Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Support & Testing > Support & Suggestions
Support & Suggestions If you need tech support post your question here or site suggestions too.
Old 12-13-2013, 09:07 AM   #1
Tsavah
Watt Waster
Tsavah's Avatar
View Tsavah's Gallery4
Club: LAFFS, but ...
Default How to Delete a Post in New Thread
I am looking about in a thread I created, but I don't see an option to delete posts that are adverts for adult toys. Obviously a bot was used since the same post was sent five times in less than 7 minutes. What am I missing? I did find and use the ignore member option, but hey, this is my thread and I cannot delete posts? Somethings not right about that.
Tsavah is offline
Old 12-13-2013, 10:05 AM   #2
View Don Sims's Gallery114
WAA-08 Pilot  Globetrotter Pilot
Friends: (40)
We've got a great bunch of volunteer mods and volunteer admins who will take care of that for you as soon as one of us logs in. Just hit the "Report this post" button when you have a concern and we'll take a look at it then do the appropriate action.
Take care and thanks for posting at WattFlyer!!
Don
Old 12-13-2013, 10:55 AM   #3
Friends: (17)
Forgive me for posting here ...
I read OP and I am concerned about the " this is my thread and I cannot delete posts" bit ...
IMHO - it's perfectly fair to be able to delete OWN posts ... but not so fair to be able to delete OTHER peoples posts even if it's your own thread. Sort of Big Brother 'ish ??
Someone posts contrary and BHAM - delete it !
Just commenting ...
Old 12-13-2013, 01:04 PM   #4
eagle33
eagle33's Avatar
Club: Dallas Electric Aircraft Flyers (DEAF)
Where is the "Report this Post" button?
eagle33 is offline
Old 12-13-2013, 01:11 PM   #5
Red triangle with the '!' in it located bottom left.
Old 12-13-2013, 01:32 PM   #6
eagle33
eagle33's Avatar
Got it. Thank you!
eagle33 is offline
Old 12-13-2013, 04:57 PM   #7
Tsavah
Watt Waster
Tsavah's Avatar
Default How to Delete ...
I must see if I can find the "Report this ..." option. I am sure there is no need to allow an advert post to remain in a thread to take up storage space on the system hard drives. Especially since it is for adult toys and is repeated more than five times in less than 10 minutes. In other sites I have had some of my posts removed and I was fine with it because I feel a thread author should have that right.
Allowing the author of a thread to delete posts seems like a very practical option. I suppose I am spoiled since that is a common option on other sites and it makes sense to allow the thread maker to manage what is posted. Otherwise it is easy to imagine what might end up in a thread and how easy it would be for hackers with bots to drive administrators nuts with postings.
Tsavah is offline
Old 12-13-2013, 05:05 PM   #8
eagle33
eagle33's Avatar
Where are you Tsavah, Lawton, OK?
eagle33 is offline
Old 12-13-2013, 05:11 PM   #9
crxmanpat's Avatar
View crxmanpat's Gallery20
Club: Arizona Model Aviators, Gilbert Quiet Flyers
Friends: (27)
Tsavah,
We do not allow members to delete posts from threads, except in the case of a Sticky thread, then the original author can moderate that thread. It is the job of the Mods and Admins to determine if certain posts need modifying or deletion.
As Don said above, we have a great group of dedicated Mods that will help with killing spammers and cleaning up threads. All you have to do is report any offending posts using the "Report Post" feature.
The report post button is located in the left hand column of each post, under the User Name and Stats. It looks like a warning triangle with a "!" in the middle. All you need to do is click on that icon on any offending post and it will send the Mods a message.
Thanks!
Pat Gagnon
crxmanpat is online now
Old 12-13-2013, 05:15 PM   #10
crxmanpat's Avatar
Friends: (27)
Also, regarding your last post on your $75 thread, you have two options:
1 - Simple option is to edit your post and just put "...".
2 - Ask a Mod to delete your post (only takes a second for us to do).
Pat Gagnon
Old 12-13-2013, 05:25 PM   #11
I'm unaware of any other discussion group forums that allows users to delete other people's posts in threads, even if they started the threads.
The only type of threads where that can normally be done is private blogs.
Old 12-13-2013, 05:44 PM   #12
crxmanpat's Avatar
Friends: (27)
Some forums will allow the author of a Sticky thread to moderate that thread themselves (it's that way on RCGroups, but not sure about here).
Pat Gagnon
Old 12-13-2013, 05:49 PM   #13
But not normal threads, I'm unaware of any forum that allows the thread starter to remove other's posts in regular discussion threads.
Old 12-13-2013, 06:04 PM   #14
crxmanpat's Avatar
Friends: (27)
Correct, and that's the way it should be. Otherwise you'd have anarchy on the board. Having Mods is the solution to keeping things civil and under control (well, on most boards anyway ).
Pat Gagnon
Old 12-13-2013, 07:31 PM   #15
Friends: (17)
I am founder and moderator on various boards ... I am registered on many ... and none to my knowledge allow a thread 'creator' to delete anothers post in that thread. That would give opportunity to create completely biased back-slapper threads that have no value to anyone at all.
I understand the OP's question if Bots or spam have invaded a thread - but that is still moderators job .. a thankless job as well.
Tags
adverts , delete posts , ignore
FREE giveaway from MaxAmps.com - post in this thread to enter brandonwilcox Maxamps discussion 33 08-31-2014 10:00 PM
Post in this thread to win a FREE 100W soldering iron from MaxAmps.com brandonwilcox Maxamps discussion 29 10-31-2012 12:04 AM
How do I delete an old thread? JimH Ca Beginners 4 05-20-2012 01:05 PM
Page generated in 0.49904 seconds with 47 queries
