Old 01-30-2014, 04:13 PM   #1
waytooslow
Crash'em if you got 'em!
waytooslow's Avatar
Club: 114th Grapevine
100mph Speed Demon
Default New Compact ArtiZan PZ Sport
Nice New plane from PZ compact ArtiZan
Too many hobbies, and not enough time!
waytooslow is offline
Old 02-03-2014, 07:56 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Looks like a great sport plane to me.... A great balance between the PZ T-28 and the Vision Aire. Nice....
Old 03-15-2014, 07:05 PM   #3
Love my Stinger
Fishbonez's Avatar
Send a message via AIM to Fishbonez Send a message via Yahoo to Fishbonez
Friends: (16)
Default Anyone??
I'm looking into this plane pretty close. I am interested in tinkering with 3D and I have seen the Visionaire and it was impressive but for some reason I kinda like the Artizan. Just don't know if this plane will help me to learn some 3D moves or not or do I dare say do you think thisar is a good beginner 3D planes? If you own one love to read your thoughts on it
Happy flying may your crashes be limited and if they are not limited let them be cool.
Fishbonez is offline
Old 03-20-2014, 01:13 AM   #4
Chucksolo69
All I can say is the PZ Artizan is an incredible plane. If you want to start flying advance aerobatics, this is the plane to get. I like her more every time I fly her.
Chucksolo69 is offline
Old 03-25-2014, 11:16 PM   #5
ChuckD
Fishbonez, I'm sure this plane is everything it's advertised to be. Probably not a 3-D trainer though. There are several Tech-One profiles that would serve you better. My favorite is the SU-31, 1000mm. Very affordable, durable and acrobatic. Dial your throws back if it's too quick for you. Or fly it slower and use bursts of throttle to make those large control surfaces work for you. Oh, and they look cool too.
Chuck.
ChuckD is offline
Old 03-29-2014, 02:41 AM   #6
Chucksolo69
After 20 flights I am convinced this is the heir apparent to the T-28 as a low wing aileron trainer. She is impervious to wind and lands the easiest of any tail dragger I have flown. I just got a VisionAire and plan to do a comparison of the two. But it's true, the Artizan is NOT a 3D plane although it can do some nice aerobatics. Flew her today with my FZ Acro-Wot. The Artizan is easier to fly, and just as aerobatic.
Old 04-08-2014, 05:23 PM   #7
simibill
General Factotum
simibill's Avatar
View simibill's Gallery34
Club: Simi Valley Flyers
Outstanding Contributor Award
I flew my Artizan for the first time today and found it to be very out of trim, especially the elevator. I had to put in all of the available up elevator trim and it still wasn't enough. Is your Artizan using the AR615 Rx?
Life's journey is not to arrive at the grave in a well preserved body,
but rather to skid in sideways totally worn out shouting, Holy Crap... what a ride.
simibill is offline
Old 04-08-2014, 05:46 PM   #8
ChuckD
These things are usually pretty close. Did you check for balance? Are all of the components in their correct locations? Hinges installed correctly and glued securely? Motor installed securely. So many things could cause this, wing mounted securely in its saddle. Does the elevator appear to be out of alignment? Does it have the same trim issues flying inverted? How about when power is off and gliding?
ChuckD is offline
Old 04-09-2014, 04:20 AM   #9
Chucksolo69
My BNF Artizan is using the AR635 AS3X receiver. As far as the elevator goes, you need to MECHANICALLY trim the elevator out before you fly it; looks can be deceptive because the HStab looks to be angled downward. If it is diving, and you are using a lot of up trim, add it gradually on the ground until she flies straight and level at just over half throttle. It may take a bit of trial and error, but once dialed in, she flies like a dream.
Old 04-09-2014, 03:10 PM   #10
simibill
General Factotum
simibill's Avatar
Thanks for the info. I think you're correct the visual of the elevator position is my problem. I've reset the neutral and will try it again.
simibill is offline
Old 09-23-2014, 09:01 PM   #11
CDN71
I have a question regarding the gear on the Artizan, it's angled back does this effect the ground handling especially on grass? How does it track on the grass?
CDN71 is offline
Old 09-23-2014, 10:17 PM   #12
stream41
nice guys...
stream41 is offline
Old 09-26-2014, 05:46 AM   #13
engineerbill
Default Artizan Transmitter Setup
I just picked up the Artizan and am setting it up tonight. The manual says to setup dual rates of 100% and 70% throws but does not mention expo. I have been using some expo on my previous models and am wondering if the omission of any mention of expo was deliberate. So, Expo yes or Expo no?
engineerbill is offline
Newbie SC flyer gets a T-28 Trojan (PZ) ironbinder Beginners 20 09-30-2013 12:08 PM
Tweaks for PZ Visionaire JZSlenker 3D Flying 12 09-11-2013 09:33 PM
PZ F4F Wildcat Cheap and Fast TopSpin Warbird Electrics 24 09-03-2013 04:02 AM
PZ Archer or PZ T-28 Trojan for flying in a baseball field njg ParkFlyers 4 02-15-2013 03:26 PM
Battery cage for PZ UM P51 Davethebluessinger Indoor & Micro Electric Planes 8 06-08-2011 06:13 PM
Page generated in 0.09278 seconds with 43 queries
