Old 10-21-2013, 06:08 AM   #1
DavidR8
Default Am I losing my mind?
I'm sitting here flying on my Phoenix4 sim with the provided DX5e TX.
I'm flying the Hobbyzone Super Cub, 3 channels.
I have the display set so I can see the controller on screen.
All trims are centred. All servos are set to normal (as in not reversed)
Standing behind the plane if I move the right stick to the left, the plane's rudder angles off to the right. Is this correct for a three channel plane?
I ask because the stick in on-screen controller display moves to the right, the opposite direction to the actual stick on the controller.
I cannot figure out how to make the direction of the two stick movements match...
Flying more, crashing less. Feels great!
Champ, Super Cub, Fun Cub
DavidR8 is offline
Old 10-21-2013, 06:23 AM   #2
View CHELLIE's Gallery13
Friends: (327)
maybe you need to reverse the rudder control on your Transmitter
Old 10-21-2013, 06:42 AM   #3
DavidR8
Default Tried that
Reversing the servos works for the elevator and throttle but has no effect on the rudder.
I'm not wrong crazy tho am I? With the plane heading away, stick to the right, rudder angles to the right, plane turns right.
If that is correct, it's no blessed wonder I'm so disoriented when I fly in the real world, I'm used to the controls being reversed...
DavidR8 is offline
Old 10-21-2013, 06:42 AM   #4
Yup, FYI, your rudder is backwards. If you move your transmitters "Rudder" stick on a three channel rudder/elevator/throttle transmitter to the "Left", then the rear most part of your rudder must also move to the "Left". That would cause the digital model to bank to the left for a left turn.
Old 10-21-2013, 07:00 AM   #5
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
The supercub's rudder may be set to the aileron channel. Try reversing that. It's a popular thing to do on 3 channel planes so your primary turning control will still be the right hand stick, even though it's the rudder.
Old 10-21-2013, 07:02 AM   #6
DavidR8
Default Hooray!
I'm not crazy!!! Thanks Denny and Chellie
I figured out how to reverse the rudder in three channel model in Phoenix as well.
I held the right stick all the way left and then moved the servo reversing switch into reverse mode. The stick in the onscreen display immediately changed sides. I let the stick centre and then switched the servo back to normal.
Presto, fixed. Just did a few laps and wow, that makes a heck of a lot more sense.
I've probably put in 100 hrs on the sim with the rudder working the wrong way and less than 30 mins in the real world with it working right. No wonder my reactions in the real world get me into trouble so much.
Crickey, and here I thought I was some kind of idjit...
DavidR8 is offline
Old 10-21-2013, 08:08 AM   #7
Friends: (19)
Forgive me for saying this .... but that sounds very strange ...
It sounds like you may have uncovered a hidden way to affect Phoenix settings ? Many programs have back-door tweaks that are hidden ...
Does Phoenix not have a Calibration and Mapping routine where sticks / buttons etc. are calibrated / set-up so Tx and screen / sim model are in co-ordination ?
Old 10-21-2013, 08:57 AM   #8
DavidR8
Default That's what I did
There is a full calibration process which I did countless times prior to what eventually worked, I also tried every TX calibration setting I could find. I assigned the rudder to each of the four channels in the DX5 and at no time would the actual stick move in the same direction as the on-screen stick. I could reverse the throttle and elevator on the TX and on-screen without issue.
So the onscreen stick was moving correctly as was the rudder but the actual TX was the opposite; I'd push left the rudder would go right as would the onscreen stick.
As soon as I figured out how to change it, my sim flying improved 100%. Before, nine of ten times I'd push the wrong way, see the response and then correct. So I had to not only figure out right or left from the plane's perspective then I had to push the stick in the opposite direction which was completely counter-intuitive
DavidR8 is offline
Old 10-21-2013, 04:25 PM   #9
maxflyer
maxflyer's Avatar
It helps to think of yourself as being in the cockpit instead of standing on the ground trying to think in reverse as an aircraft is coming towards you.
maxflyer is offline
Old 10-21-2013, 06:29 PM   #10
DavidR8
Default That is my approach
I do try to imagine I'm in the plane. If I'm flying flat and level, I need to bank right to make a right turn. If the plane only has rudder and elevator control I would move the stick to the right.
On my sim it was the opposite: in the above scenario I had to push the stick to the left to bank to the right.
This caused me to set up a mental model that had me pushing the stick toward the wing that I wanted to rise as compared to in the direction I wanted to bank. Having the sim reversed didn't help develop any kind of 'memory' for the correct movements.
Like I said, because I have so much more sim time than actual flying time this was was really causing me grief when I tried to actually fly.
DavidR8 is offline
Old 10-24-2013, 04:29 AM   #11
DavidR8
Talking Hurray!!!!!
My new Castle Creations Talon ESC should be here on Friday. That is at least according to the package tracking info.
DavidR8 is offline
Old 10-24-2013, 04:31 AM   #12
If CC is still doing it, they have been offering a free USB programming dongle coupon enclosed in the box with your new ESC. This will allow you to program your ESC quickly, and also allow access to the ESC's data recording features.
Old 10-27-2013, 12:16 AM   #13
DavidR8
I put my Cub back together today. I have to say that the Castle Creation ESC is a nice piece of work, very nicely put together. I'll be sending off for the programming card.
Sent from my iPhone using Tapatalk - now Free
DavidR8 is offline
Losing my confidence in Spektrum e-pilot RC Radios, Transmitters, Receivers, Servos, gyros 77 05-10-2012 05:09 PM
Playing with my mind dumo01 Power Systems 1 10-29-2011 02:05 AM
F2 B Brisfit Mind Blower! cocobear WWI Era 9 10-07-2011 03:09 AM
TORKS is losing field. HELP!! Hernthehunter Off Topic Chit Chat 26 10-07-2011 03:03 AM
Buzzfly 3D losing power? lee84 Beginners - Helis 15 07-03-2011 03:51 PM
Page generated in 0.09809 seconds with 43 queries
