Old 08-19-2013, 12:43 PM   #1
Friends: (17)
Default Piper Cherokee ...
Having now completed the J3 Cub ... I was looking through various pictures and found an old picture of a Cherokee I used to fly. It had a Irvine 20 up front and was not too bad ... kit itself was not so good and overall scale was a bit iffy ... but it tickled that spot !
I then sought out online a plan ... and came across Pilot's U-Control Junior series Cherokee ... right size ... right style ... just right for a 3S 1800, 7x6 prop size set-up.
mmmmmmmmmmmm do I or don't I ... so many other models I want to build as well ... 6mm Depron / Floor foam ... have a good supply in ... mmmm
We'll get back on this !!
Old 08-19-2013, 03:29 PM   #2
Dikybird
Bob
Hi where did you find the Cherokee plan ?
Regards Bob
Dikybird is offline
Old 08-19-2013, 03:57 PM   #3
Friends: (17)
Outerzone ..... http://www.outerzone.co.uk/plan_details.asp?ID=2351
Here it is attached below.
My initial thoughts ... increase the number of ribs as I will do in foam sheet. Pine spars. Single servo ailerons with torque rods to keep wing clean.
Top and bottom sheet wings in 3mm depron.
Fuselage in 6mm sheet with extra laminated 3mm in wing seat area...
Old 08-19-2013, 04:01 PM   #4
Dikybird
Bob
Thanks Nigel,
I sold my Cherokee 140 (fullsize) and would love to build a model of it
More ribs would help with the sheeting.
I have a plan somewhere it is about 4 sheets I will see if I can find it and pass it on to you.
Are you in the US
Cheers Bob
Dikybird is offline
Old 08-19-2013, 04:18 PM   #5
Friends: (17)
Originally Posted by Dikybird View Post
Thanks Nigel,
Are you in the US
Cheers Bob
No Latvia .... I moved here from the UK in 1993 just after the fall of Soviet ...
Plan would be nice - but truly - not necessary ... I have various I can fall back on and it would get lost amongst my vast collection !!
I'm always surprised that Cessna's and similar get a lot of models made - but Cherokees not.
Maybe it's the low wing bit that puts people of ?
Old 08-19-2013, 04:32 PM   #6
Dikybird
Bob
Latvia that is interesting ! I am in Portugal.
OK I understand I end up with loads of stuff I never use.
It is interesting not much stuff on Pipers at least as you say on low wings
Do you get stuff from Hobbyking?
Cheers Bob
Dikybird is offline
Old 08-19-2013, 04:54 PM   #7
Friends: (17)
About 85% HobbyKing .... 10% Ebay and rest wherever I can scrounge !! I am also receiver of others broken models that I patch up and get flying again.
We had 2 Hobby Shops in Riga ... 3hrs drive away from me ... 1 was basically a mail-order front - high priced, and other had loads of gear but not what was needed ! They went bankrupt ... so now we basaiclly have no LHS to speak of. Guys order from Germany, UK, HK - whatever. The biggest hurdle then is Latvia Post will not accept large boxes ...
Old 08-19-2013, 06:44 PM   #8
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Nigel - what size is this plane going to be?
I would ditch the ribs! I think the spar is enough and I have used that on a .60 size 4 star (granted a light, slow flyer) with no ill effects. I am using thicker material (blue core) however. If you are using thin depron you may consider adding more spars.
Just a thought....
Old 08-19-2013, 07:22 PM   #9
Friends: (17)
Rcers ... I agree that usually its fine to just go spars ... but on this one I want to try and keep the wing form. Usually as you see from my other builds - I often ditch the ribs and use tapered foam spar etc.
Having proven my combo system on a few scratchbuilds now where I split down DIY wood to thin spars and foam ribs ... I get a light but incredibly strong structure. AND get away with using 3mm sheet.
The Mini4 is best example.
I'm also considering the addition of thin wood spar along the fuselage to counter the flex and structure change that foam often suffers ...
Size ? I'm looking to go for up to about the 900mm mark ... just slight up from the plan size.... I've scaled by 125% ... This keeps it with my motor pool ... and the 7" props.
It's still ideas in head at present ...
For Sale Ace RC Simple Series J3 Piper Cub davidjt18 Airplanes - Electric For Sale & WTB 1 07-24-2016 04:57 AM
Piper L1 construction questions 1geo1 Scratch and Kit Built Aircraft 4 08-13-2013 07:46 PM
For Sale Herr Engineering Piper Cherokee Kit. davidjt18 Airplanes - Electric For Sale & WTB 1 02-07-2013 09:53 PM
Guillows Piper Cherokee matiac Beginners 3 06-30-2012 09:05 AM
J3 Piper crash blikkboks Crash and Safety Forum 1 02-05-2011 06:59 PM
Page generated in 0.08131 seconds with 37 queries
