Old 01-26-2014, 02:42 AM   #1
Friends: (22)
Default question: optima 6 channel ,4servos &rx batt issue.
hey gang,i have a optima 6 channel rx in the rv-4 and am using 2 servos on the ailerons,1 for rudder,1 for elevator and an rx 6volt battery with an opto esc.
heres what i'v spent the last hr researching and still haven't got the answer yet.
channel 1 is the right aileron,ch 2 elevator,ch3 esc opto,ch 4 rudder,ch 6 is the left aileron. so my question is if it's ok to plug the rx 6volt battery into the empty channel 5 spot?.
channel 6 is marked as battery/aileron and i don't see where i program my eclipes 7 2.4 tx to switch channel positions so the left aileron would be in channels 5's position and the battery would be where it's marked on channel 6.
will the rx battery be ok in the 5th channel spot? with it plugged in there everything is working but i want to be sure it's not a problem. worst case,i buy another optima 7 channel.
i'm not using the spc spot as i need to power the servos and the rx via the nimh 6 v battery.
Old 01-26-2014, 03:58 AM   #2
hayofstacks
hayofstacks's Avatar
I have ran a bec on an open channel before rather then the bind/battery slot and haven't had any problem, but this was on spectrum.
slow stock prop reversal. it flies! easily! 543 watt dual motor bipe slow stick. push-me-pull-you. 242 watt 3 channel slow stick. 365 watt mini ultra stick. 415 watt mini contender. 810 watt ultra stick .25e. 220 watt alpha 450 sport (retired).
hayofstacks is offline
Old 01-26-2014, 12:55 PM   #3
Rodneh
Club: Moonport Modelers
Yes, okay, the power and ground pins are common on all the receiver connectors on most receivers. This lets you plug the power source into any unused channel.
Rodneh is offline
Old 02-01-2014, 09:15 PM   #4
A.T.
Club: To many to include.
It does not matter which channel you have the power plugged into,
in fact you can power each servo separately via a "Y" lead, please refer to:
. Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout & Add Redundancy, even one for each servo.
These links will also assist:
. Optima Transceiver (RX) - Battery set up for Nitro/Gas models #1 - caution re NiMH & Alert re LiFE.
. Optima Transceiver (RX) - Battery set up for Nitro/Gas models #2 - caution re NiMH.
With much more assistance under the Hitec USA Support Forum Sticky:
AFHSS 2.4Ghz Module, Transceivers Receivers Telemetry,
- FAQ, Setups & Tips
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 02-01-2014, 10:28 PM   #5
Yep... you can plug power in any channel or Y it with any servo.
Works for all RXs.
Except on the special high power input RXs by Spektrum... those you have to use the heavy gauge power leads or the RX won't work.
There may be other high power buss RXs that also require the power to come in through a specific port.
Old 02-02-2014, 01:12 PM   #6
Friends: (22)
thanks gang for all the answers to put my mind at ease with the rv4-40's hookup. I've had bad issues in the past with this build,warped wings,bad cheap equipment,brown out..ect..ect,and couldn't let it defeat my having a successful build and flying bird.
thats why i installed good equipment and questioned its wiring. now i can relax while waiting for snow to melt. also not buy anymore rx's.
i had search for answerers and you all verified and supplied them,so thank buttons hit for all. thanks again,stu
What does the 4th channel on a 4 channel add? jmr1068204 Beginners - Helis 6 11-12-2012 03:05 PM
Choosing a Sailplane Radio - What to Consider AEAJR Hi-Performance and Sailplanes 3 04-09-2012 12:57 PM
I have a question regarding the new 16 channel transmitters. FlyWheel RC Radios, Transmitters, Receivers, Servos, gyros 12 05-08-2011 06:20 PM
4 channel question zzlentz Beginners 108 02-19-2011 02:31 PM
Page generated in 0.08835 seconds with 29 queries
