Old 07-11-2006, 03:06 AM   #1
dmmalish
r/c crash test "DUMMY"
View dmmalish's Gallery14
Club: http://www.facebook.com/home.php?#/group.php?gid=221090112030
Send a message via AIM to dmmalish
Default harbor freight cub
has anyone purchased one of these harbor freight cubs and what was your experience i bought one and want to know what i should do before i fly it
dmmalish is offline
Old 09-03-2006, 10:35 AM   #2
mcalternative
Crazy about flying!
I ownone of these Cubs http://jeepgraveyard.com/Planes/J-3.htm I love it! I've dumped it a few times, once so bad that I thought the FAA was going to need to out and search for the black box! Overall it's a great flyer. Not easy to take off from the ground, but it flies well and cann be landed with out a lot of work. I just bought a 400 motor with a gearbox and a larger prop for it with the help of my local Hobby Store expert. He said that I he has done this on the same plane and the performance is incredible! I haven't tried this combo yet - I'm anxious, but too much wind lately. Which reminds, this plane is not great in breezy weather. Good Luck.
Keep it Level
mcalternative is offline
Old 09-13-2006, 11:04 PM   #3
swapdaddyxx1
Default Harbor freight cub
I just received a new catalog from HC today. The cub is marked down from $199.99 to $99.99. No discount on back of catalog tho.
swapdaddyxx1 is offline
Old 09-13-2006, 11:06 PM   #4
swapdaddyxx1
Default HC cub
Uh oh. just looked at my posting,should be $119.99 to $99.99. Damn, old age is fun!
Old 09-13-2006, 11:07 PM   #5
dmmalish
Unhappy don't waste your money
you can buy a pretty nice combo package at towerhobbies.com for around 150.00 bucks you will not be happy with the cub no matter what you read on here
dmmalish is offline
Old 09-13-2006, 11:59 PM   #6
Twmaster
Registered User
Twmaster's Avatar
View Twmaster's Gallery17
Friends: (13)
That Cub from Harbor Frieght is the same SDM Cub (Shun-Da I think) as is sold on Feebay for lots less. The one I saw in person was junk.
Mike N
Support the entire Constitution.
Not just the parts you like.
Twmaster is offline
Old 09-14-2006, 12:18 AM   #7
dmmalish
Default i agree
towerhobbies has some good combos the hobbico super star ep is a great trainer very very forgiving for 140.00bucks Hobbico SuperStar EP Select 3-Channel RTF 48.75"
dmmalish is offline
Old 09-14-2006, 01:33 PM   #8
mcalternative
Crazy about flying!
Wow! Pretty harsh. I haven't had too many problems with mine. Your, right, It is a Shun Da Cub. Not top of the line, but not quite as bad (in my opinion) as has been stated here. Balancing the plane is imperitive. On a day with 5 mph winds or less, I'll get about 20 minutes flight time if I'm mindful of the throttle. I seldom fly anything at WOT, seems a waste. These are not aeobatic birds, but I've managed somethings. I upgraded the motor on one of them to a 400 with a gearbox and 10x6 prop that's sturdier. Great success! It takes off like a mad bird on steroids! If you like to fly out of the box, there are alot of good electric trainers available. I bought my cubs because I was able to get them for $79.00 on sale at Harber Freight.
So if you don't mind swapping the engine and rebalancing, you'll have another fun flyer to add to your collection. This plane takes a little skill, so I don't neccesarily think that it is a good trainer.
Keep it level!
Old 09-19-2006, 08:12 PM   #9
jaywalker
Sarge
View jaywalker's Gallery8
Default Harbor Cub
I bought one from Harbor freight under $100.00 Charged the battery took it out and fly it about for 12 minutes. Got up to 300 ft and it handled very nice. Gentle feather landing. The skin seems very delicate but can be easily repaired if it scapes pavement etc. I have flown many different models but this one flys right out of the box . I haven't thought of beefing up the motor , it seems to fly fine just like it is.
Lee
jaywalker is offline
Old 09-19-2006, 09:03 PM   #10
jaywalker
Sarge
Does anyone know what size props these use or where to get them. The cub uses a 7" X 2 ? 3 ? I can't find anything close.
Thanks for the help.
