Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > UAV / FPV
UAV / FPV Forum to talk about UAV / FPV electric R/C flight.
Old 07-22-2006, 05:00 AM   #1
rcguyme
Guest
Posts: n/a
Exclamation 4-Channel UAV Predator
I orderd a 4-Channel UAV Predator and seam to have a small motor never seen a 290ED was looking for a brushless setup for the plane not much room motor is in the back do want to use the space the motor fits in not chop has anyone seen a 290 ED maybe someone can give me a idea about its size so i can order a brushless motor to fit it.thanks
Wingspan: 1350mm------ 53.1496 inches
Fuselage overall length: 760mm----- 29.9213 inches
Flying weight: 550g 1940OZ
Wing load: 3503 sq dm
Wing area: 157 sq dm
Motor/propeller: 290 ED
Battery: 9.6v-108V 600-1000mAh NIMH
Old 07-22-2006, 01:57 PM   #2
darkside212
darkside212's Avatar
Send a message via MSN to darkside212
How about a pic of the plane, and of the motor mount area
I am an electronics distributor, and I can figure something out for ya'
darkside212 is offline
Old 07-22-2006, 02:48 PM   #3
Joe 1320
Joe 1320's Avatar
View Joe 1320's Gallery47
Best thing is to wait and measure the motor and it's mount, find something from there. It probably takes longer but it's better than buying twice.
I've wondered about those, curious how big of a battery you can get in there for really long flights, maybe carry a wireless camera too.
Owner of the Atomic RC Workshop.
The Flying part is easy.... it's the landings that will do you in. :p
Joe 1320 is online now
Old 07-23-2006, 05:13 AM   #4
rcguyme
Guest
Posts: n/a
Default 4-Channel UAV Predator
Joe the stock battery is a 9.6v-108V 600-1000mAh NIMH not knowing its size from a view point but i have a couple 9.6v 600's and a 1000 it has some weight i am hopeing to go 3c 1100 or larger will know monday for sure let you know then and darkside will post a pic soon thanks for the reply
Old 07-24-2006, 11:51 PM   #5
rcguyme
Guest
Posts: n/a
OK here is what it came down to in the Box one Predator RQ-1L radio servos installed looks from my measurement motor is 1&1/4 long has a gear box and 1 inch round but you have room to use a motor into 2 inches long and 1 inch round all foam plane light for sure very small screws motor cover in a thin plastic it woint stay on long for sure lol now Brushless wil be the move up now oh and battery is a MIAH 2-8AA 600
Old 07-24-2006, 11:54 PM   #6
darkside212
got any pics?
Old 07-25-2006, 03:34 AM   #7
rcguyme
Guest
Posts: n/a
new to adding pics here.here is my gallery pic will take off the motor cover and take a new pic of the motor compartment for you to see
http://www.Wattflyer.com/photoplog/index.php?n=793
Old 07-25-2006, 04:00 AM   #8
darkside212
Does the gearbox mout onto a stick?
what size prop came with the kit?
Old 07-25-2006, 04:29 AM   #9
rcguyme
Guest
Posts: n/a
IT uses a 8x6 prop and no the gear box does not mount on a stick you can see from my gallery But i have seen this plane quote the same plane but has a different motor a 380 motor and different radio system
Old 07-25-2006, 02:53 PM   #10
darkside212
OIC
you could get a BP21 on there w/fw mount. It'll give you ~20 oz of thrust on a 8040 prop. If you need a brushless motor/esc combo pm me
Old 08-04-2006, 03:28 PM   #11
rcguyme
Guest
Posts: n/a
Well i found a brushless motor that will fit and work well the eflight 4200 KV but i decided to just sell the works and go with another plane yes i have the eflight park 4200 kv motor brushless and battery 3c 1320 and charger and thanks for the help
Old 05-03-2008, 01:48 AM   #12
1stdegree
i just ordered one with lipo and brushless 2850 havnt flown it yet but it sounds awesome, for a foamy, hopefully no wind 2maro and i can go dial it in. check out raidentech , assembly was a little sketchy (main wings) but i think it should fly
1stdegree is offline
UAV Jobs Mike Freas Off Topic Chit Chat 5 05-27-2008 09:26 PM
Problem With UAV Stags209 UAV / FPV 0 04-23-2007 09:58 PM
Beginner with a predator KE4ITN Beginners 20 04-05-2007 03:57 PM
Predator UAV tedworld UAV / FPV 12 12-05-2006 06:11 AM
Army Predator RSS Feed RCU RSS Feed 1 10-07-2006 02:39 PM
Page generated in 0.36747 seconds with 35 queries
