Old 01-27-2014, 10:51 PM   #1
Karnsy
Default First Jet ?
I know this might be a silly question but other than an EDF what would be a good slow (for a jet) jet to start with. I have several HH planes and think I would like to get a jet this spring. Looking for something in a PNP or BNF. Thoughts please...........
Karnsy is offline
Old 01-28-2014, 12:29 AM   #2
tarheal63
tarheal63's Avatar
Send a message via AIM to tarheal63 Send a message via Yahoo to tarheal63
Default First Jet ?
Hobby People phase 3 f-16 is very popular. I have the Hobby Lobby(express) versions of the mig and panther. Very tame jets but you can spin em up if you want to.
Sent from my iPhone using Tapatalk
HZ SuperCub. PZ Spit(Older), Dynam EZ Hawk, GWS A-10(prop), HL F9F Panther, GWS ME-109, E-Flite P-47D, Jodel BeBe 9, HL Wicked Wabbit P-47, BL Slow Stick, PZ T-28, Electrifly SE-5A, HL Mig-15, PZ Stinson, Quad and Tricopters
AMA #973528
tarheal63 is offline
Old 01-28-2014, 01:37 AM   #3
LOL
Every jet foamie I've seen at our club goes like a bat out of heck. Even my el-cheapo EDF model moves right along. But, the pilots that have been buying them also are flying the giant scale models when the weather allows, so they are looking for the real fast ones. Two guys hit well over 100 MPH with their respective foamie jets last fall.
(Right now, its -2F around here, and windy as heck with a foot of snow on the field. A year ago, we were flying off of grass at our club field.)
Old 01-28-2014, 04:14 AM   #4
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Almost any of the foamies that fly on 3s should be manageable. Like the F-15, 16, and 18 in 64 mm edf size. There are plenty others. I have a Hobby King F-4D Skyray that could hardly pass a HZ Super Cub in its stock form. When they feel slow, then you can upgrade to a 4s power system so it can really fly like a jet. My first edf was the Dynam Turbojet, a Cessna Citation bizjet copy, and I really liked it. Twin motor power and a straight wing were the attractions. An A-10 would be similar, but the arf's out there don't usually have functioning rudders. The Turbojet does. Los of choices, but I think 3s 64 mm is the key to a beginners edf if you don't mind 'small' planes. And then as usual read real people's experiences with any plane you choose before buying it.
Edit: forgot about hand launching. I always rog, so I forgot 3s edf's may be challenging to hand launch depending how heavy they are and how strong your arm is!
Old 01-28-2014, 04:32 AM   #5
Dynam Me262 is a very stable aircraft, not excessively fast and slows down well.
See my notes about it elsewhere in these forums and in Nitroplanes.com's customer reviews.
Old 01-28-2014, 04:17 PM   #6
View dahawk's Gallery6
Club: 114th RC Aero Squadron
For ease of flying, I would recommend the Phase 3 EF16( Hobby People) or the Freewing F9F Panther( Value Hobby) The down side to the Phase 3 F-16 is the beer cooler foam. Not good in the event of a mishap. Both were extremely easy to fly without much drama but enough to keep you on your toes.
For a tad bit more fun, I recommend the Stinger. I have the 4S version and it's a lot of fun. This plane does have a rudder. Did I hear Knife Edge? LOL A really nice plane but probably a second edf.
For the smaller 50mm jets, I have a bunch of the Jpowers series( T-45, F-16, T-33, F-18, Screamer) They are also a lot of fun but twitchier than the larger 64mm jobs.
The Screamer and F-18 are my current favorites but the T-45 is the easiest to fly.
Good luck. The only thing about these planes is to add plenty of expo and stay ahead of them. They are not intimidating at all.
-Hawk
Old 01-28-2014, 05:23 PM   #7
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Without question the UM Mig or UM Habu.
