Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Hi-Performance and Sailplanes
Old 07-03-2014, 06:16 AM   #1
Friends: (9)
Cool Bagging wings - A resource thread
I am not a builder but I have a lot of respect for those who like to build.
I have been preparing a section of my weekly newsletter on Bagging Wings. There will be a presentation at our club on the topic at the next meeting.
I think I pulled together some good resources so I am going to post them here for those who might be interested.
And I encourage anyone who knows hot to bag wings or who has question about bagging wings to post in this thread. Maybe we can get a good exchange going.
If my club is interested we might start a "one design" group build around a bagged wing project. If it happens I will let you know and share a link to the discussion.
RESOURCES
BAGGED WING GLIDERS –
THE LOW COST WAY TO BUILD COMPETITIVE TD, ALES and HAND LAUNCHED GLIDERS
Many of the gliders flown at the ESL contests at our field are bagged wing designs.
Learning about bagging wings will open up a whole new world of options for you. You can make DLGs, larger models, winched gliders and electric gliders that look and fly very much like the high end molded wing gliders.
First you cut the foam cores
Hot wire cutting foam cores
https://www.youtube.com/watch?v=-sd0c7Y1XqE
https://www.youtube.com/watch?v=jZkTCeoN79M
Hot wire kit review
http://www.cstsales.com/tekoa_hot_wire.html
http://www.rcgroups.com/forums/showthread.php?t=971230
Custom cut foam cores if you don’t want to cut your own
http://www.clm-pro.com/cnc-cutting-services
Make your own foam cutter
http://www.charlesriverrc.org/articl...foamcutter.htm
Making foam cutting templates
https://www.youtube.com/watch?v=O8M91NlsxPE
Then they go in the bag
Vacuum Bagging Overview video
He is not making a wing, he is making a part on a mold
This could be used to make 1/2 of a fuselage
The process is similar for wings as you will see in the other videos
https://www.youtube.com/watch?v=5jSwx_EkJgM
Wing bagging videos – to give you a flavor of what it takes:
Bagging a DLG wing, start to finish
https://www.youtube.com/watch?v=tW3fEWBZGrU
Bagging DLG wings
https://www.youtube.com/watch?v=oFWuorRZPnQ
Bagging a scale glider wing
https://www.youtube.com/watch?v=ywPe3eqBofE
Telos building thread with $10 VACUUM BAGGING SYSTEM Tutorial!!!
http://www.rcgroups.com/forums/showthread.php?t=966524
Vacuum Bagging Systems
http://www.cstsales.com/vacuum_bagging.html
http://www.cstsales.com/basic_vacbag.html
Vacuum bagging with a vacuum sealing food saver
May not be good enough to build a Supra but it might be good
to give the process a try if you have one of these.
http://www.rcgroups.com/forums/showthread.php?t=186029
Nice write-ups and photos of building a foam core wing for bagging.
May fill in some details that you don’t pick up from the videos
http://www.cstsales.com/vac_wing.html
http://www.favonius.com/soaring/bagging/bagging.htm
http://www.favonius.com/soaring/bagging/tail_end.htm
http://www.pilotsguide.com/rc/vacbag.shtml
Instructional Videos on making bagged wings
Beginners Guide to Cutting and Bagging Foam Wings
http://www.tailwindgliders.com/Sales.html
Phil Barnes - Vacuum bagging made easy – video set (I have this set)
This is based on the stressed skin approach, as I recall
http://www.rcgroups.com/forums/showthread.php?t=190214
I confirmed that the video is still available even though a couple of the preview links
on the page don’t work. You can order the video here.
http://home.paonline.com/hayman/PAGE2.htm
OK, you are interested. What can you build? Here are some examples.
You can use this technique to build any kind of aircraft but being a glider pilot mostly I focus on gliders. Here are Mark Drela competition glider designs that are based on bagged wing construction
Supra – 3.4 meter glider
http://charlesriverrc.org/articles/supra/supra.htm
Aegea 2 – 2 Meter Glider
http://charlesriverrc.org/articles/a...la_aegea2m.htm
Super Gee 2 – DLG
http://charlesriverrc.org/articles/s...SuperGeeII.htm
You can buy the Super Gee 2 foam cutting templates and the boom here:
http://www.mountainmodels.com/produc...roducts_id=192
Lost foam method of making composite parts.
