Old 01-21-2014, 01:14 AM   #1
ewilliam
Default Reusing Power 25 mounting bracket for power 32 engine
I am upgrading from a power 25 to a power 32 engine. Does anyone know if the mounting brackets are the same size or at least is it close enough that I could use the existing mounting bracket with the power 32 engine?
ewilliam is offline
Old 01-21-2014, 02:13 AM   #2
hayofstacks
hayofstacks's Avatar
the power 32 and 25 mounts are different sizes. not sure of bolt spacing. I couldn't find this info in a quick Google search.
slow stock prop reversal. it flies! easily! 543 watt dual motor bipe slow stick. push-me-pull-you. 242 watt 3 channel slow stick. 365 watt mini ultra stick. 415 watt mini contender. 810 watt ultra stick .25e. 220 watt alpha 450 sport (retired).
hayofstacks is offline
Old 01-21-2014, 02:36 PM   #3
ewilliam
Thanks is what I was afraid of...I've also got a power 46 engine that definitely doesn't fit....may as well go with that...more power to the people.
ewilliam is offline
Old 01-21-2014, 06:32 PM   #4
hayofstacks
the power 32,40 and 46 all share the same mount.
I personally buy most if my motors from heads up rc.I like the actual testing and prop data they provide with most of their motors. I have a monster 32 on my ultra stick that I really like, but I don't think they make it anymore.
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 162 06-12-2017 07:00 PM
E-Flite Power 32 for a 6.5-7 lb Rascal 40?? Albatross Power Systems 7 07-25-2011 03:46 AM
Page generated in 0.06024 seconds with 25 queries
