Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Sport Planes (Formerly I/C & Gas Conversion)
Old 10-24-2013, 03:42 AM   #1
Default Canopy Mounting Method
I've got four flights on my new Redwing model. But the canopy installation is a pain in the , since the canopy has to be removed for charging the batteries.
So, an alternative mounting was devised. The attached JPG shows how it was done. I happen to have a lathe for making the fuselage fittings, but this could be done with a drill press and a bit of work. The system consists of removing the two blind nuts that were on the canopy "Pegs" and drilling out the holes for clearance of a piece of 3/16 outside diameter aluminum tubing. The aluminum tubing was epoxied into the two canopy pegs.
Then a trip to the local hardware store for a piece of 1/8 inch diameter brass rod. One end of the brass rod was threaded with 6-32 threads, the other end was fitted with a little aluminum button for manually screwing the assembly in place. First used was a piece of 6-32 threaded rod, but it made a LOT of grinding noise while the the threaded rod was pushed down the inside of the aluminum tube.
Several club members indicated this would not work for a gasser model, since the brass rod could vibrate out during flight. So, one club member modified the design for his gasser with a very small hole in place of the threaded end. Next, a very small spring clip was used to secure it in place.
Now, just unscrew the single piece of brass rod, takes a few seconds and the canopy is free. And re-installing the canopy is just as fast, with the aluminum tube guiding the way.
Might replace the brass rod with a piece of 1/8 inch diameter aluminum rod from a local metal supply house some time.
Take a look a the attached photos to see how it worked out.
Name:	Canopy Tube and Rod - WF.jpg
ID:	171630   Click image for larger version
Name:	Canopy Rod and Fuselage - WF.jpg
Old 10-24-2013, 04:35 AM   #2
View CHELLIE's Gallery13
Friends: (326)
Nice Job Denny
Old 10-24-2013, 05:32 AM   #3
Nice Job Denny
Thanks Chellie
It's appreciated
Old 10-24-2013, 06:29 AM   #4
Friends: (18)
I have to say that magnets and similar aree often a dead loss on many of my models ... and I resort to blind nuts / hold down bolts ... pins and latches.
Adding a block to carry a blind nut or latch is my usual modification.
Neat Denny ...
Old 10-24-2013, 06:35 AM   #5
Neat Denny ...
Yeah
I've got a Hanger 9 Kantana model that uses magnets. How this works is the canopy is slid forward, so two "Hooks or Catches" can engage the fuselage. Than the canopy is slid backwards against the magnets. No way this can come loose, it's worked very well.
To bad the Kantana is no longer available, it is a very good midsized model.
http://www.horizonhobby.com/products...-46-55-HAN4170
Old 10-24-2013, 07:05 AM   #6
Friends: (18)
If I stay with magnets ... I usually add an extra couple to get it to really stay down ...
Good source of magnets - old motors !!
My 'quickie' canopy method for non-scale stuff is the rubber bands and cocktail sticks ... might look a bit heath-robinish close up - but in the air you never see it. Makes for easy quick access.
Old 10-24-2013, 07:58 AM   #7
hayofstacks
hayofstacks's Avatar
I pretty much always just put a single rubber band around the nose of my mini ultra stick, just incase the.battery comes loose or the hatch fails.
no modification necessary :p.
slow stock prop reversal. it flies! easily! 543 watt dual motor bipe slow stick. push-me-pull-you. 242 watt 3 channel slow stick. 365 watt mini ultra stick. 415 watt mini contender. 810 watt ultra stick .25e. 220 watt alpha 450 sport (retired).
hayofstacks is offline
Old 10-24-2013, 12:23 PM   #8
Friends: (18)
If you pass 2 BBQ skewers all way through fuselage, just below rim of hatchway .. harden area with epoxy, small plastic plates on inside or similar so they don't pull through ...cut of ends suitable to put a couple of office style rubber bands to ... easier than all way round nose band ...
I actually use 2 bands ... sometimes 3 ...
Best Canopy Glue ? CHELLIE Scratch and Kit Built Aircraft 15 10-14-2013 02:21 PM
Painting a stock mCX2 canopy - will it work? calldaffer E-Flite Helicopters 5 04-04-2011 05:25 PM
Eflite t-34 mentor canopy fly off during flight Flysohigh General Electric Discussions 8 03-02-2011 03:26 PM
For Sale Canopy Lock IFlyTailies Field Equipment For Sale & WTB 0 02-22-2011 03:51 AM
Anyone made a duplicate canopy of an original plastic canopy? 4stripes Scratch and Kit Built Aircraft 10 12-14-2010 11:42 PM
Page generated in 0.21003 seconds with 37 queries