You could use this method to make your own pod/fuselage
http://www.rcgroups.com/forums/showthread.php?t=188980
Glider design discussion based on a bagged wing Supra. This conversation goes back to 2011 and is still active today.
If you want to read a bit about how people take an existing design, the Supra, and modify it, this is an interesting discussion.
http://www.rcgroups.com/forums/showthread.php?t=1528685
OK, You made the wings. What about the rest of the parts?
Continuing with the glider designs above, you can make your own fuselage/pod or you can buy one These guys sell pods, booms and v mounts
http://www.clm-pro.com/pods
http://www.rcgroups.com/forums/showthread.php?t=1832907
Tail Booms
https://goodwinds.com/catalogsearch/result/?q=Tail+Boom
If you want to design and build your own – these are for the composite building junkie
DEPARTMENT OF DEFENSE HANDBOOK - COMPOSITE MATERIALS HANDBOOK
http://www.library.ucdavis.edu/dept/.../HDBK17-3F.pdf
Design Software
XFLR5 - Planform and airfoil integrated design
http://www.xflr5.com/xflr5.htm
Profili - Airfoil performance and plotting software
http://www.profili2.com/eng/default.htm
Plane Geometry - Design parameters in Excel spreadsheet. Plug in the measured parameters of your model and back out the performance properties, or vise-versa. Great for scaling up planes or making small changes in design but keeping the flight characteristics the same
http://www.envisiondesignusa.com/evd..._Overview.html
Linkage Design - calculate you linkage layouts, calculate torques and moment arms for your servos, etc
PLEASE POST YOUR QUESTONS OR INPUT. TELL US OF YOU EXPERINCE BUILDING BAGGED WING GLIDERS. SHARE YOUR TIPS AND TRICKS, PHOTOS AND VIDEOS.
www.lisf.org
Eastern Soaring League
www.flyesl.org
AEAJR is offline
Old 07-04-2014, 09:45 AM   #2
Larry3215
Look out for that tree!!!
Larry3215's Avatar
View Larry3215's Gallery63
Club: Kitsap ARCS & E-FLAPS
Good idea ED! WattFlyer could use more tech info on this subject. It goes beyond just building super hi-tech wings for uber gliders too. These techniques can come in handy in building almost any model.
Im currently working on an e-Supra.
I made my own pod using the lost foam technique then attached it to a pre-made boom. It came in pretty light too about 105 gms. It still needs the pylon made and mounted so will likely end up closer to 150 gms when complete.
I have completed the horizontal stab and the fin/rudder. They came in at 34 and 37 gms.
Both wing tip panels are out of the bags but still need some trimming and sanding. They should end up around 130 gms - 140 gms or so.
Im using a refrigerator compressor salvaged from a dead refer. Cost = zero and it pulls a good 25" of vac. I use cheap plastic drop cloths and cheap caulk for the bagging.
You can build vacuum bagged wings surprisingly inexpensively if your careful
Its certainly a daunting task if you've never tried it before, but Phills and Curtis' videos help it all makes sense.
Ive made about every mistake possible on this build and it's till turning out halfway decent, so if I can do it, anyone can
ID:	176377   Click image for larger version
ID:	176378   Click image for larger version
ID:	176379   Click image for larger version
ID:	176380   Click image for larger version
I think I need a signature.
Larry
Larry3215 is offline
Old 07-04-2014, 05:08 PM   #3
Friends: (9)
That is great Larry. Do you have a build thread going somewhere? Please post a link.
Yes, this can be for building any kind of aircraft, not just gliders.
Anyone else?
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 07-05-2014, 01:54 AM   #4
Larry3215
Larry3215's Avatar
Build log:
http://www.rcgroups.com/forums/showt...2072590&pp=100
Larry
Old 07-05-2014, 03:17 AM   #5
How well does that work for applying wood skin to a foam core?
