Old 09-05-2013, 07:09 PM   #1
dereckbc
Default Foam Safe Paint
Title says it all.
Want to paint the underside of plane to help with orientation. What kind of spray paint can I use on foam?
dereckbc is offline
Old 09-05-2013, 07:15 PM   #2
View CHELLIE's Gallery13
Friends: (327)
Originally Posted by dereckbc View Post
Title says it all.
Testors, Its The best, Make sure it says Styrofoam on the top of the Lable
http://www.hobbylinc.com/htm/tes/tes...FS6CQgodj0UAaw
Old 09-05-2013, 07:26 PM   #3
dereckbc
Thanks I think Hobby Lobby sells it here in Sherman. Now all I gotta do is figure out a high contrast color for the partially color blind like myself. Day-Glow Orange sounds tasty.
dereckbc is offline
Old 09-05-2013, 08:06 PM   #4
Friends: (327)
I do The same thing I need a bright colour on the bottom of the plane to see it way out there
Old 09-06-2013, 12:04 AM   #5
Depends on the foam also...
EPO can handle every spray paint I have tested so far.
Old 09-06-2013, 12:07 AM   #6
crxmanpat's Avatar
View crxmanpat's Gallery20
Club: Arizona Model Aviators, Gilbert Quiet Flyers
Friends: (27)
I have used every type of Testors paint on just about every type of foam with no issues at all.
When you go to Hobby Lobby (or Michael's or Jo-Ann's, they all carry it), make sure you take a coupon with you. You can normally find one for at least 40% off one regular priced item. If you have a smartphone, you can download the free app for each place and get the coupon right on your phone.
I do it all the time.
Pat Gagnon
crxmanpat is offline
Old 09-06-2013, 07:03 AM   #7
+1 on Testors...used it on my "newish" PZ Trojan.....that and black Sharpies (red and blue stay sticky for quite some time.
Old 09-06-2013, 07:45 AM   #8
View mclarkson's Gallery26
Friends: (8)
I use Testor's Model Master quite a bit. It's pricy but works well and is foam safe. I've used a color of theirs called "Racing Red" that is amazingly, eye-searingly bright.
Old 09-06-2013, 02:40 PM   #9
eagle33
eagle33's Avatar
Club: Dallas Electric Aircraft Flyers (DEAF)
Another good foam-safe spray paint is Krylon Short Cuts. A multitude of colors is available. Can also be bought at Hobby Lobby.
eagle33 is offline
Old 09-07-2013, 12:07 AM   #10
crxmanpat's Avatar
Friends: (27)
Something else you can use are water based acrylics like you can get at the craft stores and in the craft section at Wal-Mart. Usually a buck for a bottle and they go on well. I've used them on almost all of my depron builds for small details that can't be sprayed on.
Pat Gagnon
Old 09-07-2013, 04:20 AM   #11
dereckbc
OK guys here is a follow up. Things did not go as expected.
Bough ta can of Krylon Short Cut spray enamel because it was the only paint available in Day Glo Orange. Taped up the plane with tape and newspaper, cleaned the surface with Denatured Alcohol, and sprayed the plane.
First thing I noticed while spraying is the paint looked flat, verse glossy, and appeared to have a gritty texture. Let it dry and it feels like sand paper and the paint wipes of like a powder.
If I had to guess the paint dried before it hit the surface. Only thing Ican think of is it might be to warm to spray paint. Did it in the garage which was around 85 to 90 degrees.
Comment?
dereckbc is offline
Old 09-07-2013, 04:55 AM   #12
BroncoSquid
Workin on it...
BroncoSquid's Avatar
Club: Bill G fan club!
How far was the spray can from the plane while spraying? Possibly too far away? Possibly not shaken enough? Best guessessez.
I'm either going to get good at flying em, or get good at fixin em!
BroncoSquid is offline
Old 09-07-2013, 05:14 AM   #13
dereckbc
About 12 inches and shaken for 2 minutes.
Not sure what to do at this point. You cannot handle the plane without getting covered in powder like paint.
dereckbc is offline
Old 09-07-2013, 05:46 AM   #14
BroncoSquid
Workin on it...
12" sounds a little far. Find a piece of practice material, try spraying at 6-8" if there is too much build up, move the can faster.
Old 09-07-2013, 07:10 AM   #15
crxmanpat's Avatar
Friends: (27)
I'd wipe off the Short Cuts and get some water based acrylic at the craft store. They have the bright colors, and you can just brush it on.
And although I've never used Short Cuts, I'm not sure if that is a good paint to use. The only Krylon I've ever heard of being good for foam was H2O.
Pat Gagnon
Old 05-22-2016, 04:59 AM   #16
TommyC.
Default P51 foam safe silver touch up paint??
Hello, I am new to the forums, So I hope I put this question in the correct place...I am looking for a P51 silver touch up paint. I have whet to my local Lowes and they could not match this silver in water based Valspar sample paints. I just need something close to the original silver for wing tip scuffs and such...Any help would be greatly appreciated..
TommyC. is offline
Old 05-22-2016, 02:57 PM   #17
Porcia83
Friends: (4)
Bring part of the plane if you can with you to Joann Fabric or Michaels, both craft stores. Go to the pain aisle, look for the latex paint. The little tubes/containers start at .99 and they have every color possible, even glitter and metalic
Porcia83 is offline
Old 05-22-2016, 03:28 PM   #18
1kW
Friends: (7)
Maybe even a silver Sharpie marker. Everything blends at 200' agl. lol
I don't have a short temper. I just have a quick reaction to B.S.
Rob
Old 05-22-2016, 04:10 PM   #19
Friends: (19)
That's what I do ... take sample to the paint store and get them to mix up a tin for me. If its matt and I want gloss .... then I just overcoat with gloss lacquer or clear varnish.
Old 05-22-2016, 08:56 PM   #20
TommyC.
Thanks a million..
TommyC. is offline
Old 05-22-2016, 10:33 PM   #21
Mogg2112
Coming in hot!
Mogg2112's Avatar
Club: Gastineau Aeromodelers Society
Home Depot will also mix/match paint for you. I recently painted up my parkzone FW-190 wing tips and rudder to match the yellow on the underside of the cowling. I took the plastic cowl section into the store and they scanned/matched the shade of yellow with near 100% accuracy. The 8oz sample I got was like $3 and I still have over 90% of it left for additional coats/future touch ups. It's a water-based latex I think and perfectly safe for foam. Stuff is called Glidden Duo Tintable Tester paint.
Mogg2112 is offline
Old 05-22-2016, 10:36 PM   #22
TommyC.
Thanks.. I will try Home depot, sample paint is what I tried at Lowes but they couldn't match this silver.
TommyC. is offline
How to fix warps, dents, twists or uncrunch foam parts AEAJR Beginners 28 03-03-2016 06:36 PM
How to fix warps, dents, twists or uncrunch foam parts AEAJR Hi-Performance and Sailplanes 1 09-30-2013 02:12 AM
What type of paint is best on foam? RCFlyer44 Foamies 21 09-12-2013 05:40 AM
FINISHED! Airfield B-25 Paint Conversion to Navy PBJ-1 "Pacific Princess" mumblinaviator Warbird Electrics 74 04-12-2012 01:08 PM
spraying foam to make paint last longer? crshbandit Foamies 9 09-01-2011 04:23 PM
Page generated in 0.46170 seconds with 61 queries
