Old 03-14-2014, 11:25 PM   #1
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Default Electric conversion / GP Cherokee
Picking up a used Cherokee tomorrow for $75.00. Now for the electric conversion. This is my Buddy's plane and it is gas with air retracts and of course, the servos. So , I guess it would now be a Piper Archer. LOL
I'm looking at 4 different electric 46 size motors: Tacon, Exceed, SK3, and Powerup(familiar with) but not sure which one. Any thoughts? . All in the 600-700kv 1000W range Probably go with a 70-80 amp esc. Will change out the air retracts to servoless metal trunnion electrics with oleo struts. Will have to see what's he's done there with the openings. Will need a new GP cowl .
By the time I'm done, it will be a ~ $300 airplane. No way around it.
Appreciate expert advice !
Thanks,
Old 03-15-2014, 04:32 AM   #2
View CHELLIE's Gallery13
Friends: (326)
Thanks,
Hi Hawk whats the W/S on the plane and what is the Estimated AUW, That will help a lot to get a nice power system for it, here are a few suggestions below. I Know that Fireman Bill uses these Grayson motors on his builds and is happy with them.
50 size E Motor & 70A ESC Combo $74.99
http://www.graysonhobby.com/catalog/...0gsvvd2jcstir4
60 size E Motor & 70A ESC Combo $89.99
Old 03-15-2014, 04:36 AM   #3
Friends: (326)
Great Planes Cowl Cherokee .40 ARF
http://www3.towerhobbies.com/cgi-bin...?&I=LXUDR9&P=7
Old 03-15-2014, 04:39 AM   #4
Friends: (326)
is this the Plane, If it is, the 2 Grayson motors listed above will work great with out breaking the Bank
http://www3.towerhobbies.com/cgi-bin...&I=LWC217&P=ML
SPECS: Wingspan: 60" (1520mm) Wing Area: 606 sq in (39 sq dm) Weight: 6.75 - 7.25 lb (3060 - 3290g) Length: 46" (1170mm) Airfoil: Semi symmetrical, low wing placement Center of Gravity: 3-1/16" (78mm) Back from the wing's leading edge Control Throws: Low Rate High Rate Elevator: Up & Down 3/8" (9.5mm) 16 1/2" (13mm) 21 Rudder: Right to Left 5/8" (16mm) 17 1-1/4" (32mm) 34 Ailerons: Up & Down 7/16" (11mm) 10 1" (25mm) 24 Flaps: Full 9/16" (14mm) 24 Half 5/16" (8mm) 13
Old 03-15-2014, 06:25 AM   #5
Thanks,
I've also got this motor, looks to be a very decent motor at a very good price. Have not flown it yet, not with all the snow we got this winter.
http://www.ebay.com/itm/Hyperion-ZS-...-/190877599328
This motor turns an APC-E 13X6.5 Prop at 8500 RPM, while pulling 40 Amps at 14 Volts out of my 5S A123 battery pack.
Update:
This model with the Hyperion motor was flown last week with four very successful flights. That motor and it 5S1P A123 pack will haul that 57 ounce model straight up, out of sight.
Old 03-18-2014, 11:39 AM   #6
RobinA
Club: West Florida Modelers
I have the Power Up 46 on a Four Star 40.Great motor,more power than I need.
Robin
RobinA is offline
Old 03-18-2014, 12:18 PM   #7
Thanks all,
Good options. I'm most familiar with the Power up but am open to other combos. Want an arming switch on the esc cause the canopy removal is a bit of pita. Two side screws hold it on. Maybe go with magnets.
-Hawk
Old 03-21-2014, 12:29 AM   #8
cyclops2
Magnets.
Screws crack.
cyclops2 is offline
Old 03-21-2014, 01:29 AM   #9
Thanks all,
-Hawk
Depending on the size of your model, this works out very well for models perhaps 4 foot wingspan and larger.
http://www.wattflyer.com/forums/showthread.php?t=72329
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 04:22 PM
2 Meter Glider Conversion to Electric - Sample Package AEAJR Beginners 28 02-16-2016 12:19 AM
Glider Kits? to a conversion to electric? BrianW517 Hi-Performance and Sailplanes 18 01-03-2015 03:26 AM
GP Lancair 60 size electric conversion!! spencer k Sport Planes (Formerly I/C & Gas Conversion) 4 02-06-2012 04:50 PM
Page generated in 0.10293 seconds with 35 queries