I'm planning to mix up a few techniques in one build.
Old 07-05-2014, 04:51 AM   #6
Friends: (9)
Bagging wings with wood skins is a common method. For example, www.arthobby.com sells a full line of wood skinned bagged wing gliders.
www.lisf.org
www.flyesl.org
AEAJR is offline
Old 07-05-2014, 04:51 AM   #7
Larry3215
Larry3215's Avatar
It works much better than the alternatives I have tried - bags of lead shot or rice or hoping tape will make a good bond everywhere.
For bonding balsa to foam you probably dont need the full vacuum pressure Im using, but the more you have the better it will work.
You need the shucks the cores were cut from as a bed to hold the cores straight and maintain the proper washout, etc while the glue dries.
What I do is leave the shucks outside the vacuum bag. Put the first shuck down on the bench, then lay a piece of cheap plastic drop cloth over it thats large enough to fold over the core. Leave enough room around the edges to run a bead of caulk.
Next lay down some paper towels on top of the plastic drop cloth to act like a breather. Thats so the air can get evenly drawn down on all parts of the core.
You need a layer of breather the full length of the core on top and bottom. If you dont want your breather getting glued to the core when excess glue gets sucked out, you need to run a layer of wax paper or more dropcloth plastic between the breather and the core. Make the breather larger than the wax paper.
So you have this set up:
Bottom shuck
plastic drop cloth "bag"
breather
wax paper or more plastic
the core
wax paper/plastic
breather
drop cloth plastic "bag"
top shuck
Then I place bricks or some other weights all along the top shuck to weight everything down so it cant move when the vacuum starts to suck things down.
The above layers would be if you were using balsa and some wood glue to attach it to the foam.
In my case, where Im using epoxy resin and fiberglass/carbon fiber, I use plastic mylars .014" thick instead of the wax paper inside the bag.
The mylars are cut to the exact shape of the parts. You can pre-paint the mylars and that paint gets transferred to the parts when the epoxy cures - if you have prepped the mylars correctly!
I sometimes also use something called peel-ply between the mylar and breather. The peel-ply is just 100% polyster or nylon dress liner fabric. It helps 'peel' any excess epoxy from the outside of the mylars.
Once the core and bag is all set, I stick the vacuum hose in the bed of caulk so that it sticks into the bag far enough to lap onto the breather material. If you dont do that, the plastic drop cloth will just seal the end of the tube.
below are a couple of pics of some parts bagging.
In the fist one the vacuum hose is off to the left.
In this one you can see the vacuum hose. Notice lots of weights to keep things stable and flat.
You need lots of weight to keep things stable and flat when you pull the vacuum. 17 psi can add up to a huge amount of force trying to bend your parts where you dont want them to go
ID:	176392   Click image for larger version
Larry
Old 07-05-2014, 04:57 AM   #8
Larry3215
Larry3215's Avatar
By the way, its important to keep the plastic sheets, breather, wax paper, etc all nice and smooth and with a uniform thickness everywhere on the core. If you end up with folds or creases in the bag or breather or un-even layers, those creases can be imprinted into the final part.
I also only use Viva paper towels as they have no texture to them. At hi vacuum levels, some paper towels have enough texture to show up on the final part! Little impressions of flowers or butterflies dont go well with most glider wings
Larry
Old 07-05-2014, 07:03 AM   #9
My plan currently is to:
Cut retract wells, servo wire runs and servo bays
Inset the wood for the hinge lines, and sand to match the cores
Inset retract mounts and other "hard points" in the foam cores
Join the shucks for the wing and lay on bagging plastic set on a solid core door blank. (8 ft X 4 ft... its a big wing and will overhang a couple inches each end!)
Join the wing cores and affix CF TOW on high stress lines (I want continuous CF TOW from tip to tip)
Add the LE and TE wood stock, shaping the wood so the skins can overlap them
Join the wing skin panels ( this could be "fun" ) I plan to double-stick tape the skins to the shucks so they can't shift.
