Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Indoor & Micro Electric Planes
Old 07-22-2014, 10:02 PM   #1
smallflyer
Default flyzone p51 mustang esc problem?
Yesterday I brought out my flyzone micro p51 mustang for the first time this year but wasn't able to get it in the air. I fully charged my 2 li-po batteries, and put fresh batteries in the TX. When plugging in the battery everything looked good, tested the control surfaces, when I hit the throttle, it started up, but by midway it was pulsing on/off, then would cutoff after a couple second or 2. Repeated several times did the same thing, tried the other battery, same thing. Thinking both batteries might be bad I put them on a volt meter and the were both reading about 3.9/4.0 which looked like a full charge to me. Connected 1 of the batteries to another motor, and it seemed to have good power. So now I'm assuming something wrong with the esc? Anyone have any ideas on how to get it going again?
Thanks Tom
smallflyer is offline
Old 07-23-2014, 01:00 AM   #2
View xmech2k's Gallery21
Club: CVMRCC, SEFSD
Not being familiar with that plane, I assume from your voltage statement it's a 1 cell battery? Seeing as you havent used it in a while, did you store the batteries fully charged or discharged? Lipos need to be stored at 50% capacity. If not the internal resistance increases, then what you just described happens. You charge them up, without a load the voltage is fine, but when you start flying they suffer from voltage sag and your esc goes into lvc. Get it on the ground and check and voltage is fine. Those tiny single cell batteries are notorious for not lasting long. This is what I suspect is happening, nothing wrong with the esc. As far as working ok in the other plane, is there a lower power demand in that one? This would be easy to verify with a bigger battery where you could plug a volt meter into the balance lead while doing a run up. Not an easy option with a single cell.
Old 12-27-2015, 05:48 AM   #3
FoxProGT
Im having this problem with my micro corsair. I hope a new battery will fix the problem. Thanks for the input.
FoxProGT is offline
Old 12-27-2015, 08:00 AM   #4
LiPo improperly stored can go bad in just a few months. They can seem fine but be unable to deliver a useful amount of current for anywhere near as long as when the pack was new.
Also the useful capacity goes down with age. it will go down fast if improperly stored.
Your result is typical of a LiPo that won't deliver current and/or has significantly reduced capacity.
In the future: Store the batteries at 3.7 to 3.8 volts per cell in a cool location. Do not let them "freeze". (below 32F or 0 C is bad for LiPo )
Most modern multi-chemistry capable chargers have a LiPo storage mode That will charge or discharge (some won't discharge to storage level) the pack to the appropriate voltage. The discharge is usually so slow as to be useless (if offered)...so its usually best to discharge in the model to LVC then charge using the storage mode.
Old 12-27-2015, 03:15 PM   #5
FoxProGT
Right on... Thanks
FoxProGT is offline
Old 12-27-2015, 04:11 PM   #6
With proper care, a LiPo is good for 3 years high demand (average of 75% rated max current each cycle, 80% labeled capacity) plus another 1 to 2 years moderate demand (average of 20% to 30% rated max current 70% capacity) followed by another year of appx 1C 50% capacity demand.
Using full labeled capacity at full rated max current is a good way to destroy a LiPo in 5 cycles.
Old 12-27-2015, 11:13 PM   #7
park
Clear !
park's Avatar
Friends: (4)
Thanks Tom
What electronics do you have?
AMA 1124147
park is offline
Old 12-27-2015, 11:23 PM   #8
FoxProGT
Ok so the battery was the problem. Bought a new battery and no longer have the issue.
FoxProGT is offline
Old 12-28-2015, 08:43 AM   #9
You will get a lot more cycles out of your battery if you minimise the time they spend fully charged, so charge up just before flying rather than after flying then leaving the battery charged.
Also use a timer and dont fly all the way until the power cuts.
Old 12-28-2015, 07:34 PM   #10
FoxProGT
ok good notes...Thanks
FoxProGT is offline
Old 12-28-2015, 08:21 PM   #11
1kW
Friends: (7)
These are very nice for monitoring the single cell batteries.
There are better models but some can certainly be had for cheap.
http://www.harborfreight.com/7-funct...ter-90899.html
I don't have a short temper. I just have a quick reaction to B.S.
Rob
Old 11-29-2016, 10:37 AM   #12
Virgil Kee
Default Motor "pulsing" in UM P-51
I'm one of those who keep the lipo's fully charged in order to fly outdoors right away when the wind is down (usually the last daylight hour). With these batteries, I find that if I only tax them at about 3/4 max draw, there is no further loping.
Try it on a "bench test" and you'll see what I mean.
This is still enough batt. usage to fly at a good speed. I only "cruise"; no acrobatics. I enjoy having these micros VISIBLE, LOOKING LIKE AN AIRPLANE!
Low passes give me the best chance to SEE a real-looking plane.
Virg.
Virgil Kee is offline
Old 11-29-2016, 03:04 PM   #13
raming
Ramin G
Club: HCAM Austin
Default 150mAHr 1 Cell Micro Batteries
Virg.
I use these 1Cell 'Micro' Batteries for indoor helicopters and UltraMicro planes and have had several that died. The main reason for the LiPO failures, in my experience, is deep-discharging the batteries. Therefore, when flying a UltraMicro, I always set the Transmitter Timer for no more than 70% of the battery capacity (i.e. 4 minutes if battery can support a 6 minute flight). If you fly regularly into the 'pulsing motor' mode, the batteries will quickly wear out.
I too like to charge my batteries to full capacity between flights. This does not seem to affect the life (after hundreds of flights). These are my routines:
1. Charge to full capacity after flying
2. Store batteries in a cooler chest with an icepack (particularly in hot weather)
3. Store batteries in the refrigerator when not used for more than a day or so
4. 'top off' the charge just before use
Trust, but Verify!
raming is offline
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 162 06-12-2017 07:00 PM
Flyzone Calypso ESC wiring issue ewilliam Power Systems 6 01-24-2014 02:32 AM
ESC from Flyzone Cessna vs Flyzone Super Cub gene375 Power Systems 3 10-03-2012 12:58 AM
Page generated in 0.12857 seconds with 43 queries