Lee
Old 09-22-2006, 04:45 AM   #11
lostagain
i just got the same cub today went out to fly,but was not able to get in the air planewould dive to the ground and at the last minute would try to pull up but it seems to be under powered or out of balance. fuse cracked 2/3 through .ca put it back . will try again tommorow.
lostagain is offline
Old 09-22-2006, 11:45 AM   #12
jaywalker
Sarge
Cool Cub Crashes
I have never had trouble with my Cub. COG is critical and the ESC is left floating around inside the fuselage to some degree. Throw the plane out level don't aim it up. The battery will only go in one way so I can't see a problem there. It's very seldom a plane flys that well right out the box at the altitude in the summer that we have here. I usually climb up a 3 foot dirt bank to launch my planes in the country . I have to do that with several planes but not the Cub. Your plane must be out of balance or your motor isn't running full speed for some reason. I can check my RPM if you need a comparison.
Happy flying.
Lee
Old 09-24-2006, 11:28 PM   #13
jaywalker
Sarge
I have had one of these for a couple years and flown it with no problems. Yesterday on take off a gust of wind slammed it into the ground not real hard but it snapped in two pieces. It is very brittle and easy to break. I glued it together and it's no longer a flying model, I took the servo's and other parts out to reuse.
Lee
Old 07-28-2007, 02:53 PM   #14
WD2O
WD2O's Avatar
View WD2O's Gallery39
Default Trouble Finding Fh Cub Props
I am having trouble locating 7x2 props used on the Freight Harbor Cub. Don't want to bother sending back to FH just for props and would rather find them locally or on line but it seems no one makes them. Does anyone know where I can purchase them? Substituted a 7x3 and a 7x4 prop but neither has the same thrust.
WD2O is offline
Old 08-29-2007, 06:34 AM   #15
vega2614
I recommend getting an APC 8x4 prop. It definitely improves the performance of the cub. However, in the long run, it will wear the engine out faster. I've since upgraded my cub with a brushless motor and lipo. I can't stress how much better it makes flying the cub. You can get a brushless/ESC combo for $15 and a quality lipo for $25 at UnitedHobbies.com. Check out the motor/ESC combos.
Here's a vid of my upgraded cub in action: http://youtube.com/watch?v=9yptgKwf-TI .
I'm surprised a 7x4 isn't working for you. I know a lot of people use that with their SDM cub. My cub always flew acceptably, although it was very underpowered (I had to fly almost at full throttle the entire time). Also, it was tail heavy, but even before modifying the battery bay to move the battery forward, I could still fly with minimal difficulty.
vega2614 is offline
Old 12-14-2007, 03:40 AM   #16
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
View GreenAce92's Gallery36
Heres a vid of me flying my SDM Piper CUb and me climbing a tree to get it out just thought i would post it here since its showing flight capabilities of the SDM Piper Cub oh and it landed in the tree because my battery was dead.
SDM FLight:
Rescuing Cub.
Do life with optimism
GreenAce92 is offline
Old 12-14-2007, 04:57 AM   #17
Airhead
Redneck Member
Airhead's Avatar
View Airhead's Gallery23
Globetrotter Pilot  Ambassador Award
Friends: (29)
When you got it back. was it undamaged... other than tree burn I mean..
Bruce
AMA 873912
Project Globetrotter participant
If it ain't broke, I'll fix it till it is.
Airhead is offline
Old 12-14-2007, 11:10 AM   #18
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
Yeah it was fine but the next day it acted up and it ended up going through many branches and snapping a wing off. It was odd it was struggling to climb and moving forward but at the same time it was at an odd angle so it was stalling too so yeah it was dead.
Old 12-15-2007, 02:06 AM   #19
Aircraftfreak15
hey did the CG get moved when it got stuck in the tree
Aircraftfreak15 is offline
Old 12-15-2007, 02:11 AM   #20
GreenAce92
RAWR!!! Lets fly...
GreenAce92's Avatar
no not really i think the battery just finally gave out but once i have a real radio system by this christmas the only error for my planes not flying well is me. I wont have problems with glitching or underpoweredness.
Old 12-15-2007, 02:14 AM   #21
Aircraftfreak15
hey have you flowen the yellowbee
Old 12-15-2007, 02:35 AM   #22
Aircraftfreak15
Are you going to get a new plane or Just the wing for it.
Mini-review: Harbor Freight/SDM Piper Cub J-3 gzsfrk Beginners 2 01-22-2008 05:32 PM
Harbor freight planes - yellow bee, cub trooper8 Indoor & Micro Electric Planes 10 12-17-2007 12:29 AM
HZ Super Cub or Harbor Freight Wild Hawk? JARowe Beginners 12 03-31-2007 02:41 PM
harbor freight cub on steroids dmmalish ParkFlyers 9 02-10-2007 10:06 PM
harbor freight cub changing crystal mbilar1 General Electric Discussions 3 12-02-2006 08:34 PM
Page generated in 0.52275 seconds with 61 queries
