Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Electronic Builders Workshop
Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
Old 06-28-2014, 01:29 AM   #1
tocar64
Tom B
Default Spektrum DX-8 Flaperon setup HELP
Can anyone help me with setting up my DX-8 for flaperons?? I have A 6 ch rx and plugged one servo into the AIL slot and the other into the AUX-1 slot. I went into wing type on the DX-8 and weather I use Duel Ail or Flaperon, I only get response from the servo plugged into the AIL slot. HELP!!!
tocar64 is offline
Old 06-28-2014, 01:49 AM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Go to your Monitor page and make sure there are 2 channels moving when you move the ail. Then see what that other channel, the one that's not AIL, is. IIRC, it may use the gear output.
Old 06-28-2014, 02:35 AM   #3
tocar64
Tom B
Okay, I checked the monitor and it shows the RAL and LAL moving. It does not show an AUX1 port. The last 3 are: LAL, AUX2 and AUX3.
tocar64 is offline
Old 06-28-2014, 03:14 AM   #4
Club: CVMRCC, SEFSD
Oh yeah. They rename them on the screen. I think like I said, it winds up on the gear port of the rx. When all else fails, try the different plugs and see what works!
Old 06-28-2014, 04:43 AM   #5
It renamed the AUX1 port in the TRANSMITTER, but didn't change the label on the RX... its still AUX1
JR/Spektrum port order is: Throttle, Aileron, Elevator, Rudder, Gear, AUX1/2/3/4/5...
Pretty standard to NOT use the 5th (Gear) channel for the flap or second aileron channel. Futaba uses 6th port also.
So skip a port between rudder and your second aileron/flap/flaperon channel.
There ARE other settings that could leave the second aileron so it doesn't move. Generally if you start out with a CLEARED model memory you won't run into these potential issues. I always clear the memory (even if its never had a model assigned to it) before I start plugging in servos when setting up a model.
Old 06-28-2014, 02:30 PM   #6
tocar64
Tom B
Do you think if I re-bind the RX it will see the AUX channel as the 2nd AIL ??
tocar64 is offline
Old 06-28-2014, 06:26 PM   #7
Club: CVMRCC, SEFSD
Lol! You searched for my pet peeve, didn't you? No. The process of binding only makes the tx and rx talk to each other on that model memory. They are either bound or not. The only thing it will do on certain Spektrum rx's, is set the rx's failsafe servo positions. The 2nd ail position is set within the tx.
I just checked some dual ail models in my Dx8, and it looks like on the monitor screen the 2nd ail is in the spot where "AX1" used to be, not the gear position as I previously thought. Did you find out which position on the rx it is? Which rx are you using, btw?
Old 06-28-2014, 06:45 PM   #8
Clearing model memory and starting over might help... That might require a rebind. (didn't require rebind with X9303 DSM2... haven't checked with my DX-18 DSMX mode)
Check that the aileron that is not responding will work if you swap which aileron is plugged into which channel.
If the same aileron still moves and the same one doesn't move then you have a servo issue. Either the servo is bad or the plug on the wire is bad.
If it swaps which aileron works and which doesn't then you have an issue with your RX or your programming. (more likely the programming)
My standard practice when setting up a plane with separate servos for each aileron is to make both ailerons work correctly on a Y harness THEN split to different channels. That involved 3 Y harnesses when doing an ultimate Bipe, one servo for each of 4 aileron surfaces. (Then I split it out to 4 channels... one at a time.)
Old 06-28-2014, 08:18 PM   #9
tocar64
Tom B
Thanks to everyone for all your help. I feel like a fool! All it took was putting the servo into the RX correctly!!! It was backwards!!! WOW!!!
tocar64 is offline
Old 06-28-2014, 10:03 PM   #10
Club: CVMRCC, SEFSD
Lol! Don't feel bad. I think we've all done it. Now you know it's the first thing to check.
Why is spektrum lacking? Gibbon RC Radios, Transmitters, Receivers, Servos, gyros 5 03-04-2014 08:59 PM
Sold Spektrum 2.4Ghz DX 7 dumpsterjay Radio Equipment For Sale & WTB 0 08-02-2012 02:02 AM
Setup help with foam ducted fan F16 danauti1 RC Radios, Transmitters, Receivers, Servos, gyros 13 06-03-2012 04:23 AM
DX 7 (Spektrum) Battery Issues/Question AirmanAirhead RC Radios, Transmitters, Receivers, Servos, gyros 4 03-27-2011 06:21 AM
Need help with complete setup. KenSue Power Systems 9 01-29-2011 01:36 AM
Page generated in 0.09081 seconds with 37 queries
