| ParkFlyers Talk about all backyard and parkflyer aircraft here |
#51 | ||
Guest
Posts: n/a
Originally Posted by ForestCam
It sure looks that way.
Who are you ordering from?
#52 | ||
Bad Influence
GWS Expert
Used to use ALLERC but their standard shipping (UPS which ALWAYS takes 5 days including 48 hour layover in Chicago for some reason ) was as much as GWSE's priority mail which I've gotten as quickly as two days, three at the most.
#53 | ||
Guest
Posts: n/a
Thanks!
If I don't find the "booms" locally, I will have to place an order with them.
#54 | ||
Friends: (11)
I ordered three SS slopers, some props, and other stuff from ALLERC last month, and the shipping was only $5.95 for all of it through UPS.
#56 | ||
Club: Arizona WingNutz
Friends: (24)
#58 | ||
Friends: (11)
Not having to pay sales tax is why I order from ALLERC and not Calif. based company's. Along with the great service I get from them of course. I have to pay enough in sales, income, and property taxes as it is. I avoid paying any more taxes any chance I get.
#59 | ||
Hal Marshall
The SS has been one of my favorite all around planes. As for the 'new' version, well, I really don't care if the box has a handle on it or not, because it'll go into the trash once I unpack it. I do like the idea of thicker feathers, but the old ones work okay and never had a problem repairing or replacing them if needed. As for the split stick, personally I prefer mine as one piece, and with the wing off its never been a problem transporting it.
Frankly, for me the biggest improvement to the stock kit was accomplished when they redesigned the motor mount and switched to the EPS400. Much better than the previous flimsy underpowered affair! My current setup is a bit different than most. The electronics are from a doomed Parkzone Stryker, including servos'. The prop is a 10x8 from the Parkzone P-51, and batteries are the 8.4v 600mah used in the Parkzone Slow-V. I typically get about 15 or more minutes of flight time, and if the wind is just right, it'll hover straight and level into the wind for as long as you can stand to tweak the stick and power. It has close to 100 flights and still flies great! |
#60 | ||
"Bigster" on RCG
I notice allerc also has the "GWS SLOW STICK AS-1 PARTS KIT" for $5 which includes the fuse. Might be worth the add'l buck and a half.
#61 | ||
Does this 8mm square carbon fiber tube fit inside the 10 mm alluminium tubing. If so then make a CF fuselage and place small pieces of alluminium tubing over the CF at the front for motor mounting and at the mounting points for the wing and RC equipment carriers. A drop of super glue will hold the alluminium tubing in position.
Ken |
#62 | ||
Bad Influence
Originally Posted by kensp
Why bother? They have 1mm x 4mm flat to make up the size difference where you need it and I'm likeing the idea of a CF SS more and more, especially since it'll only cost about $15 to do.
#63 | ||
How much havoc will a CF frame cause with your radio reception, I wonder...
#64 | ||
Guest
Posts: n/a
#65 | ||
The fuse on my SS broke long ago, a quick trip to the local Home Depot for a 3/8 square stick for a $1 and some change fixed it right up plus I added a little length to accomodate a CVS camcorder
.I wouldnt worry about the new fuse because everybody loves to modify anyway.
#66 | ||
Guest
Posts: n/a
Hi,
Which department at Home Depot did you find the 3/8" aluminum stock at? I was there this morning and could not find it. :o
Originally Posted by nstaller
#68 | ||
Guest
Posts: n/a
#69 | ||
Sorry about that it was birch. It was with the dowels
#70 | ||
Guest
Posts: n/a
No problem.
I'll take a look at them when I go back there on Friday.
#71 | ||
#73 | ||
I have been reading this thread with interest. There seems to be a number of people who believe that because the new Slow Stick fuselage has a join in it must be weak. None of these people appear to have built or flown the new model.
A join does not necessarily have to be weak. Over the last 40 years my friends and I have built and flown many large span Sailplanes with either one or two joins in the wings. Wing structures have to far more stress on them than tail booms do but none of these large span sailplanes has a problem with the join being weak. So how can you criticize the 2-piece Slow Stick fuselage without building and flying it? Here is a photo of the durability testing team for the New Slow Stick. Ken |
#74 | ||
Friends: (63)
Ken, I think it is yet to be determined whether it's a bad thing or not but why mess with something that works so well? Remember when Coca-Cola came out with New Coke?
![]() What I'm wondering is in the photo it appears 4 of the 6 that I can see have the one piece fuse, the connector to put it together is longer that the push rod holder that is on them. Another has a black fuse. Has it had to be replaced? If this is the product testing team why would they not replace it with a stock fuse??? I'm not knocking or bashing... just curious |
#75 | ||
Guest
Posts: n/a
I speak from experience Ken.
Two of the guys I help out followed the original Slow Stick instructions (photos) to the letter and had their booms "cut" as suggested. The result is a weakened tail end on these two particular ones. They are not rigid and there is a fair amount of "play". One of them has inserted a dowel in his in order to reduce the problem. This fact is what I have based my opinion of the "new and improved" version of the Slow Stick on. I have no axe to grind as I have always been an avid advocate of the Slow Stick, but I will point out shortcomings on anything when I see them first hand. The split boom is not an advantage, it is a shortcoming. |
| slow stick with gws floats | money-pit | Seaplanes E-Powered | 14 | 01-10-2009 07:13 PM |
| GWS Slow Stick | Gauge | ParkFlyers | 44 | 05-10-2008 09:04 PM |
| GWS Slow Stick - WTB | BatteriesIncluded | Airplanes - Electric For Sale & WTB | 6 | 03-07-2007 01:30 PM |
| Gws Slow-Stick??? | Blake123 | ParkFlyers | 34 | 06-08-2006 12:17 AM |
| GWS Slow Stick Question??? | rtmiller | ParkFlyers | 54 | 11-11-2005 12:34 AM |
