Old 03-03-2014, 05:01 AM   #1
Default Model Airplane Power Systems
Many of our electric models use electric power systems all ready installed. For flying the model, it's a simple matter of picking up a suitable battery pack, finish the radio stuff, and go fly.
Then there are those larger models, where the modeler has to select an electric power system that will perform as well as the same model with gas or glow engine power.
In this regard, I searched through a real stack of model magazines, looking for test reports or data on the power systems, consisting of Glow Engines, Gas Engines, or Electric motors. This information was tabulated in a Microsoft Access database, with the fields "Motor Mfg", Motor Model", "Type", "Prop Diameter'", "Prop Pitch", "Prop RPM", and "Watts".
Using the Access Database, reports were created with the information sorted by "Motor Mfg", "Type", and "Watts". (Type is electric, gas or glow")
For those wattflyers that are familiar with engine power, and are looking to convert some of those larger models to electric power, these reports may be useful.
FYI, a few of the electric power system power outputs were derived from www.motocalc.com, as my electric collection does not have any 10 KW motors.
Some of those glow engines output power was a bit surprising. Check out the Saito FA200 three cylinder engine. That $$$$ engine has quite a bit less power than my Hacker A60-16M motor.
File Type: pdf Model Power Sort by Motor Mfg_Motor Model_Prop Diameter.pdf (226.4 KB, 376 views)
Platt Dora 64" wood model -Power Ques? lou1984 Warbird Electrics 37 10-28-2014 03:42 PM
Will-Hobby Gee Bee R2 .90 - 1.20 power plant question. Electropilot Power Systems 8 12-25-2013 09:50 PM
Kyleservicetechs Hanger 9 Katana model kyleservicetech Sport Planes (Formerly I/C & Gas Conversion) 12 04-01-2013 04:04 AM
May have figured out what killed my plane- DX5 power glitch CNY_Dave RC Radios, Transmitters, Receivers, Servos, gyros 9 08-12-2012 04:17 AM
Is Model Airplane News (digital access) worth it for old articles and plans? Mojo Scratch and Kit Built Aircraft 7 07-24-2012 06:04 PM
Page generated in 0.05267 seconds with 21 queries
