Old 04-02-2014, 03:52 PM   #1
FlyWheel
Ochroma Pyramidale Tekton
FlyWheel's Avatar
View FlyWheel's Gallery5
Club: Lancaster County Fliers
Question question about bending balsa
For all my builds I have been soaking the wood I intend to bend in plain water and this has been working fine so far. However in many other builds I have read the builder uses a mixture of water and either ammonia (Windex) or vinegar. Am I missing something? What does mixing these additives do that plain water doesn't?
OK, I got my "drone licence"...
When does the season start and what Ammo can I use?
FlyWheel is offline
Old 04-02-2014, 04:38 PM   #2
View rcers's Gallery57
WAA-08 Pilot
Friends: (9)
Yes they allow the fibers to relax a bit more. That said - I have never found them necessary.
Old 04-02-2014, 05:49 PM   #3
Yep, ammonia softens the bond between the fibres so they can slide over one-another allowing the wood to be bent to a very tight radius without creasing. Only necessary if you need a very tight radius, otherwise plain water is good enough.
Old 04-02-2014, 08:16 PM   #4
Rodneh
Club: Moonport Modelers
The ammonia works best as it actually softens the cell casing itself and lets it reform to the new position, then, when the ammonia dissipates it locks the wood into the new position just as if it had grown that way. There is some spring back if you use water.
Rodneh is offline
Old 04-02-2014, 10:15 PM   #5
FlyWheel
FlyWheel's Avatar
Kind of like giving the wood a perm, right? Ok , thanks. I'll keep that in mind if I ever need to make any tight bends. Does the acid/ammonia affect the curing of aliphatic (TiteBond) any? IOW, should I make sure it's dried completely before gluing?
FlyWheel is offline
Old 04-02-2014, 10:33 PM   #6
dgjessing
Heat works wonders on lots of woods (I've never tried bending balsa like this though...):
https://www.youtube.com/watch?v=EzS0vWp3ycs
Dave
AMA #56519
dgjessing is offline
Old 04-03-2014, 02:21 AM   #7
FlyWheel
FlyWheel's Avatar
it will, but most people here who I have heard use it saturate the wood with hot steam, whereas the guy on the video saturates the wood first then applies heat.
FlyWheel is offline
Old 04-03-2014, 01:21 PM   #8
carpetbagger
Club: Dare County RC Flyers
no special smelly additives needed - heat works. 200 deg F is the magic number. Boat builders use a steam box and steam the strips X number of minutes per inch thickness (I forgot the minutes number) then pull out the spaghetti bendable strip and shape it, clamp it, let it cool and dry.
I have a hot water tray - 3/4" wood squares tacked to a wood sheet and lined with Al foil, size about 40" x 9" to hold sheets of balsa. Balsa waiting in tray I boil up a pot of water, pour it on wood in tray, let `er sit for a few, then pull it out and strap it down to the shaped mold piece. Let her dry, trim and install.
For things like 1/16" or 3/32" turtle decks I soak the wood under running hot water from the sink tap, strap around form, let dry, trim and install.
carpetbagger is offline
Old 04-04-2014, 09:05 AM   #9
P51 nut
A slight variation here - what I do is soak a sponge with plain water and apply it only to the outside of the piece to be bent. This way, the glue tends to work better since the inside surface is still dry (or relatively so at least). I've had excellent results with this method so far on pieces up to 1/4" thick. I've enclosed a shot from my current build with the results.
P51 nut is offline
Fixing balsa damage, how do I do this? Mysterious Scratch and Kit Built Aircraft 20 06-06-2013 06:11 PM
Balsa Built Parkflyers (not kits) Murocflyer General Electric Discussions 4 06-06-2013 04:06 AM
Sold SOLD Builders Lot of Balsa and Wood Merritt General RC items For Sale and WTB 0 02-17-2013 11:53 PM
covering question on balsa...any ideas? tobydogs Scratch and Kit Built Aircraft 44 01-22-2013 07:15 AM
Best Balsa Source Zocane Scratch and Kit Built Aircraft 8 12-19-2010 01:32 PM
Page generated in 0.14258 seconds with 38 queries
