Old 06-04-2014, 10:14 PM   #1
Davethebluessinger
Child of the 60s
Davethebluessinger's Avatar
View Davethebluessinger's Gallery4
Club: None
Friends: (9)
Default Seperate Ailerons on DX7s with Orange RX
Hi guys,
This is driving me mad!
I'm almost finished assembling my HK 330 Extra profile but cannot figure out the settings to use 2 individual ailerons (no Y lead).
TX is the old DX7 SE (heli model) I'm plugging the right Aileron into the Aileron channel and the left aileron into Aux on the Orange RX. I've done a data reset and created a new model in the TX and I've been through both TX setups suggested here without success: http://www.spektrumrc.com/Articles/A...ArticleID=1798
I can get the ailerons working in the right directions but the left aileron automatically flicks to about 35 degrees as soon as I power up the RX.
Does anyone have any suggestions please (apart from throwing the TX in the bin!)
HK Mini Spirit, Flying Wings Mini Raven, FT Versa Wing, HK WingWing, Yuneec Q500, RCTimer 450 Spider, Eflite 200QX, Eflite UM Habu, Eflite Sport Cub, Eflite Whipit, HK Phoenix 2000, Dogfighter SPAD, Stryker F27Q
Davethebluessinger is offline
Old 06-04-2014, 10:49 PM   #2
It sounds sort of like the one aileron is cycling through the position the AUX channel had when you first bound the RX to the TX. If its going back to centered when controls start responding its not a problem at all. You can rebind and that will make it stay centered.
Old 06-04-2014, 11:39 PM   #3
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Is the Dx7se the same as the old Dx7? You may want to check here. Denny did it. Mentions it at the bottom of the page. Maybe he can help you out? Good luck ď
Old 06-05-2014, 12:37 AM   #4
Originally Posted by Davethebluessinger View Post
Hi guys,
Try using a different channel for the left aileron servo. (FYI, if another don't help, try another channel!) My DX7 transmitter had issues when the "wrong" slave channel was used. Also had an issue where throwing one of the unused DX7 switches at the top of the transmitter caused an unwanted servo operation. Be sure to double check this when done. That is, while holding the two transmitter sticks off center, throw all unused switches at the top of the transmitter, to make certain no unwanted interaction takes place.
Again, with a different mix with a different channel for the left aileron, everything worked out just fine. If my fading memory is correct, two of the aux channels of the DX7 transmitter are designed for mixed slave operation, the others are not.
Old 06-05-2014, 02:25 AM   #5
Turner
Turner's Avatar
Have a look here. Let me know if I can help with any questions.
http://www.wattflyer.com/forums/showthread.php?t=72022
Turner is offline
Old 06-05-2014, 06:05 AM   #6
Have you set enabled 'flaperon' in the 'wing type' set up screen?
You need to do it to get dual aileron servos working. It's on page 44-45 of DX7 the manual (I assume the SE is identical in this pert of the set up).
Orange RX / DX5e weirdness dgjessing RC Radios, Transmitters, Receivers, Servos, gyros 12 05-29-2014 01:53 AM
Best use of 6-channel RX w/Flaps + Ailerons mclarkson General Electric Discussions 10 10-04-2013 10:19 AM
For Sale HK Orange RX 3 axis airplane gyro $20 Shipped newjak Radio Equipment For Sale & WTB 4 04-02-2013 09:27 PM
quanum telemetry and orange rx cc83 General Electric Discussions 2 03-05-2012 03:44 AM
Seperate RX battery..does the LIPO pack need to be connected to program the ESC liposucker General Electric Discussions 6 06-12-2011 01:40 AM
Page generated in 0.09273 seconds with 29 queries
