Old 01-01-2014, 10:45 AM   #1
Friends: (19)
Default EDF unit installed in profile model
Lets say you have a profile model ... for arguments sake an F16 ....
The model is basically formed from a vertical profile fuselage and a horizontal outline wing / tail etc. In essence a X frame.... (sorry cannot do an X upright !)
Lets assume we cut that frame near the middle or just back from there - similar to a slot prop and install an EDF unit with wing outline in line with rotor hub centre.
We end up with a model that has an EDF unit sandwiched between two X's ...
How much loss of performance would there be ?
Why I ask - is I have a profile F16 sitting at home that I hate !! Still to this day I do not understand why I wasted the Depron on it. But it has dropped in my mind as to whether to convert to EDF unit.
It's quite big as well ... 1.2m long, but too light and flexible.
Reckon a 55 - 64mm set in would do it.
Old 01-01-2014, 10:59 AM   #2
View CHELLIE's Gallery13
Friends: (327)
Hi Nigel Just cut out the top profile fuselage foam on top of the wing, to fit the EDF, making the edf rear part flush with the trailing edge of the wing, no need to go into the middle of the planes X section, and lay it on top of the wing, add a strip of Basswood 1/16" x 1/4" x 10" to 15" on the bottom of the profile fuselage to make the fuselage stronger, I know you wont get as much elevator control at slower speeds this way, but it will work fine, just keep the speed up,
Old 01-01-2014, 11:49 AM   #3
Friends: (19)
Happy New Year Babe !
I thought about sitting it on the wing as you suggest ... but was hoping to lose a bit of it's bulk lower set in.
I added extra strips along the wing to fuselage joint - if you look closely = you notice a paint line. It stiffened it but still I wasn't too happy to think of fitting a high power pusher on it. So it's sat there for more than a year.
Will check out your suggestion once I get of this hulk of steel !!
Old 01-01-2014, 12:06 PM   #4
Friends: (327)
Happy New Year Nigel
Old 01-01-2014, 04:48 PM   #5
You won't lose much performance having the fuselage and wing crossing the EDF inlet and outlet.
What you will lose is a LOT of structure and will need to make up for it with some form of reinforcing what little of the fuselage there is above and below the fan.
Old 01-01-2014, 04:51 PM   #6
Friends: (19)
True .... mmmmmmmmmmmm ...
Old 01-01-2014, 05:01 PM   #7
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
There must be some edf experts out there who would know. I'd think not using the 80 to 90 % fsa rule for the exhaust would be a loss of top speed, and having some blockage to the exhaust would be a loss to overall thrust. How much? I've seen plans like this in magazines and online though, so it must work if you have a good enough fan unit.
Edit: A random idea just popped into my soggy brain. Maybe having some of that 'x' structure going into the aft portion of the fan, and shaped gradually as possible to a point, if that makes sense, would act as the reduction in exhaust area towards the fsa rule?
Old 01-01-2014, 06:19 PM   #8
Friends: (19)
The model featured earlier is designed for pusher on a 7" prop ... not a pleasant prospect for any hand-launcher ...
Fitting an EDF unit back there is out of the question as it would be far too heavy.
Only way is to fit it near midships ... Fit OVER wing or UNDER wing ?
Chellies idea of the wood spar appeals to me to stiffen it up. I have the bench saw that can strip good wood to ideal size .. and length.
mmmmmm
Watch this space !
Old 01-01-2014, 06:37 PM   #9
You lose top speed by not putting an exit cone on the EDF, but you get a bit more static thrust. Similarly not having a good inlet ring reduces the fan efficiency. Drag from the X of material in the eflux is just that... drag.
But there are EDF designs with the fan buried in the middle of the plane, having essentially a bare EDF, fuselage section partly blocking inlet and part of the fuselage splitting the efflux and they do fine.
(note the horiz in my avatar pic splits the eflux and the fuselage partly blocks the inlet... 120mph)
Sure you could do a lot of work and make it more efficient... and add weight... and probably not really gain anything except a higher minimum speed to maintain level flight (stall speed).
Micro F15 twin 35mm EDF Joe 1320 Indoor & Micro Electric Planes 9 03-01-2013 04:49 PM
Ask about EDF Model Rocket Reynaldo13 Electric Ducted Fan Jets 12 02-12-2013 04:32 AM
Screamer 50mm EDF by Skyangel / Jpower Joe 1320 Electric Ducted Fan Jets 26 08-17-2012 10:16 PM
ELERC Micro A-10 Warthog 30mm EDF Beta Test Joe 1320 Electric Ducted Fan Jets 13 02-02-2012 01:15 PM
Page generated in 0.09613 seconds with 35 queries
