Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Warbird Electrics
Old 08-29-2013, 02:10 AM   #1
riot3d
Default World Models' latest 40 size warbird - the Zero
Just maiden the World Models' 40 size Zero EP this morning. All wood construction, stock outrunner motor & 40A ESC, Futaba receiver & servos. Turnigy 4S, 3,300 mAh, 30C battery on APC 11x8 E prop.
It took me three evenings to put the plane together. What can I say, I''m a slow "installer" ... . Every parts are precise & put together real easy, they especially did a good job on their covering/ color scheme & looks really realistic . The recommended CG came out slightly tail heavy, so I balance it with two square weight on the nose.
Take off run requires holding a little right rudder, climb out & subsequent trim flight for straight & level was pretty uneventful. It did require a touch of right aileron & some down elevator - with landing gear on both extended & retracted position.
Since the nose cowling is fairly large, you do need to keep the speed up & hold slight elevator while turning. Loop tracks fairly well with minor rudder correction, & roll requires slight down elevator when it's inverted.
When it comes time for landing, be sure to maintain slight throttle to prevent stalling. Try not to hold too steep of a glide angle, with some practice & above idle throttle, you should be able to touch down with a three point landing.
I've always enjoy flying the World's 40 size Spitfire & Mustang EP. With the Zero's kit price of $159.99 - motor, battery, esc, radio equipment required, it's definitely another winner from World's.
Now, if I can only persuade their owner Fai Chan to offer the de Havilland Mosquito fighter, I'll be a real happy camper.
Adrian
ID:	170498   Click image for larger version
ID:	170499   Click image for larger version
riot3d is offline
World models voodoo 46 Stangfreak2001 General Electric Discussions 2 01-09-2013 10:52 PM
World Models Super Tai Ji 40ep dumpsterjay Pattern aircraft 2 11-29-2011 11:44 PM
World Models Park Flyers wolfewinde ParkFlyers 10 07-22-2011 03:29 PM
40 size electric cub hybrid General Electric Discussions 16 02-12-2011 10:35 PM
Page generated in 0.19366 seconds with 24 queries
