Old 10-28-2013, 02:48 AM   #1
View CHELLIE's Gallery13
Friends: (304)
Build Review Help Finding CG on a F-20
Hi Everyone Know what, Tapered wings have always thrown me for a loop trying to find the CG, i have used CG calculators before, only to have the CG way off and tail heavy, I Dont know if its me not using them right, or the CG calculators not being correct here is what I have. I am looking for a 25% MAC, Thank You In Advance, Chellie
http://adamone.rchomepage.com/cg_calc.htm
Main Wing
Wing Root Cord (A) 16"
Wing Tip Cord (B) 5"
Wing Sweep Distance (S) 11"
Wing Half Span (Y) 16.75"
Stabilizer
Stab Root Cord (AA) 8.75"
Stab Tip Cord (BB) 3"
Stab Sweep Distance (SS) 5.75"
Stab Half Span (YY) 10"
Distance from Both Leading edges (D) 20.50"
I Entered a Static margin of 15%
I am thinking that Maybe 6" Back from the LE will give me approx 25% Root Cord / MAC from the LE, But I am not Sure
Old 10-28-2013, 03:02 AM   #2
earthsciteach
Hey, Chellie. The F-20 is pretty much a modified delta wing with a tail, right? As a SWAG, find the centroid of the wing planform. It should be a bit back from 1/3 the distance from the trailing edge forward to the vertex of the triangle that is the wing.
Look at that point as the center of lift. The cog should be forward of that by a couple of % of chord. If I am babbling, let me know and I'll try to do a better job of explaining.
earthsciteach is offline
Old 10-28-2013, 03:11 AM   #3
Friends: (304)
Hi I get what your saying My Plane also has a Flat bottom, that I am trying to take into consideration, that why a 25% mac or 25% back from the leading edge, to make it a tad nose heavy, better a little nose heavy than tail heavy but like i said before, tapered wings throw me for a loop big time
Old 10-28-2013, 03:14 AM   #4
DEG
AMA 16634
DEG's Avatar
Friends: (8)
Main Wing
Stabilizer
I am thinking that Maybe 6" Back from the LE will give me approx 25% Root Cord from the LE, But I am not Sure
Actually closer to 7" back from LE of wing root. (6.86" according to the calc you listed) At 6" you'll be close to 22% static margin (a little high according to your link). You'll know when it gets in the air.....
DEG is offline
Old 10-28-2013, 04:20 AM   #5
flying wing/delta starting CG is 15% MAC.
but the F-20 isn't even close to a flying wing.
Count the area of the fuselage from TE of the wing forward to the intakes for the engines as part of the wing. The fuselage of the F-20 contributes to the aircraft's lifting surface. If you don't include that block of area forward of the wings a part of the lifting surface the CG will be too far back using the normal 30% MAC for a conventional aircraft design.
This is potentially going to push the CG almost up to where the wing LE meets the fuselage.
Make a smaller "chuck glider" (overhead and profile view flat plates) and test the CG. Apply about 3 deg of up elevator. Where that glides passably will be acceptable for test flying the RC model.
fhhuber is online now
Old 10-28-2013, 04:57 AM   #6
Friends: (304)
Great idea I think a profile test glider will keep me safe, Thank You, Chellie
Old 10-28-2013, 05:05 AM   #7
Friends: (304)
This pic might give me a little idea of to where the CG should be at or close to it.
http://www.rcuniverse.com/forum/elec...igershark.html
Old 10-28-2013, 02:42 PM   #8
pmullen503
Main Wing.............
That particular calculator ALWAYS results in a pitch sensitive CG in my experience. I would start with 25% MAC as the most rearward CG, maybe 20% for the maiden unless the WL is very high. "Nose heavy flies poorly, tail heavy flies once!"
Great looking model BTW.
pmullen503 is offline
Old 10-28-2013, 10:51 PM   #9
Friends: (304)
Thank you for the reply, Thats what i kind of figured that the Calculator is not correct, and giving me a tail heavy plane, I think i might have to make a chuck glider and see where the cg needs to be at, Take care, Chellie
Old 11-19-2013, 03:33 PM   #10
nuteman
fhhuber is right. Those CG calculators are really good for fairly "conventional" designs, but as soon as you add in funky factors (like parts of the fuselage that act as lifting bodies, "wake interference" from canards that are "too" close to the main wing, conventional tailplane that is "too" close to main wing so that it gets the main wing's "wake", etc.) they can be wildly inaccurate. I've done a couple of scratch builds that were considerably off the beaten path and the only way I could get the CG right was through trial and error - the CG calculator was just plain misleading.
nuteman is offline
Old 11-19-2013, 03:48 PM   #11
Friends: (8)
That is one smart F20 !!
Old 11-19-2013, 04:03 PM   #12
Friends: (8)
My calc gives safe recc'd as 7.63" and max rearward as 8.23" back from LE joint to fuselage ...
But to be honest - I don't trust many of these calcs !!
Old 11-19-2013, 07:33 PM   #13
The calc is only as good as the info its given.
When the fuselage becomes a significant contributor of lift then you have to figure out what portion of the fuselage to put into the equations. Most CG calculator can't deal with the strange shapes and you can do better by drawing the top view on graph paper and counting squares to get the correct proportion of squares ahead of CG vs total squares for the style of wing and stabilizers.
Old 11-19-2013, 07:47 PM   #14
Friends: (8)
Very true ... when I rebuilt the smashed up F16 pal gave me - imagine the trouble getting that CoG with such a lifting body.
But amazingly the calc I used was not far out. So I used the same one here.
I can't upload it here as it's a spreadsheet and the PC I'm on is a crappy Win8 Company job.
For Sale 20 Pair "T" Type Deans Connectors - $15.00 Shipped within CONUS ABADGTP Airplanes - Electric For Sale & WTB 0 01-02-2013 12:45 AM
Wanted Spare Part Logo 20 Swashplate 90dec. Sir John Helicopters- Electric For Sale & WTB 0 04-10-2011 06:44 PM
E/xpo in the UNI Dome - Feb 19 & 20, 2011 - Cedar Falls, IA rnleeper Events, Shows and Fun Fly's - Electric Airplanes 5 01-21-2011 12:33 AM
Desert Storm - 20 Years - Were you there too? franklin_m Off Topic Chit Chat 6 01-17-2011 08:01 PM
snark 20 Buckwheat Beginners 4 01-09-2011 01:55 AM
Page generated in 0.23113 seconds with 45 queries
