Old 01-01-2014, 11:54 PM   #1
thepiper92
Warbird Fanatic
thepiper92's Avatar
Default Balsa kit building
I just ordered a balsa kit, a Mountain Models P 51: http://www.mountainmodels.com/produc...roducts_id=201
I will not doubt be throwing on a 2 blader, rather than a scale 4 blader, but I am excited nonetheless. I have a few questions about building though, as I have never built anything balsa before. For the main build, would it be wise to add in carbon fiber, and where? Secondlyh, how does one bend balsa? Thirdly, for the motor, it is meant for a gear box, would it take much it throw in an outrunner, most likely a 2836 size? Also, where do I use thick CA and where do I use thin CA? Lastly, how exactly do I wrap the plane? I understand it is a covering that is heated up and shrinks, but is there a certain way to cut the covering and a certain tool to heat it with? It wont be for some time before I get the plane, but I would like some insight from those who have built planes before, or links to sites that give good directions on the procedures required.
thepiper92 is offline
Old 01-02-2014, 12:15 AM   #2
gramps2361
gramps2361's Avatar
View gramps2361's Gallery9
Friends: (24)
piper excellent build thread on this plane here is a link should have all your questions answered with a little reading.
http://www.wattflyer.com/forums/showthread.php?t=45032
Another build thread here .
http://www.wattflyer.com/forums/showthread.php?t=55367
gramps2361 is offline
Old 01-02-2014, 12:21 AM   #3
Friends: (22)
piper,nice build! do a build thread here at wattflyer and we'll follow along as ya go.
some of your questions on covering have me suggesting you p/u a cheap balsa build like the micro telemaster and practice covering it as it's a flat surface fuse. and the wing will get you hands and skills on covering ready to make the p51 look really good.
Micro-Telemaster Kit V2
Product# TEL1100
Price: $49.99
Old 01-02-2014, 12:25 AM   #4
I have a preference to use yellow wood glue (Aliphatic resin) for most of my building with balsa.
Cheaper than CA
Not as brittle
Doesn't harden the balsa creating stress points.
More working time and you can heat the joint to take it apart if its not right.
Makes up for small gaps better than even thick CA.
Old 01-02-2014, 12:29 AM   #5
gramps2361
gramps2361's Avatar
Friends: (24)
Cheaper than CA
Not as brittle
Couldn't agree more on the good old yellow wood glue for building Titebond II is my go to glue now.
Old 01-02-2014, 12:38 AM   #6
thepiper92
Warbird Fanatic
thepiper92's Avatar
Why didn't I think of that, I did woodworking for some time in school, was a master at it, should have thought of the wood glue instead of the CA. And I just realized there are directions for the plane. Just looked them over quickly, that will help a lot.
Old 01-02-2014, 01:32 AM   #7
thepiper92
Warbird Fanatic
thepiper92's Avatar
What's the best option for heating the solarfilm? I'm seeing heating irons, heating guns.
Old 01-02-2014, 01:56 AM   #8
The important part about covering is getting the edges down, pulling the wrinkles out as best you can.
WHat works best for the final shrinking is a heat gun of some sort (hotter than a blow dryer). but you can just use a common travel iron. I did all of my covering work for over 20 years with a travel iron I got for $1 at a garage sale. I still use that for ironing down the edges and often don't bother getting the heat gun out.
What you get used to using will influence your techniques and can make it so you have trouble transitioning to a different tool.... I can't use the specialty covering irons at all.
Old 01-02-2014, 02:07 AM   #9
thepiper92
Warbird Fanatic
thepiper92's Avatar
I ordered one of the Hangar 9 Irons, a smaller one, hopefully that will work for me...once I get to actually covering the plane that is. Looking at videos, it doesn't seem to difficult, and one set of directions mentions tacking one corner and actually stretching the film a bit to the next corner, thus eliminating most of the shrinking process.
Old 01-02-2014, 02:26 AM   #10
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Changing over to an outrunner from a geared inrunner is fairly simple. The main thing is you will likely need to build a new firewall more forward than the existing firewall as most outrunners are shorter then most geared inrunners.
The most important thing to have when building a balsa kit is a FLAT building surface. If your build table has warps or twists in it - so will your finished model. I tape the planes to the building table, then cover with wax paper or clear cellophane to keep them from getting covered in glue. Then build right on top of the plan.
Mountain Models kits mostly jig up by themselves, but some of the smaller sized T-pins or some dress making pins (with the bead on the end) will help to pin pieces in place on top of the plans while the glue sets.
Some other good things to have when building a balsa kit - various grades of sandpaper, razor knife or blades, razor saw, hobby plain, small clamps and most any other wood working tools you ay have.
Good luck!!
I think I need a signature.
Larry
Larry3215 is offline
Old 01-02-2014, 02:33 AM   #11
thepiper92
Warbird Fanatic
thepiper92's Avatar
Good luck!!
I found some stick motor mounts. Looking around, apparently that's what other people building the plane used. I have plenty of x-acto blades and a lot of sandpaper. Good idea about the clamps and pins. Pins would definitely come in handy holding things in place.
Old 01-02-2014, 03:56 AM   #12
Larry3215
Larry3215's Avatar
Stick mounts work well for low power setups - under say 150-200 watts. Much over that and they can cause problems - vibration mostly - especially if you use a long stick or one that isnt strong enough.
