Old 10-02-2013, 01:24 AM   #1
View mclarkson's Gallery26
Friends: (8)
Default Best use of 6-channel RX w/Flaps + Ailerons
I have almost no experience with planes with flaps, but my current build will have them.
I usually use the FLAPERON setup on my DX7, with dual ailerons which has me plugging one aileron into the AIL port, and one into the AUX/FLAP port.
This clearly won't work with actual flaps, but I like easy way it handles dual aileron servos.
I'm gonna have to stick some 'Y' connectors in there somewhere I fear.
I just thought I'd ask if there were any tips or recommendations from more experienced fliers.
Old 10-02-2013, 01:32 AM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Well you are are asking to do flaps and flaps. So you need to just do dual ailerons and separate flaps - NOT flaperons. Simple as that....
My DX7 skills are rusty but if nothing else it will support that you can setup a PMix that will do it. Still pretty easy!
Old 10-02-2013, 03:11 AM   #3
dangaras
Electric Flyer
You use a y cable for the ailerons and for the flaps a y-cable into the Aux1 port of the receiver.
You have to make sure the flap servos are facing the same direction and that the control arms are on the same side or the flaps will act like ailerons.
Then you need to set the flap settings in the model setup. Download the dx7 manual for details.
dangaras is offline
Old 10-02-2013, 05:47 AM   #4
Turner
Turner's Avatar
Have a look at my DX7 programs: http://www.wattflyer.com/forums/showthread.php?t=72022
There are five programs, all for flaps in my RGC blog. These programs are all for 7 channel Rx's. You can probably use some or all of them in some form but you'll need to put the flaps on a Y extension and you will only have two position flaps. If you forgo flaperons/spoilerons you can have 3 position flaps.
http://www.rcgroups.com/forums/member.php?u=282750
Turner is offline
Old 10-03-2013, 05:17 AM   #5
Friends: (8)
Thanks. I didn't want to get it all hooked up and then have somebody say, "What you should have done is put the flaps on your GEAR channel and then ..."
Old 10-04-2013, 01:41 AM   #6
Friends: (8)
You know, the more I think about my last post, the better it sounds. Except I'm gonna put one of the ailerons on the GEAR channel, and leave the flaps on the FLAP/AUX1 channel. That way, I minimize my 'Y' connections, and still get separate trim/etc. on the ailerons.
AIL->GEAR : +100% / +100%
I'm also setting my GEAR travel to 0%, JIC.
Old 10-04-2013, 03:25 AM   #7
Seveeral approaches depending on how you want to use flaps and ailerons...
You can continue with the "flaperon" setup of one channel per aileron and plug flaps into any other switched or dial operated channel.
This may or may not limit the flaps to being 2 position. Depending on the plane this could be just fine.
You can mix the flaperon fucntion to the flaps and the flaps function back to the ailerons for more effects. Some planes I like to have ailerons come up 2 to 5 deg as flaps come down. it can make a plane that likes to violently tip stall n approach very docile.
The wonderful power of modern computer radios. Play with it. Test your experimental configurations with plenty of altitude and be ready to flip switches to put the plane back to a known safe setup.
Old 10-04-2013, 04:03 AM   #8
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Not sure about your Dx7, but on my Dx8, if I wanted to do this I would have to disable my gear switch, or wierd things would happen. So if wierd things start happening when you try this, you may try that.
Old 10-04-2013, 04:36 AM   #9
Turner
Turner's Avatar
You have to put this mix in P-Mix 5 or P-Mix 6 to have the aileron trim follow to the slave.
And as xmech2k said disable the gear switch. Do this with another P-Mix.
Gear > Gear: -100% / -100%
Turner is offline
Old 10-04-2013, 04:37 AM   #10
Hard to say what to expect... Spektrum does not use the same programming priorities with their different level radios. What works with the DX8 may easily not work with the DX7.
I've gone through so many different programming systems that its hard to keep track of what works on which radio.
Old 10-04-2013, 11:19 AM   #11
Friends: (8)
It seems to be working...
I set the travel to 0%. That seems to work too.
Helping People Learn to Fly AEAJR General Electric Discussions 204 01-28-2016 05:20 AM
What does the 4th channel on a 4 channel add? jmr1068204 Beginners - Helis 6 11-12-2012 04:05 PM
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 01:57 PM
For Sale R600 6 channel rx cpmalish Radio Equipment For Sale & WTB 4 03-11-2011 03:29 PM
For Sale Rx crystals-Berg-Gws-Hitec $4 each gone2fly2 Radio Equipment For Sale & WTB 0 01-14-2011 05:30 AM
Page generated in 0.10078 seconds with 39 queries
