Old 02-12-2014, 09:23 PM   #1
waytooslow
Crash'em if you got 'em!
waytooslow's Avatar
Club: 114th Grapevine
100mph Speed Demon
Default Powering Spektrum Recievers
Is it possible to power up a spektrum DSMX via the Bind Data plug for a two battery system? Like other ports?
Too many hobbies, and not enough time!
waytooslow is offline
Old 02-12-2014, 10:18 PM   #2
Dennis V
4kW  Outstanding Contributor Award  3kW  2kW
Friends: (21)
Yes it is.
FYI, the standard configuration for ALL servo connectors is black or negative, red or positive, and another color for signal from one end to the other end. If you grab a digital multimeter and check continuity between servo connectors, you will find the bottom row are all common, the middle row are all common, with the top row being individual servo control signals. So a two wire battery plug connected to the Bind Data connector works just fine.
In fact, on my giant scale models with dual receiver power supplies, one connects to the standard receiver DC input, the backup connects to the Bind Data connector.
DennyV
Old 02-13-2014, 01:46 AM   #3
waytooslow
waytooslow's Avatar
100mph Speed Demon
I thought as much, just had a hard time finding the answer to my expectation. Thanks
Old 02-26-2014, 01:01 AM   #4
Lighat
I'm running the AR9000 with 4 8611a's and 9 8411s with a Powerbox Champion 4024 and two Powerbox 2800mah batteries without any problems. Powerbox setups are ideal for this kind of setup since your receiver should get constant voltage through the Powerbox. A friend of mine is running all 8711's with this setup and hasn't had a problem either.
Lighat is offline
Why is spektrum lacking? Gibbon RC Radios, Transmitters, Receivers, Servos, gyros 5 03-04-2014 08:59 PM
Sold Spektrum HP6DSM TX for sale $35 shipped (priced reduced) pmullen503 Radio Equipment For Sale & WTB 1 07-20-2012 01:57 PM
Losing my confidence in Spektrum e-pilot RC Radios, Transmitters, Receivers, Servos, gyros 77 05-10-2012 04:09 PM
Help please - need to buy several new spektrum receivers DanWard RC Radios, Transmitters, Receivers, Servos, gyros 3 08-12-2011 07:18 PM
For Sale spektrum receivers AR7000 genuine spektrum receivers LOWERED PRICE 2.4ghz Radio Equipment For Sale & WTB 0 07-12-2011 02:22 PM
Page generated in 0.08566 seconds with 27 queries
