Old 04-19-2014, 06:11 AM   #1
Default $100 Twin Build Contest Batplane
http://www.wattflyer.com/forums/atta...0&d=1397530097
Going to design as I build with the PDF (provided by DEG) as the only part of the design I didn't do on my own.
Plan is:
Build a small flat plate based glider to experimentally determine CG (scrap card stock)
Cut the bat symbol and vertical stabs from 1 inch pink insulation foam.
Cut parts to make the fuselage "box" from scraps of the pink foam.
Insert 1/4 inch dia fiberglass (bike pennant) rod as main spar and possibly other reinforcements to keep the wing stiff.
Place the EDF units, servos and electronics to get appropriate CG
Build ducts around the EDFs (probably a couple of styro soda cups involved here)
liberal use of knife and sandpaper to finish shaping.
Cut in the control surfaces and hinge them
Add landing gear.
Pray that battery placement gets me back on CG
Spray paint and fly.
Actually not starting yet...
I am spearheading (herding cats would be more organized) our local club's participation in a full scale airshow with RC model demonstrations 2-4 May.
Old 04-19-2014, 07:08 AM   #2
thepiper92
Warbird Fanatic
thepiper92's Avatar
Good idea for a build, how large is it going to be?
thepiper92 is offline
Old 04-19-2014, 07:21 AM   #3
1400 mm span, appx 680 mm length
Twin 70 mm EDFs on 4S (4000 to 5000 mah tested to be appropriate for about 4 min flights using these fans in the plane they came from)
Old 04-19-2014, 07:31 AM   #4
thepiper92
Warbird Fanatic
thepiper92's Avatar
The size of planes I like Not too cumbersome to carry, yet handles the wind well. Good luck with the build, really want to see how it turns out.
Old 04-19-2014, 07:34 AM   #5
Friends: (19)
Interested to see how you lay it out ... ie control surfaces etc.
It's an interesting concept and one that is making me consider dropping my TU144 and choose something else more 'interesting' !!
Watching with great interest !
Old 04-19-2014, 05:35 PM   #6
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Looking forward to this one Ive done a Bat Car and Bat Boat in depron but not an edf version. Twin edfs will be very cool!
I think I need a signature.
Larry
Larry3215 is offline
Old 04-19-2014, 08:46 PM   #7
pmullen503
Scratchbuilders Award
Subscribed!
pmullen503 is offline
Old 04-19-2014, 09:53 PM   #8
Friends: (19)
I live by the river with quiet stretch of it for my yacht ... and I think often about building a model boat in foam ...
I used to run model boats ... Veron Police Launch with OS 10, MFA Spearfish with Merco 60, County Class Destroyer with twin electrics etc. when I lived in UK.
Sorry back to Batplane !!
Old 04-19-2014, 10:07 PM   #9
Larry3215
Larry3215's Avatar
I should have mentioned that the Bat Boat is a flying boat - along the lines of the Hydro craze from a few years back. Best (or worst) of both worlds The Bat car flew too, but the boat was way cooler and more fun.
(sorry for the hijack!)
Name:	IMG_2254 (Large).JPG
Larry
Old 04-20-2014, 05:10 AM   #10
View CHELLIE's Gallery13
Friends: (327)
This will be a cool Build Subscribed
Old 04-20-2014, 05:54 PM   #11
Wrongway-Feldman
Wrongway-Feldman's Avatar
Looking forward to seeing this one come alive
This is a fact, you have never been in an empty room.
Wrongway-Feldman is offline
Old 05-12-2014, 08:21 PM   #12
Just bought the "pink" (its purple) foam... $16 for a 4 ft X 8 ft sheet. I'll use slightly more than half of it.