Packing tape applied to shucks where epoxy might try to glue the wing to the shucks.
Lay in the wing skin (1/64 ply upper, 1/32 ply lower) wing core and slow cure epoxy and lay the opposing shucks on top... cover with bagging plastic and weights... draw the vacuum.
I think I'll need to skin top then when that cures do the bottom.
I need some REALLY slow cure epoxy... Its a big wing and I want it to act as one piece.
Old 07-05-2014, 07:32 AM   #10
Larry3215
Larry3215's Avatar
Is this a giant flying wing? Cool project!
I think you will find you get better - more uniform - compression on the cores if you leave the shucks outside the bag.
If you try to rely on the shucks putting pressure evenly on the core, it doesnt work so well. Where ever you have a difference in thickness on the shuck or at corners edges, etc, the pressure varies as the foam compresses unevenly. This is mostly a problem around the leading edge where you have more curvature.
If the vacuum bag is directly against the core, you get the full vacuum pressure on every sq inch. Leave the shucks on the outside and use them to hold things straight and weigh them down a bunch while its setting up.
My favorite epoxy is MGS. Using the slow hardener you will have maybe 5-6 hours of pot life for a 1mm thickness of epoxy. Mix up smaller batches at a time and you should be fine. You're still going to have to work fast though!
The down side to MGS is its cost.
One question - why the thicker skin layer on the bottom? I would have thought you would treat the skins like a spar cap and want the thicker section on the top?
Larry
Old 07-05-2014, 07:35 AM   #11
Larry3215
Larry3215's Avatar
One other thing I forgot to mention. I both of those pics above, I used .7mm drop cloth plastic. Thats too thin and it tears too easily. You may be able to see that I used multiple layers of the plastic to form the "bag". I much prefer to use heavier gauge plastic around 1.5mm -2.0 mm.
On the other hand, if you're careful, the .7mm is good if you have some part with large compound curves. It will stretch and form better to the core shape without wrinkles.
Larry
Old 07-05-2014, 07:40 AM   #12
Larry3215
Larry3215's Avatar
One more thought I had. For a project your size, paper towels wont work very well for a breather. Id try using some of that dress liner fabric or something similar as long as you canget it in a roll wide enough for your cord distance.
The 100% polyester will act as a breather and peel-ply in one go.
Larry
Old 07-05-2014, 08:30 AM   #13
Wing is for a 107 in span Me-262. Kit specified built-up structure and a pair of .91 glow ducted fans. I'm sticking in a pair of 5000 watt EDFs and didn't trust the wing structure so I had cores cut.
Upper surface is thinner for the curvature of the top surface, lower is thicker for more strength. The more curved upper surface will gain some stiffness by the "coke can effect" but I'll have the CF TOW backing up the wing skins for the loads expected.
CF TOW strips and light fiberglass will be on the inside (foam side) of the skins at all skin joints. Trying for minimal work to get a smooth finish.
Final expected RTF weight between 30 and 35 lbs. (kit specifies 30 to 32 lbs RTF with glow fans)
Been delaying the project because I needed to learn to handle something as fast as I expect this to go...
EDF model in the avatar has one of the fans that will go in the Me-262. Its overweight and overpowered on purpose.
Might call it an "Extreme" E-pylon racer... expecting 200+ mph.
Old 07-05-2014, 08:56 PM   #14
Larry3215
Larry3215's Avatar
Awesome project!
Larry
Old 07-06-2014, 07:36 PM   #15
Larry3215
Larry3215's Avatar
Build thread?
Larry
slow stick build thread and mods hayofstacks ParkFlyers 24 01-27-2014 08:10 AM
another newbie question on wings hangingon General Electric Discussions 12 01-18-2012 07:24 PM
Replacing Damaged wings. PGernix Foamies 1 01-02-2012 09:00 PM
Stabilize wings when building with EDF? sporren Electric Ducted Fan Jets 2 12-16-2011 06:02 PM
"Full Flying" wings - surely it's been done? mclarkson Aerodynamics 8 08-20-2011 07:26 AM
Page generated in 0.87268 seconds with 56 queries
