Old 11-16-2013, 08:57 AM   #1
Friends: (18)
Default Forced air cooling
Ok - who thinks I'm bored ?
I'm sitting here with a barge playing games and making my work a pain !! And thinking ... my EDF's usually run too hot - the batterys / ESC's that is.
So I'm thinking to myself is there any way to increase cooling ? I've added cheat holes ... placed ESC in the ducts etc.
So here's the question :
Has anyone ever taken a PC processor fan and installed to force air into the battery / ESC area ? Small, low power ... a 2nd uBEC could supply the small amount needed ? This is on any type pf model - not just EDF or Pushers ... I have prop planes that are hard on batts / ESC's as well.
I know ... daft sod !!
But maybe not so daft an idea ?
Old 11-16-2013, 09:28 AM   #2
Wrench66
Ya' need to use mo rudda!
Wrench66's Avatar
View Wrench66's Gallery33
Club: Chino Renegades RC Flier's
Scratchbuilders Award
Friends: (20)
Leave those ducted fans to the maniacally rich, Nigel......for the electrons wasted as heat in the batts, motors and esc's you could be flying two more prop planes!
God those hair dryers are hard on everything, including the wallet...LOL. I like jets but I just run a little prop on the rear and enjoy
Just sayin'
--Ray
Man, gravity is ALWAYS wanting something from me
Wrench66 is offline
Old 11-16-2013, 09:43 AM   #3
Friends: (18)
True Wrench66 ... but I'm actually asking in terms of any model .. I have prop jobs that run hard on LiPo's / ESC as well....
Maybe I should have made that more clear ... I'll go back and amend OP.
Old 11-16-2013, 11:23 AM   #4
There have been some who have successfully used fans to cool the ESCs and/or batteries.
I heard of one case where a LARGE prop plane used a small EDF as its fan for cooling the ESC and batteries.
Another option is to create a bypass duct to bleed air from the EDF to do the cooling.
Then there's the option of using air scoops.
Lots of options...
Old 11-16-2013, 11:28 AM   #5
View CHELLIE's Gallery13
Friends: (326)
http://www.rcplanet.com/Traxxas_Cool..._p/tra3340.htm
http://www.amainhobbies.com/product_...PM-Cooling-Fan
Old 11-16-2013, 11:31 AM   #6
Friends: (326)
ron_van_sommeren
homo ludens modelisticus
Club: www.rmvc-cumulus.nl
Methods for cooling controllers
www.mgm-compro.com
-> tech.info
-> controllers COOLING in models [pdf, 166 kB]
Old 11-16-2013, 11:34 AM   #7
Friends: (326)
http://www.hobbyking.com/hobbyking/s...=cooling%20fan
type in cooling fan in the HK search, they have a bunch of cooling fans and different sizes too
Old 11-16-2013, 12:33 PM   #8
rreid7
rreid7's Avatar
Club: AMA #987422
Or you can keep things simple and add a heat sink to your ESC and let the air flow while flying be your fan. Model Aero sells one that works very well:
http://modelaero.com/Merchant5/merch...tegory_Code=SC
ID:	171949 Click image for larger version
rreid7 is offline
Old 11-16-2013, 09:19 PM   #9
Quality ESC's such as the Castle Creations and similar units specify their ratings are based on a 5 MPH breeze blowing past their units. That's probably what a small fan would do. But I don't know just how well that fan would work if it is trying to pull in air that is moving at 60 MPH past the outside of the model. That question would be in the territory of someone with experience in this sort of fluid dynamics.
It's interesting, Castle Creations larger ESC's all have heat sinks on them. Must be a reason. Also interesting, the 20 Amp CC switching BEC also has a fan on it. Again, must be a reason. Methinks for a fan to be effective, it must bolted to, and have the air ducted around the ESC to cool it, much like those computer fans that are mounted directly to the microprocessor in your computer.
One way to obtain real data would be to use an ESC with data recording, again such as the Castle Creations units. The ICE and Talon series also record ESC temperature. So, it would appear to be a simple process to set up a model with, and without a fan, and see what happens in the recorded data.
If you do it, it would be quite interesting for the rest of us!
Take a look at the attached JPG from the Castle Creations 80 Amp HV ESC used in my Redwing MXSR model, flying a Hacker A60-5S motor, 12S2P A123's, and a 19X12 APC-E prop. Its showing only the current, and temperature, all other graph's are turned off. Maximum current pulled is just over 80 Amps, maximum temperature was 100.7 degrees F. This ESC is mounted in line behind one of the air inlets on the fiberglass cowling of the model.
http://www.wattflyer.com/forums/showthread.php?t=72225
Name:	Amps and Temps.jpg
Air compressor for Air Brush npowell28 Beginners 6 08-22-2013 09:49 AM
Air flow spinners.. foodstick General Electric Discussions 3 01-16-2012 11:11 PM
Nona air wheels? eye4wings Scale E-Powered Aircraft 22 06-04-2011 06:31 AM
Page generated in 0.16262 seconds with 38 queries