Old 01-28-2014, 10:36 PM   #8
earthsciteach
http://hobbyking.com/hobbyking/store...arehouse_.html
earthsciteach is offline
Old 01-30-2014, 10:11 PM   #9
Karnsy
Default Thanks
Thank you for all your info. I really like the T45.
What about this one ? I am thinking it might be a good beginner jet. Not available right now but maybe soon ???
http://www.nitroplanes.com/exrcfpharfed.html
I also wonder about this one if I was to take it easy....
http://www.nitroplanes.com/95a251-f18-blue-arf.html
Karnsy is offline
Old 01-30-2014, 10:30 PM   #10
F-18 is a better choice than a Phantom... the Phantom has some inherent stability issues.
There are common issues with any EDF.
You have to ensure the fan has adequate intake flow and a good thrust tube for best results. Many foam ARF/RTF edf models have decent thrust tubes molded in but inadequate intake. If you find the model to seem to have limited power, you can often cure it by carefully opening up the intakes and/or "cheater holes". (I had to open the cheater holes to 8X original area for an Art-Tech F-18)
The EDF may produce more thrust at mid throttle than at full throttle at low airspeed. Its important to remember this especially for take-off. You can often use a shorter runway by slowly advancing the throttle instead of advancing it as rapidly as you are used to when flying a prop driven plane. Full throttle thrust will build up with airspeed (up to max the fan can produce) due to a ram-intake effect.
Tight turns and other maneuvers can bleed speed and get you back into the speed range where the fan isn't producing its best full throttle thrust.
You have to think a bit differently flying the EDF. If you remember the common issues you can avoid them easily.
Old 01-30-2014, 11:09 PM   #11
Karnsey,
I'm a huge fan of both full scale planes. The designation is incorrect on the Phantom though. The Navy never flew the E model. Just the B, J and N. Anywhoo...
I agree that the F-4 will be much more difficult to fly. Heck, the full scale version was called "the brick" Had a 50mm Jpowers F4N and it was a real dog.
The F-18 will perform much better IMO. All my edf's are hand launchers 50mm or 64mm. I now have a 70mm scratch built X47B . The easiest has been the F9F Panther.
Naval Air Superiority!
Old 01-31-2014, 12:16 AM   #12
Club: CVMRCC, SEFSD
Actually, one of our club members who flies a lot of edf's said his 64 mm FMS F-4 is the best flying edf he's ever had. Don't know how that one will compare.
Old 01-31-2014, 01:40 AM   #13
Phantoms can be really nice... but I just don't recommend as a first EDF for someone scared of speed. You need to keep the speed up. The Phantom has a nasty stall-spin characteristic that the F-18 avoids.
Old 01-31-2014, 11:49 AM   #14
Siberianhusky
Club: Human Race
You might be waiting a LOOOONG time from Nitroplanes/hobbyparts!
Some things have been out of stock years (literally), seems they get a container load of something, when it sells out that's it, but it will remain on the website out of stock.
I've been watching a few things from them, kind of gave up as stock hasn't been replenished.
I haven't bought much from them, but when stuff is in stock you can't beat some of the prices.
Siberianhusky is offline
Old 02-01-2014, 11:56 AM   #15
Karnsy
Default My Decision
Well after much research I have decided to go with the F18
I hope it works out for me. It has gotten great reviews. For the price I could not go wrong. I have another Nitroplanes (P51mustang) and so far so good with that one. I have a lot of room to fly it so turning should not be an issue. Should be in this coming week. Thanks to all of you that took the time to help me out.
Karnsy is offline
Old 02-01-2014, 01:13 PM   #16
View CHELLIE's Gallery13
Friends: (326)
The F18 is a nice jet, Just remember to keep the speed up, speed is your friend with EDF jets if you try to fly them to slow, they will stall on you, because jets tend to have a heavier wing loading, Take care and have fun, Chellie
Old 02-01-2014, 01:26 PM   #17
Great ! and of course, Go Navy !
