Old 04-08-2014, 09:01 PM   #1
MKE-Flyer
Default Charger Combo Deal??
So my local Hobby Town is selling a Charger & Power Supply deal for 124.99 and I was wondering if this was any better or a good deal at all compared to my current charger.
Currently I have this little guy, I charge in parallel and it takes about 45-60 min to charge 3300mAh 3S batteries.
Hitec X1+ AC Single Port AC/DC Charger HRC44165
http://www.rcplanet.com/Hitec_X1_AC_...FfFFMgodcxsAeQ
I can get this for 124.99 Combo Deal.
Power Supply, 15VDC 250W - http://www.dynamiterc.com/Products/D...ProdID=DYN4200
And
Passport Ultra Power DC Charger - http://www.dynamiterc.com/Products/D...ProdID=DYN4102
Will this be any better than what I currently have at the moment? I would like to charge faster if at all any possible.
MKE-Flyer is offline
Old 04-08-2014, 10:36 PM   #2
And
That doesn't look to bad, especially at the price including a power supply. I've got the Cellpro Powerlab 8 chargers that can charge a battery in 15 minutes or less.
BUT, and this is a BIG BUT! Fast charging LiPo batteries can drastically shorten their life. Most people indicate that these LiPo batteries should be charged at the "1C" rate, or 2.3 Amps for your 2300 Mah batteries. That 1C by definition is a charge(or discharge) time of exactly one hour.
I've got those A123 cells in all of my models. Those overweight, undervoltage, oversized batteries can be charged at any rate your charger can put out. And, they'll last for years and hundreds of charge cycles in the process.
Problem is, IMHO, those A123's don't work out so well in smaller foamie type models. They won't fit, and they are heavier.
Old 04-08-2014, 10:37 PM   #3
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Well, first do you understand that to be able to charge faster, your batteries have to be rated for higher than 1C charge rate? Check the labels if they say so.
As far as the charger you're looking at, it appears more capable at 150w output vs your current 50w. (Actually, at 50w, I'm surprised you're able to parallel charge, at least at 1c for each battery. You know if you parallel charge 2 3300 batts, you can charge at 6.6 amps to get 3.3A each? But at 50w, for 3S batts you're limited to about 3.9A, if I figure right.) Anyway, the only thing I don't see is that the charger is a balancing one. Maybe it's not important to you, but it is to me. It might save you from accidentally charging a 5S batt as a 6S and having some fireworks or something! And it'll be nicer to your batteries, or so they say. I'd verify it is a balancing charger before going ahead with it.
I don't like to charge faster than 1C as it can be hard on the batteries. I think parallel charging is the biggest time saver.
Old 04-08-2014, 10:51 PM   #4
You're right.
No where does it say this charger does balance charging. IMHO, any LiPo charger now days that doesn't do balance charging should not be considered.
Period.
It's just to dangerous, since charging a way way out of whack LiPo battery could lead to battery fires.
Old 04-09-2014, 12:27 AM   #5
MKE-Flyer
Oh, you may have saved me!!! I balance charge every time! Good call on that one, I will see if it can. I know it has balance leads but I will look in the manual before I purchase.
IF it does balance charge would this be a better beginner option?
Old 04-09-2014, 12:34 AM   #6
MKE-Flyer
I would set it to 6amps but it would only charge at 4.4amps (maybe), would take 45-60min to charge two 3.3amp 3C LiPos.
Old 04-09-2014, 12:35 AM   #7
MKE-Flyer
It does, I just looked at the manual.
Link to manual:
http://www.horizonhobby.com/pdf/DYN4102_EN.pdf
Old 04-09-2014, 12:58 AM   #8
Club: CVMRCC, SEFSD
Well it sounds like a good deal then.
As far as the balance charging, sounds like you were pushing your charger to its limits. 12.6v*6A=75.6w. Probably why it was limiting itself in amps. I prefer to keep my chargers well within their limits. All that heat I figure will fry something eventually. At 4.4A it was at around 55w, depending on the battery voltage.
If you're not familiar with the math involved, you should learn before something bad happens!
Old 04-09-2014, 01:01 AM   #9
MKE-Flyer
Thank you the help, I will go out and pick it up tonight.
Any good links on understanding math and LiPo charging?
Old 04-09-2014, 02:33 AM   #10
Club: CVMRCC, SEFSD
Here's an electrical calculation chart.
And I guess you haven't caught this yet: Everything You Wanted to Know About Electric Powered Flight. The battery stuff is in there somewhere!
Will this Battery & Charger Combo work? MKE-Flyer Batteries & Chargers 1 11-26-2013 01:51 AM
Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 7 10-25-2011 08:03 AM
How to use a RC Lipo charger properly? SimonXi Power Systems 0 08-17-2011 12:02 PM
Solid experience on RC Model Lipo Battery Accident & Charger Guide SimonXi Batteries & Chargers 0 08-12-2011 06:08 PM
Introducing the ALL NEW Cellpro 10XP Charger Howard Matos FMA Direct 0 07-28-2011 03:04 PM
Page generated in 0.09012 seconds with 37 queries
