| ParkFlyers Talk about all backyard and parkflyer aircraft here |
#26 | ||
Guest
Posts: n/a
Originally Posted by vax6335
It won't have the integrity of a solid one piece boom.
The break is forth of the tail wheel bracket, so hard tail first landings will make it "snap". It is something those who hit brickwalls and light poles with their Slow Sticks won't have to worry about. One alternative would be to get a "spare" boom from one of the places that sells parts for the GWS Slow Stick and keep the new one for "modified" versions of the model.
#27 | ||
Guest
Posts: n/a
Originally Posted by bsoder
Nope.
I am giving my opinion based on the photos and comments posted by the thread originator here. I trust the only screw up is just the split boom. Bad enough that it is ahead of the tail wheel bracket, where the boom is at its weakest point. That plastic joiner won't survive more than a few hard landings. :o |
#28 | ||
Turn the fuse around, use a 4" piece of hardwood to join the sections with epoxy, done. A little more work, tho.
I wish it was one piece as well. I haven't gotten one of the new kits yet, so I'll reserve judgement on the rest of it.
#29 | ||
Guest
Posts: n/a
Unfortunately flipping the boom around will bring the "break" near where the main landing gear bracket goes. It would be too close to the motor and its torque as well. :o
One hard "nose first" landing will snap it rather quickly, even if one used a carbon fiber rod to reinforce the boom's joint. :o I just got me an older version Slow Stick from a fellow flyer for $25. Complete including its EPS-300 power plant.
#30 | ||
I use a piece of hardwood to mount my motors in all my planes - shaved down to 9mm x 9mm to fit inside a piece of slowstick fuselage. I've hit nose first into a few things - lightpole, wall, ground
and never broken the stick. I've bent my slowstick fuse a number of times but never broken the stick. I think you'd end up with a bend at each end of the stick before you broke it.
#31 | ||
Guest
Posts: n/a
On a solid one you'll end up with a "shock forced downthrust" bend. On an already pre-cut aluminum tube you'll break the wood and the joiner. :o
At any rate I just got me one of the older ones, and will expand my search for some more of them.
#32 | ||
why don't you just by an oak rectangular dowel for $1.39 at the hardware store? it will last longer than the aluminum stick-----won't bend and can handle a nose dive
#33 | ||
Pete O'Connor
Ask the old guy how to fly the plane....... He's still alive!!
#34 | ||
Guest
Posts: n/a
#35 | ||
I got a replacement fuselage today along with a repalcement rudder and stab. The fuse is in one piece and the tail feathers are the old, thin type.
#36 | ||
Guest
Posts: n/a
Originally Posted by Doc Pete
I can get a combo including the Tower Pro 2410-12 motor (or the 2408-21) and 15A ESC for $37 plus $5 shipping from Wisconsin at: www.rcepower.com
#37 | ||
and I usually throw in freebies....thanks Q
#38 | ||
Friends: (63)
#39 | ||
Just call me ... Bill
Truthfully, and to parphrase Shakespeare, all the hoopla about the split fuse is much a do about nothing.
I cut my first SS where GWS told me to and it survived a whole lot. What finally did it in was my horse stepping on it when it landed it in his paddock after I knocked it down from a tree. If it is that critical, a 2" piece of square stock inserted as a splice will make it sturdier. My $.02 |
#40 | ||
Bad Influence
I noticed that HL is starting to carry 8mm square carbon fiber tube, too bad they don't offer it in a 2mm larger size.
Maybe the 8mm tube with some 1mm thick flats to put in the supports! If I ever need to replace my SS I figured on ordering an extra tube and having them toss it in the box to save on shipping just in case (shipping on the tube is as much as the tube itself. What do you bet the replacement tubes aren't cut!
#41 | ||
Guest
Posts: n/a
Yes, it is extremely important for the boom to be rigid. :o
I have no clue if the people linked below are related to GWS, their name certainly leads me to believe so. They sell a replacement boom for the model. An additional $3.50 would get the problem solved. ![]() http://www.gwsexpert.com/product_inf...roducts_id=563 |
#42 | ||
Bad Influence
Originally Posted by qban_flyer
They always ship kits inside another box (my SS and Formosa both came in the same sized box) so getting an extra boom no matter which kit shouldn't be a problem.
And they're always quick to answer questions during business hours. |
#43 | ||
Club: Arizona WingNutz
Friends: (24)
One of the LHS' here had 8 spare one-piece fuses on hand. I bought two of them, and a buddy bought 5. I told the manager about the new SS kits. He said he would try to order more spare fuses (they were $4 apiece). I will find out if he is able to order more replacements, or if they will now only be available in the 2 piece version.
#44 | ||
Bad Influence
I would think that spares would still be one peice simply because they probably already have a million of them in a warehouse in China and the fact that no matter how you slice up a 10mm x 37" square tube it'll take up the same amount of space.
BTW I just checked, they have the "New Improved Packaging" for theire SS's at GWSExpert. ![]()
#45 | ||
Guest
Posts: n/a
There is a LHS I haven't contacted yet. I shall do so tomorrow morning. If they have spare booms I'll drive up to them and get me a couple. Just in case!
#46 | ||
Guest
Posts: n/a
There goes the neighborhood for sure! Where the parts are shown the pre-cut boom is visible below the wing. ![]() I like the thicker tail feathers, though. So while they improved one thing they've managed to screw up another. And they even brag about it! What gives Mr. Lin?
Originally Posted by ForestCam
#47 | ||
Bad Influence
Well I just checked and for me the breakdown is this
SS Sloper, $12.80 USPS Priority $11.88 UPS Ground SS Sloper + 1 boom $12.92 USPS PRiority $12.25 UPS Ground SS Sloper + 2 booms $14.80 USPS Priority $12.72 UPS Ground SS Sloper + 3 booms $16.60 USPS Priority $13.45 UPS Ground That second and third boom must be really heavy.
#48 | ||
Friends: (24)
Q ban,
I checked a few sources, and lots are still available. The link above (GWS Expert) has 7 on hand, ALLeRC (www.allerc.com) has 25 (and are the cheapest at $3.38). I'd say order as many as you can afford, and then corner the market on spares. :p |
#49 | ||
Guest
Posts: n/a
Originally Posted by crxmanpat
I'll do that!
I'll have to rename myself the "Slow Stick Boom Hoarder", though.
| slow stick with gws floats | money-pit | Seaplanes E-Powered | 14 | 01-10-2009 07:13 PM |
| GWS Slow Stick | Gauge | ParkFlyers | 44 | 05-10-2008 09:04 PM |
| GWS Slow Stick - WTB | BatteriesIncluded | Airplanes - Electric For Sale & WTB | 6 | 03-07-2007 01:30 PM |
| Gws Slow-Stick??? | Blake123 | ParkFlyers | 34 | 06-08-2006 12:17 AM |
| GWS Slow Stick Question??? | rtmiller | ParkFlyers | 54 | 11-11-2005 12:34 AM |
