it on a couple planes .If it weighs 14.5 ounces the 450 would still be good . You want the lightest motor but enough thrust to go vertical . joe
Old 07-23-2013, 08:10 PM   #20
hayofstacks
did you read the thread?
it was spelled out for you by more then one person. people even.talked about weight and cog issues and why they liked which motor.
what do you need to know?
Old 07-23-2013, 09:55 PM   #21
vicrider
vicrider's Avatar
If its a 480 thats comparable to an eflite .480 I think the plane will be underpowered. The .480 that was suggested in post #6 I think would be great. I think this way cause that motor is more powerfull and heavier then the typical .480. I beleave you are going to have to put lead in the nose to balance it if you use anything lighter. This plane comes from a time when the heavy brushed can motors were used and was designed with the wieght of those motors in mind. Might as well put that wieght in to a more powerfull motor and make that plane fly the way its supposed to. A .450 would make the plane a real pig. All of this is considering that a 3-cell is being used.
There is not much differance between yours and my plan built version. My plan was to use an eflite .480 but with suggestions from this forum and actually putting that motor to the plane it was obvious it wasnt going to be enough. I put an .o.s .10 on it with a 2200 3-cell and it balanced perfect and has good power but I really think the plane could handle a .15 without issue.
vicrider is offline
Old 07-23-2013, 10:58 PM   #22
road king 97
old hat
Friends: (16)
A little testy today are we ? I would go with what vicrider recomends he has one and if he says a 480 will fly it but with no fun i would go with a 15 . Its not a trainer and its not a slow stick so lets get some speed. Vicrider knows the plane just dont buy the same bike he rides. lmao They tried Arlen Ness and ended up with a mess. joe
Name:	road king 97.jpg
Old 07-23-2013, 11:16 PM   #23
Friends: (327)
HI if using a 3 cell lipo, use a 480 - 1450KV speed motor, it has more KVs and will give you better performance than a 1000kv motor will on 3 cells,
http://www.headsuphobby.com/Power-Up...otor-E-690.htm
Old 07-23-2013, 11:22 PM   #24
Friends: (327)
a 480 is a great power house, and it is a little heavier, thats a good thing, because e power planes tend to come out tail heavy, use a 1450Kv 480 motor on 3 cells, a 1000kv 480 motor will work on 3 cells, but it will be a little on the slow side.
A 480 - 1000kv motor on 4 cells is a Monster I have that set up in a katana, it leaps up off the ground
Old 07-23-2013, 11:28 PM   #25
hkeelljr
Thanks for the replies, but will likely get the 450 for now due to budget constraints.
hkeelljr is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 12:56 AM
WHITMAN FLYERS ELECTRIC FLY-IN 8/10/ 2013 Bethpage NY whitman flyers Events, Shows and Fun Fly's - Electric Airplanes 3 07-11-2013 02:03 AM
M.A.N. Lectric Hots vicrider Scratch and Kit Built Aircraft 8 07-22-2012 10:34 PM
WHITMAN FLYERS ELECTRIC FLY-IN 8/13 2011 Bethpage NY whitman flyers Events, Shows and Fun Fly's - Electric Airplanes 5 08-14-2011 06:00 AM
Page generated in 0.62118 seconds with 70 queries
