Old 11-12-2013, 10:29 PM   #1
Karnsy
Default Spektrum DX6i Throttle Cut Switch
Did not see this thread for planes. Has anyone swapped the throttle cut button for a switch on the dx6i ? Any issues ? I think I will do it when the warrantee runs out.
Karnsy is offline
Old 11-13-2013, 01:44 AM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Interesting idea. Never thought of it, but now i'm on the 8, and the 6i is relegated to sim and trainee duties.
Also, I thought the warranty never runs out on Spektrums!
Old 11-13-2013, 04:27 AM   #3
cc83
I've done it. It works very well. I handed the radio down to my dad or I'd post photos but it's pretty simple.
cc83 is offline
Old 11-13-2013, 05:31 AM   #4
Not familiar with the DX6i and its throttle cut switch.
As for me, I've programmed the gear switch as a throttle cut function on my DX8, and did the same with my DX7. It's a lot more work with the DX7.
With the larger models, that throttle cut switch is almost a requirement for safety's sake.
Old 10-05-2014, 07:55 PM   #5
Freeair
Anyone have a link to install on the throttle cut switch on the dx6i ?
Freeair is offline
Old 10-05-2014, 09:19 PM   #6
Karnsy
Default Try This
https://www.youtube.com/watch?v=CVcZLKTm6UI
Karnsy is offline
Old 10-05-2014, 09:39 PM   #7
Freeair
Karnsy
Freeair is offline
Old 10-12-2014, 01:45 AM   #8
c.sitas
I don't have a spectrum, I have a flysky. All I had to do was tell my throttle which switch I used and away we go . I really like this feature because it's like walking around with the safety on for a gun . I also use it If I know for sure I'm coming DOWN. I'll flip it off at the last second. It saves motors that way.
c.sitas is offline
Old 10-12-2014, 04:57 PM   #9
That's nice, but Spektrum's throttle comprehension works a little different and it's not advisable to walk around with a gun in hand (most states here in the U.S.), safety engaged or otherwise.........
Old 10-13-2014, 02:35 AM   #10
I'm using the throttle cut off function on my Spekie DX8. But, the battery is plugged in right at the steel fence for the pit area inside in the flight line. Then the DX8 switch is flipped to power up the ESC and Hacker A60 motor when it is time to take off. An accidental start up of a 3000 watt motor with its 19X12 prop would not be good.
Old 10-14-2014, 04:50 PM   #11
Abuelo
Abuelo's Avatar
Club: Open flying at the Chandler Bowl
Made the mod last night, photos attached.
No issues, 15 minutes, and exactly as the video spelled out. The blade toggle switch came from Radio Shack, #275 0634 and under $4, and matches the existing switches. Uses a hex nut instead of the round stock ones, but the visual difference is minimal.
Thanks for doing the research, credit given, and posting the how-to.
Name:	Toggle Switch.JPG
ID:	177898   Click image for larger version
Name:	Toggle Switch Throttle Cut.JPG
Science has proven that six out of seven dwarves are not Happy.
Abuelo is offline
Old 10-14-2014, 05:36 PM   #12
raming
Ramin G
Club: HCAM Austin
Default Potential Glitch with Throttle Cut Switch Mod on DX6i
There are several people including me that have found that the Throttle Subtrim on some models need to be adjusted after the Switch Modification. It appears to be a function of the ESC (Speed Control) Setup. For example, on my ElectroStik, the motor runs at Throttle idle and I changed the throttle sub trim to -63 to move the trottle idle down. In addition, the Great Planes 45A Brushless ESC has a 'Throttle Cycle Arming' feature that will only be enabled by cycling both the throttle stick and the Throttle Cut Switch.
This switch modification worked without throttle idle sub trim adjustments on my Parkzone T28 (with HobbyKing ESC), my Eflite AS3X P51, and my 1/5th Scale J-3 Cub (using HobbyKing Blue Series 60A ESC)
Trust, but Verify!
raming is offline
Old 10-14-2014, 06:23 PM   #13
Club: CVMRCC, SEFSD
Good job on the upgrade, Abuelo. Thanks for sharing it.
Probably what you're mentioning, raming, is similar to what you have to deal with on the throttle cut for the Dx7s, 8, and the new series Dx6, 9, and 18. Watch the monitor screen. By default, throttle stick idle is -100%. With the new tx's, throttle cut default is -130%. Some ESC's will 're-learn' that -130% as it's idle position, so when you turn off the throttle cut, the throttle signal goes to -100% and suddenly your motor is running even though your throttle stick is at idle. I sold my 6i and I don't remember if you can adjust the throttle cut servo setting in it, but perhaps you may want to look into it and set it to -100% if possible to avoid nasty surprises.
Old 10-29-2014, 07:46 PM   #14
Abuelo
Abuelo's Avatar
Might add that with the Spectrum 6i transmitter you need to activate the throttle cutoff for this to work. For each of model, go to the setup menu, item 5 and change the setting from INH to ACT.
Abuelo is offline
Safety First BaronBernie Beginners 31 04-05-2013 10:11 PM
RX Switch Question paxskipper Beginners 27 02-25-2012 10:21 AM
Turn on TX or RX first paxskipper General Electric Discussions 20 01-28-2012 10:29 PM
Modification of throttle cut switch DX6i cjg Micro Sized Electric Helicopters 0 01-09-2012 11:25 PM
One of those days.... wolfewinde General Electric Discussions 35 10-25-2011 12:02 AM
Page generated in 0.53539 seconds with 49 queries
