Old 08-21-2013, 03:32 PM   #1
npowell28
Default Air compressor for Air Brush
Sorry but it didn't know where else to put this. I've just bought an air compressor from my local Sainsbury Garage in the UK. I bought it to blow up some camp beds but the connector is wrong. I was just wondering before i take it back if i could use it on an air brush. I've seen some starter air brush kits with a can of compressed air which power it. Just wondering if i could buy one of these and power it off the compressor.
The compressor i bought is a DC 12v 250 psi compressor. A few more details which don't mean anything to me but might to someone else
60 Watt (i'm fine with this bit)
4.5 L/min (presume this means litres per minute)
15000 min-1 (not a clue)
8 amp (i know what these are)
Its got a rubber hose which is covered with nylon and terminates with the sort of adapter you would blow your car tyres up with. The power lead is the type you put to a car cigar lighter. No problem there, i've got an old 12v DC adapter which i could solder on. Let me know your thoughts before i take it back to the shop.
Cheers Neil
npowell28 is offline
Old 08-21-2013, 03:44 PM   #2
BroncoSquid
Workin on it...
BroncoSquid's Avatar
Club: Bill G fan club!
I too am new to the airbrush world. You would need some type of air regulator on the compressor.
Here is where I go for all my airbrush info.
http://www.theairbrushforum.com/index.php
I'm either going to get good at flying em, or get good at fixin em!
BroncoSquid is offline
Old 08-21-2013, 04:02 PM   #3
npowell28
cheers dude! I've posted on there too.
Old 08-22-2013, 12:17 AM   #4
View CHELLIE's Gallery13
Friends: (326)
Cheers Neil
Hi thats not a good air comp for air brushes, not enough air volume, too high of a working pressure and no air regulator. Take it back
you need something like this.
http://www.ebay.com/itm/New-Pro-Air-...item565a086983
Old 08-22-2013, 12:50 AM   #5
You could use the cheap 12v compressor if you use a large volume to store up pressure and a regulator.
Cost will meet or exceed the cost of a proper regulated compressor intended for air brushes.
Not sure where to recommend in the UK..
Harbor Freight has some decent low cost air brush compressors available here in the US.
Old 08-22-2013, 01:42 AM   #6
DHC Beaver
DHC Beaver's Avatar
With compressors for home use,it's still a case of "bigger is better".You'd want an absolute minimum of 7litres per minute.If you're needing it for automotive use,minimum 10 lpm.The standard outlet fitting for compressors is 1/4",but many adapters are available.These days,a simple regulator is usually fitted as standard.
You also need a water trap,and personally,i like the quick disconnect fittings.For my Paasche airbrush,I use a plastic spiral hose.Nice and light.
DHC Beaver is offline
Old 08-22-2013, 09:49 AM   #7
Friends: (18)
Forget it ... as another says - the flow volume is far too low.
Only way to use it ... you would need to have a car tyre or similar as pressure reservoir to power the air-brush ... with the compressor trying to top-it up ... but believe me - it's just not worth the trouble.
Put the compressor in back of car and keep for the car use.
In UK - Screwfix online and other dealers have hobby air compressors designed for the job.
Flitetest join the downwind turn debate! JetPlaneFlyer Aerodynamics 63 03-06-2015 03:26 AM
Air flow spinners.. foodstick General Electric Discussions 3 01-16-2012 11:11 PM
Mountain Models P51 air scoop help needed sgschwartz Scratch and Kit Built Aircraft 2 01-14-2012 03:49 AM
For Sale Sterling, Green Air designs, Flying Styro, Hyperion Skypoet Airplanes - Electric For Sale & WTB 1 07-19-2011 04:25 AM
Nona air wheels? eye4wings Scale E-Powered Aircraft 22 06-04-2011 06:31 AM
Page generated in 0.08589 seconds with 31 queries