I have a smaller 50mm F-18. I hand launch it. Like Chellie mentioned, keep your speed up, especially in the turns. Fly her in "Big Air" and stay out in front of her. I'd include plenty of expo in the beginning. Say, 40% on ailerons and elevator.
Should be lots of fun. Enjoy !
-Hawk
Old 02-01-2014, 01:39 PM   #18
WAA-08 Pilot
Friends: (9)
Interesting choice - good luck!
Old 02-01-2014, 05:54 PM   #19
I had the earlier version of the Airfield F-18. That's the one that I drastically increased the cheater hole size for.
Later I opened up the area behind the nosewheel for a 1800 mah 3S which kept the CG the same as the OEM 900 mah in front of the nosewheel. (apparently they read my review about the battery) With the available power being better (better airflow) it handled the added weight just fine.
Stock out of box it was really struggling until I had it high enough to do a dive and get the ram-air effect going.
Don't hesitate to open the cheater holes if it seems to lack power. Double length and 4 times as wide as the old version's holes...
Found a pic of the new version's belly. They didn't change the cheater holes. They did the behind the nose-wheel battery compartment (left the old forward one too...) All of the rest looks the same as the one I had.
Old 02-08-2014, 12:41 PM   #20
Karnsy
Default Got it !
Well the Nitroplanes Blue Angels F-18 got delivered yesterday.
Packed well, all is good there however............
Looks like I will need to make some mods already before flying.
1. The battery compartment, as there is no way any of my 3cell 1800 or 2200 batteries will ever fit. I need to extend the compartment by 3/4" which is odd since those are the recommended battery sizes..hmmmm. Some plastic cutting is in need.
2. I need to get 2 servo leads as the RX is best going up front and not on top of the ESC, there is no way servo wires will reach.
Other than that I am looking forward to the maiden
Karnsy is offline
Old 02-08-2014, 03:41 PM   #21
Club: CVMRCC, SEFSD
Good luck on the maiden. Just an fyi, many rc models of jet fighters have a very forward cg, so it that's what the instructions tell you, believe it! My F-35 and F-104 cg is probably 1/4" aft of where the wing meets the fuselage.
Old 02-08-2014, 10:06 PM   #22
Karnsy
What I do not get is a 1300 fits perfect, I think I am going to have solder longer esc leads on (hardly long enough clip a battery in) but the 1300 fits like a glove in the factory compartment. But I think that may ruin the ESC.
Karnsy is offline
Old 02-08-2014, 10:26 PM   #23
Which F-18 did you get? The 64mm ? I have a 50mm Jpowers job that I can easily get a 1000mah 3S inside the cabin
Old 02-08-2014, 10:56 PM   #24
Club: CVMRCC, SEFSD
Ruin the ESC? A higher mah battery won't ruin the ESC, but too many cells, hence too much voltage, can.
Old 02-08-2014, 11:03 PM   #25
You can usually extend the ESC wires to double original length without much worry. If you are really concerned you can double up the capacitors that are on the ESC. That allows you to extend the wires even more.
Excess wire length between battery and ESC can cause an inductive "snap" which can blow up the ESC. The chance of this happening is higher at mid-range than at full throttle.
Its safer to extend the wires between ESC and motor, but you need to keep the lengths even.
The original version of that F-18 had a 12 inch extension between ESC and battery and no added capacitors.
A slow 'fast jet' - The Fairey Delta 2 quorneng Electric Ducted Fan Jets 32 12-03-2013 12:21 AM
need help finding cg on a pusger jet sratch build before maiden.stu tobydogs Pusher Park Jets 30 10-05-2013 02:17 PM
JPower 50mm EDF V-Tail Jet Glider Joe 1320 Electric Ducted Fan Jets 4 06-03-2013 02:53 PM
First good EDF jet peteflys Electric Ducted Fan Jets 6 03-29-2011 02:07 AM
Welcome to the Pusher Jet Forum - Please read crxmanpat Pusher Park Jets 13 11-02-2009 09:39 PM
Page generated in 0.55309 seconds with 67 queries
