Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Scale E-Powered Aircraft
Old 08-13-2013, 06:22 PM   #1
rotorsport
Default HobbyKing DHC-2 Beaver 1353mm (ARF)
I'm not a balsa builder but have been flying lots of arf's over the years I have a lot more experience in helicopters.
I just finished reading the sticky on this site on all you need to know. This is all still in the box and I under stand that there will be a lot of trial and error and a steep learning curve.
Any advice is welcomed!
The DH Beaver is of course famous for its STOL capability, load capacity and general ruggedness and fans of the Beaver will be pleased to see this larger version of our popular 40" kit.
This nicely made ARF is a pleasure to build and features a removable wing, easy access magnetic battery hatch, large lightweight wheels, steerable tail wheel and so on. A choice of motor mounts come with the kit as does a very comprehnsive hardware kit. This model being a little bigger means of course it will cope with the wind just that little bit better but either size Beaver is perfect for those calm, relaxing days at the field.
Specs:
Wingspan: 1353mm
Length: 835mm
Dry Weight: 760g
Includes:
All Hardware
Instrucions
Requires:
Your Own 4 channel TX/RX
28mm~35mm Brushless Outrunner Motor
30A ESC w/BEC
4 x 9g servo
2200mAh 3s Lipoly Battery
http://www.hobbyking.com/hobbyking/s...dproduct=15388
rotorsport is offline
Old 08-16-2013, 08:53 PM   #2
rotorsport
Default Beaver HK
got the box opened today wings look good opened up the wing servo opening 14mm X 30 MM
I was going to some to use some HK Hextronik 9g servos but they are too small
ID:	170272   Click image for larger version
ID:	170273   Click image for larger version
Old 08-17-2013, 11:19 PM   #3
rotorsport
So looks like it's going to be Hitec Servos for aileron, Rudder and Elevator
Hitec servo
HS-82MS
Servo - Micro Metal Gear Univ
SPECIFICATIONS
0.12 sec/60 Speed @ 4.8V:
0.10 sec/60 Speed @ 6.0V:
38.88 oz-in Torque @ 4.8V:
47.22 oz-in Torque @ 6.0V:
19.0 g Weight:
29.8 x 12.0 x 29.6 mm Dimensions:
Old 08-18-2013, 01:25 AM   #4
DHC Beaver
DHC Beaver's Avatar
Scratchbuilders Award
If you wanted to use the 9g servo's,couldn't you make up some plates from,say,1/16th ply,to fit over the existing hole?Just a thought.
On the other hand,maybe you need the slightly bigger servos on a plane this size.
DHC Beaver is offline
Old 08-18-2013, 03:28 AM   #5
rotorsport
I started to do just that and changed my mind, The 9g servos looked small when I started to fit them into the wings.
Things to check on an arf AEAJR Beginners 8 08-13-2013 11:29 PM
HK Beaver DHC touche Scale E-Powered Aircraft 0 10-09-2012 05:09 PM
For Sale Pilot-1 50" Waco YKS 6 1/8th Scale BiPlane ARF ARF philscho Airplanes - Electric For Sale & WTB 0 03-23-2012 10:26 PM
Hobbyking Yak 54 30ep 1280mm (ARF) - Crash budkeywest Video Parking lot 0 12-27-2011 03:34 AM
Page generated in 0.21318 seconds with 32 queries
