Old 02-06-2014, 01:48 AM   #1
thepiper92
Warbird Fanatic
thepiper92's Avatar
Default Aileron servo not working
I just hooked up all the electronics in my P51, including the Frsky receiver with my new 9xr. For some reason, the servo stops working randomly. The ESC is some 20a Hobbyking one, although I will be installing a better one, I'm just using it to test everything out. I don't know what is wrong, whether it isn't bound well, the esc, the servo or the receiver. I unplug the battery to the plane and plug it back in and I can see the servo moving, then it is dead when trying to control it. I will suddenly start working, then randomly die yet again.
thepiper92 is offline
Old 02-06-2014, 03:10 AM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Details will help. There are a lot of P-51s out there! What size is it, how many servos, dual or single aileron servos, what battery, etc.
Also, I doubt there is such a thing as a 'bad bind'. Either the tx and rx are bound or not.
Check the servo connection very carefully. Is it plugged in fully? Maybe a pin in the connector came loose and isn't fly engaged.
Old 02-06-2014, 03:17 AM   #3
thepiper92
Warbird Fanatic
thepiper92's Avatar
It's the Mountain Models P51 I just built. Perhaps it's the y-connector. I'll have to see if a different connector works better.
Old 02-06-2014, 05:31 AM   #4
View mclarkson's Gallery26
Friends: (8)
I would say that 75% of the time I've had that kind of problem, it's been the servo itself that was bad. Can you swap leads with the other aileron servo and see what happens then? Or plug a known good servo in place of your suspect one?
Old 02-06-2014, 05:42 AM   #5
thepiper92
Warbird Fanatic
thepiper92's Avatar
Well I already had that issue. The one servo wasn't working at all, and I ripped it out and put a new one in. It worked, then had the issue of not working, it may be one side of the y connector not working properly. It is a fairly new servo, came off of one of my first planes, and the servos never failed on it. The servo sounds fine, just it suddenly doesn't work after I move the plane around a bit. As the wire coming out of the servo is held tight in the mounting area, it wouldn't be moving.
Old 02-06-2014, 07:04 AM   #6
Club: CVMRCC, SEFSD
Maybe a bad y-harness? Jiggle it while troubleshooting.
Old 02-06-2014, 07:31 AM   #7
Diagnosing things like this simply needs a logical systemetic trouble shooting approach.
In this case if I understand it right: One aileron servo is working ok, the other is not, and they are on a Y-lead.
So it's quite obviously not a receiver or transmitter problem, otherwise neither servo would move.
First check that the control surfaces and pushrods (when disconnected from the servos) move freely with no binding or stickiness and minimum resistance.
If the surfaces move ok then next reverse the Y lead so that the leg of the lead that's been connected to the 'bad' servo is now connected to the 'good' servo, and vice versa. Check to see if problem now transfered to the other servo.
If the problem transfers then it must be a bad Y-lead. If it stays with the same servo then it's a bad servo.... simple
Old 02-06-2014, 08:34 AM   #8
Friends: (19)
JPF is right, it's a bit if systematic diagnosis by testing each part in turn.
First us to swap over servos and see if same servo acts up or same y lead extension.
One item that proves excellent in this - a servo tester. For less than a decent servo price, you have a tester that identifies all faulty servos and connections. Safes all the hassle of RX access etc.
Being a Y lead job - it is not RX..... it has to be in the Y lead or servo itself.
Aileron Servo Direction ianfox RC Radios, Transmitters, Receivers, Servos, gyros 11 12-18-2013 08:33 PM
Aileron servo conversion Skyartec Cessna 182 solentlife Foamies 3 12-15-2011 12:03 AM
PZ F4u corsair-lost contact...hard landing, broke aileron servo arm-need replacement tehlump Warbird Electrics 12 03-07-2011 06:40 PM
servo zero, angle of the dangle, and flight surface equal travel DanWard Beginners 4 02-10-2011 04:57 AM
Page generated in 0.09873 seconds with 33 queries
