Old 04-25-2014, 02:23 AM   #1
View mclarkson's Gallery26
Friends: (8)
Default DX9 Aileron - Rudder mixing. What am I missing?
I have a new plane that I'm setting up on my DX9 radio. I want to add in some Aileron - to - rudder mixing.
The DX9 has a selection under MIXING called AIL > RUD. This sounds like exactly what I need.
So I enable it, set it to a switch, adjust the LEFT and RIGHT mix %, and ...
nothing happens. Aileron movement does not cause rudder movement. (Nor does rudder movement cause aileron movement.)
The DX9 provides a handy monitor right there on the mixing screen so I can see that nothing's happening.
This should be really simple. What am I missing?
Old 04-25-2014, 04:39 AM   #2
Stevephoon
Stevephoon's Avatar
View Stevephoon's Gallery70
Friends: (8)
Originally Posted by mclarkson View Post
... set it to a switch...
Is the enable switch is set to the enable state??
I bought a DX9 as well, I have not tried a Aileron to Rudder Mix yet. I have done a Rudder to Elevator mix which works fine. I set it up just like you stated for your mix... I'll pull it out tomorrow (after work) and double check the settings and look at what happens on the output screen...
I was hoping to see some action on this TX here on Wattflyer... The DX9 thread over on RcGroups is so active, I can't keep up...
Growing the fleet!
Stevephoon is online now
Old 04-25-2014, 04:45 AM   #3
Friends: (8)
I've flipped the Enable switch both ways. I've also set it to ON rather than a switch. No joy.
Old 04-25-2014, 08:42 AM   #4
I have the DX18 which has the exact same programming menu. Sounds like you are doing all the right things, it works ok when i set up Ail>Rud mix on my DX18.
What % value did you set? If you use a small value the servo movement is so small as to be undetectable at the servo or in the monitor. If you want to check that it's working whack the % value up to around 50% or more, then you should notice it doing it's stuff. For actual flying try around 15% for starters.
Old 04-25-2014, 10:18 AM   #5
Friends: (8)
I set it to 25% but that's a good idea. I'll dial it up to 100% and see if that makes any difference.
Old 04-29-2014, 01:02 AM   #6
Stevephoon
Stevephoon's Avatar
Friends: (8)
Mark, Sorry that I never got back with you, did you figure this out yet?
With mine, It's as simple as your original post. I'm on the latest firmware. 1.05. I see it on the mix screen, (Aileron input giving some Rudder movement) and on the main screen as well.
Growing the fleet!
Old 04-29-2014, 03:45 AM   #7
Friends: (8)
It seem to have magically started working. :/ I have no idea what I might have changed, or done wrong in the first place, but I fired it up just now to get some photos of its behaviour and it's now doing just what it ought to.
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 159 02-16-2016 01:56 AM
Helping People Learn to Fly AEAJR General Electric Discussions 204 01-28-2016 05:20 AM
Questions about 2 servo(separate plug) aileron vs single, and mixing on the DX7S DCDetector RC Radios, Transmitters, Receivers, Servos, gyros 4 02-27-2013 06:21 AM
Re: A dx6i mixing question please! Swanj Power Systems 1 08-26-2011 06:19 PM
Do you use aileron-rudder mixing? safecub Beginners 33 07-11-2011 07:22 AM
Page generated in 0.07300 seconds with 31 queries