Old 05-13-2014, 12:30 AM   #13
riverrat
circa: 1946
riverrat's Avatar
Club: NRA Life Member
Friends: (30)
Subscribed.
riverrat is offline
Old 05-14-2014, 06:04 AM   #14
crispy
Foam Concept Jets
Club: Foam Flyer's
Send a message via Yahoo to crispy
This is the 70mm edf bat wing i made it's just one of many of my creations. http://youtu.be/IRvvjODJFSo http://youtu.be/amU8ZoXk0cI http://youtu.be/ImayqHO5UyI http://youtu.be/83kNO4aaYxE http://youtu.be/QFrOlS_nDAs
crispy is offline
Old 05-14-2014, 06:26 AM   #15
thepiper92
Warbird Fanatic
thepiper92's Avatar
That flies great. Doesn't take long to get up to speed either.
Old 05-17-2014, 04:48 AM   #16
OK..
Step 1: Print reduced scale bat symbol and make a test glider to get ballpark for CG.
This worked REALLY well. One rough guess at CG and I had it gliding across the room. Stuck a screwdriver that came with a Dynam ARF in as the nose weight.
And there's the 70mm EDFs that will go in the big one. I also plan to install retracts.
(Still just $16 spent so far)
Name:	Mini bat symbol test glider.jpg
Old 05-17-2014, 05:44 AM   #17
Got the tiled printout for the big one.... 24 sheets of paper :p
I cut the small one out on my bandsaw. The big one won't fit. Cutting it out will take a while.
Old 05-17-2014, 04:47 PM   #18
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Holy overkill Batman! (Ok, I realized that's your chuck glider next to those 2 edf's as I was typing that, but someone had to do it! )
Old 05-17-2014, 10:16 PM   #19
Been playing around more with the chuck glider... added verticals and shaped the plate to give it some reflex. Now it can be tossed for a flight across the front yard.
CG might not be ideal since it goes through a stall-dive sequence. Or maybe I have too much reflex. It should be controllable if I put a micro RC system on it, so close enough.
Trying to piece together the 24 sheets for the big one... is a pain. I think I'll go to a drafting company and have them print it.
Old 05-18-2014, 02:47 AM   #20
Larry3215
Larry3215's Avatar
Kinkos will print pdf's to any scale you want. Prices vary a LOT from one store to another, so its worth calling around first. I printed some plans a year or so ago that was about 36" x 42" for about $3/page. I was quoted anywhere from there on up to $12/page.
Larry
Old 05-20-2014, 04:24 AM   #21
Bill G
Super Contrubutor
Bill G's Avatar
View Bill G's Gallery88
Club: rcg staff
Friends: (17)
I wouldn't call that a hijack. Looks really cool Larry!
The contest project also looks like it will be really interesting.
Yeah 24 sheets is about my limit. Done that more times than I care to think about!
Bill G is offline
Old 05-30-2014, 12:26 AM   #22
Not really working on it much...
Located the styro cups to use for EDF efflux cones. $1.50 for a pack of 20. I'll use 2.
Stacked all of the servos and such in a pile.
That's about it so far.
Old 09-30-2014, 09:54 AM   #23
Friends: (327)
Hi fhhuber Did you ever get this plane built and flying, voting on the planes will be starting on the first of Oct.
$100 Twin Build Contest JU EF112 offtom Scratch and Kit Built Aircraft 18 09-30-2014 09:57 AM
$100 Semi Scratch, Twin Build Contest CHELLIE Scratch and Kit Built Aircraft 64 08-23-2014 01:04 PM
$75.00 Build Contest, Unique, Seldom Built Flying Aircraft Starts Dec.1 2013 CHELLIE Scratch and Kit Built Aircraft 24 02-16-2014 06:00 PM
$50.00 Scratch Build Contest, It has Begun :) CHELLIE Scratch and Kit Built Aircraft 120 12-07-2013 04:27 PM
$100 Scratch Build Contest "Best Looking" poll here hillbillynamedpossum Scratch and Kit Built Aircraft 107 08-27-2013 12:23 AM
Page generated in 0.53184 seconds with 67 queries
