Old 09-11-2013, 12:19 AM   #1
jeff4912
Default Engine vibration after crash...replaced prop shaft.
Had minor nose in with Multiplex Mentor and bent the prop shaft so I replaced it. Went out to do a run up test on the prop and at 1/2 throttle, I get a heavy vibration that shakes the whole plane.
The prop is spinning true. When the prop stopped, I grabbed the spinner and was able to wiggle it up and down maybe a 1000 th of an inch. Should there be any slop in there?
I was thinking that maybe a bearing got damaged because I am starting to hear the beginnings of a grinding noise at certain points of the prop rotation when spinning it by hand.
New engine?
jeff4912 is offline
Old 09-11-2013, 01:34 AM   #2
gramps2361
gramps2361's Avatar
View gramps2361's Gallery9
Friends: (24)
Buy new bearings and replace em. If it is a good motor it is worth replacing them it can be a pain if you don't have a proper way of pressing them out. This place sells quality bearing and they have a chart for different motors to get the correct size. If you don't have a way of measuring the ID OD of the bearings.
http://www.bocabearings.com/bearing-...motor-bearings
gramps2361 is offline
Old 09-11-2013, 02:31 AM   #3
View CHELLIE's Gallery13
Friends: (327)
Check the Magnets to make sure they did not come loose, if they did, you can glue them back in with Epoxy or Med CA, make sure they dont get turned around, mark them with a felt pen on one side. also check the motor can, it could have gotten bent, if it is bent, time to get a new motor and save the magnets for canopy hold downs, Hope that helps, Chellie
Old 09-11-2013, 07:18 AM   #4
It could also be the actual bell and/or stator mount that is bent, this could case the stator to rub on the magnets which would explain the grinding noise. Check the motor and make sure that the bell/rotor part (the part that spins) is straight and true against the fixed part of the motor, check the gap between the back of the rotor and the fixed part and make sure it's the same width all round the motor.
The other points (bearings and magnets) are worth checking but bearings would not normally cause bad vibration unless the damage was extreme.
The other thing to check is the actual prop adapter, this is quite likely to have been bent in the crash.
JetPlaneFlyer is online now
Old 09-11-2013, 10:16 PM   #5
jeff4912
I think you are right now I have listened more to the noise. When plane crashed, the battery flew forward and struck the back of the motor.
I bet it bent the bell and caused the magnets to rub.
New engine ordered. I will used damaged one for spare if I can fix it.
jeff4912 is offline
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 5303 Today 08:36 PM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 04:05 AM
Shaft or bell mounted prop adapter? Unclebuck21228 Power Systems 10 09-08-2013 12:40 AM
Vibration Levels! (Why I fly Giant Electric Models) kyleservicetech General Electric Discussions 15 04-28-2012 03:46 AM
Champ prop shaft angle Jzone99 Beginners 4 08-06-2011 12:08 AM
Page generated in 0.07218 seconds with 27 queries