Keep us posted on progress
Larry
Old 01-02-2014, 04:01 AM   #13
Larry3215
Larry3215's Avatar
By the way, here is one of the best covering 'How to' threads Ive seen.
http://www.rcgroups.com/forums/showt...=711624&pp=100
Larry
Old 01-02-2014, 05:53 AM   #14
thepiper92
Warbird Fanatic
thepiper92's Avatar
So stick mounts are no good really. What's my option then?
Old 01-02-2014, 06:16 AM   #15
Simply make a box to push the motor forward.... or move the firewall forward.
Most likely if you move the firewall you'd have to put in a bulkhead at the original firewall position and wouldn't gain anything vs the box. The box is another convenient place to put some lead ballast.
Old 01-02-2014, 06:47 AM   #16
thepiper92
Warbird Fanatic
thepiper92's Avatar
So even this is no good for higher power?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYWY5
Sorry still trying to understand all this. Is the mount the issue or the stick itself in terms of too much power. If that's the case I would have to make something that mounts to the frame itself?
Old 01-02-2014, 07:09 AM   #17
Larry3215
Larry3215's Avatar
A lot depends on how long the stick is and the quality of the stick itself as well as how powerful the motor is.
However, the recommended power systems for that model is only capable of 150-175 watts or so at the absolute maximum, so a stick mount will be fine as long as you dont use a balsa stick. Find a nice smooth grained basswood or spruce stick and you will be fine
You could easily use a more powerful outrunner if you wanted but as I said, I would not go much above 200-250 watts or so if the stick is more than two to 3 inches long unsuported.
Larry
Old 01-02-2014, 07:21 AM   #18
thepiper92
Warbird Fanatic
thepiper92's Avatar
Okay, so I am guess this is overkill? https://www.hobbyking.com/hobbyking/...er_1200kv.html
It is what the Mini Switch is running. Will this plane actually be lighter than a foam one? I'm guessing the plane doesn't come with a stick, or if it does it is likely balsa. Where are some basswood sticks available?
Old 01-02-2014, 07:30 AM   #19
Larry3215
Larry3215's Avatar
Yup - way overkill That model will build very light if you're even moderately careful - under 20 ounces if you follow the plan.
So 150 watts works out to 140 watts per pound of model. Thats enough power to do 3D flying
A 350 watt power system would be 280 watts per pound of model - which is beyond insane power levels.
The model is designed for 100-150 watt power range. The structure might not handle 350 watts well at all - as in having ther frront of the model depart in flight
Id recommend no more than 200 watts or so max
Larry
Old 01-02-2014, 07:32 AM   #20
Yeah
Add me to the list of suggesting yellow Titebond glue, rather than CA. It's easier to work with, much easier to sand, and from tests I ran several decades ago, after the Titebond has dried for 24 hours, it's less weight.
And, if you really screw up during the build, just hit the Titebond glue joint with a heat gun, and peal apart the wrong glue joint with a DULL knife. Then, just re-do it.
This also works with epoxy glue joints, but be careful of the fumes.
Don't try this with CA. CA won't let go, and it will stink up the house with who knows what is in the fumes.
Old 01-02-2014, 07:33 AM   #21
thepiper92
Warbird Fanatic
thepiper92's Avatar
Yikes, it's slightly larger than the Mini Switch and actually lighter. Good thing I have other motors.
Old 01-02-2014, 07:35 AM   #22
Larry3215
Larry3215's Avatar
It may be a balsa stick as its only designed for low power setups. I never use balsa sticks though - Ive had too many issues with them. Ive done many many stick mounted motors over the years. Its easy to make your own or you can go to HomeDepot and get a 1/2"x1/2"x36" long pre-cut hardwood stick. You will need to sand it down to 10mm but you can get several sticks for just a couple of bucks. Just check the stick to be sure the grain runs parallel to the long dimension and its nice and straight and you will be fine.
Larry
Old 01-02-2014, 07:41 AM   #23
Yeah
Sand it down to fit. For some reason, I've had problems trying to glue some of that square stock. Don't know why, it might be due to some natural oils present in the wood??? For me, sanding it down made it work OK.
That square material is some strong stuff, just try gluing some scraps of it first to make sure all is well.
Old 01-02-2014, 08:00 AM   #24
Friends: (19)
Best thing I ever did was to buy a small bench circular saw ...
Means I can buy wood at local store ... and strip it to sizes I want ...
Old 01-02-2014, 08:15 AM   #25
thepiper92
Warbird Fanatic
thepiper92's Avatar
Any hardwood should be fine though I'm guessing. The plane should be really light with only 1300mah packs. It will get good run times too with only that much amp draw. I am getting 6-8 minutes with the bigger 3836 in the Mini Switch, although not full throttle often. With this plane, lighter will only help the run time on each pack.
Building the Great Planes Fundango Pilotwings24 ParkFlyers 2 07-28-2013 09:02 PM
Dumas(P.Tritle's) TaylorCraft 40" Balsa Kit Build- "Jeannie" CrimzonRider Scratch and Kit Built Aircraft 15 04-06-2013 05:06 AM
Equipment for Covering & Building Balsa Kit CrimzonRider Scratch and Kit Built Aircraft 47 02-23-2013 01:42 AM
Help with balsa kit selection Novice_Ace Beginners 9 12-22-2011 03:10 AM
Trying my hand at kit building Wrongway-Feldman Scratch and Kit Built Aircraft 25 05-30-2011 05:18 PM
Page generated in 0.46694 seconds with 69 queries
