Old 07-31-2006, 04:33 PM   #1
Grasshopper
Some Assembly Required
Grasshopper's Avatar
View Grasshopper's Gallery48
AP Contest Winner  WAA-08 Pilot  100mph Speed Demon
Friends: (52)
Default Can you airbrush the Acrylic Craft Paints?
Has anyone used the acrylic craft paints in an airbrush. It seems like an inexpensive way to paint but I wasn't sure how well they would cover once thinned. If you have, what percentage did you thin it and did you just use water? Are the metallic paints any different to thin from the standard colors?
Thanks,
Tom
Tom
Grasshopper is offline
Old 07-31-2006, 04:58 PM   #2
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
1kW
Tom,
Depends on the paint. If you use something like Faskolor, you spray it straight, no thinning required. Other wise just play with the paint till you get a good spray pattern and coverage.
With metallics, you may run into a problem, depending on the flake size, if so just go to a bigger size tip on the air brush.
Glacier Girl is offline
Old 07-31-2006, 05:17 PM   #3
Grasshopper
Friends: (52)
Thanks Brad. I was talking about the craft paints like at Michaels or Hobby Lobby ($1.50 or less a bottle). The metallic is a very fine flake so it should be OK. I'll buy a couple of bottles and try it. Even if it doesn't work, I'm only out $3 and some time cleaning up the airbrush.
Tom
Old 07-31-2006, 06:22 PM   #4
ForestCam
Bad Influence
ForestCam's Avatar
View ForestCam's Gallery3
I've used them (Wal*Mart craft department) and they worked great. I didn't thin with water though I used about 50/50 rubbing alcohol.
Just make sure that if you want a gloss finish to get gloss paint and buy the bigger bottles, the little 77 ones don't go very far.
ForestCam is offline
Old 07-31-2006, 06:54 PM   #5
Grasshopper
Friends: (52)
Thanks for the tips Forrest. I do want a gloss finish. I was going to try putting a light coat of gloss WBPU on top to seal it and give it a gloss finish. I'll practice on some scrap foam first.
Tom
Old 08-01-2006, 12:30 AM   #6
Joe 1320
Joe 1320's Avatar
View Joe 1320's Gallery47
Thin the paints with windex when airbrushing. It's a old nail salon trick and it works, faster evaporating and the color sticks better.
As far as clear, remember it adds weight. Go easy on it!
Owner of the Atomic RC Workshop.
The Flying part is easy.... it's the landings that will do you in. :p
Joe 1320 is offline
Old 08-02-2006, 02:41 AM   #7
Grasshopper
Friends: (52)
Will the blue Windex discolor white paint?
Tom
Old 08-02-2006, 03:59 AM   #8
darkside212
darkside212's Avatar
Send a message via MSN to darkside212
just use water to thin it...thats what I've been doing works good....currently refurbing a GWS CH47
ONE thing I had to do was use a really fine sand paper to remove the old paint
darkside212 is offline
Old 08-02-2006, 04:39 AM   #9
ForestCam
Bad Influence
ForestCam's Avatar
They do make clear class cleaner, it's usiually found in the automotive department of your local megalo mart.
Old 08-05-2006, 03:16 PM   #10
darkside212
Hey Guys, I want to get a clear coat...the stuff in the craft section (spray can) says its good for "bisque" clay...etc
what can I use on top of the acrylic with out eating away the foam?
Old 08-05-2006, 03:26 PM   #11
View firemanbill's Gallery67
Club: Smoky Mountain Aero Club
Friends: (64)
that's good question Paul, I am not really sure. What I would try to do is paint a piece of scrap foam, If your'e anything like me you have lots of it, and then put your clear on it. Give it few days to cure and then cut it in half and have a look.
President - Smoky Mountain Aero Club, Sevierville Tennessee
Old 08-05-2006, 03:31 PM   #12
darkside212
scrap foam?.....do you consider 5 8'4' 3" sheets, 2 8'4' 2 ", 3 8*4 8", and a brick of blucore enough
I wanted to try the spray can stuff from the craft section, but I did find some H2O based acrylic clear coat...I was just being lazy and didn't want to mix it:p
Old 08-05-2006, 03:36 PM   #13
Friends: (64)
ummm yeah... lol
See I knew you'd have some! Come to think of it I don't think I've ever seen any water based clear either.
Old 08-05-2006, 03:58 PM   #14
Grasshopper
Friends: (52)
Mornin Guys,
I was going to try the clear gloss water based polyurethane over mine. I'll go throw a coat over some acrylic paint test patches I've got on foam right now. I'm hoping to get my Magpie painted this weekend and I had the same question.
I got some acrylic metallic paints at Michaels last night and put them over my polycrylic to see how they dried. They dried overnight and are very shiney so I wasn't going to top coat them. I'll go try the polycrylic and let you know.
I would think any water based clear coat would be fine over acrylics but you always want to try a test piece first.
Tom
Tom
Old 08-05-2006, 04:05 PM   #15
Joe 1320
Joe 1320's Avatar
Testor's clear is foam safe and won't react with the acrylic. It's heavy, so go lightly and the results are great!
Joe 1320 is offline
Old 08-05-2006, 04:11 PM   #16
Grasshopper
Friends: (52)
That's good to know Joe. I had read that Testors enamels will eat foam but I tried them on some scraps and they worked fine. I haven't painted a whole plane yet but I would think they would be lighter than acrylics once dried.
Tom
Old 08-05-2006, 04:28 PM   #17
Grasshopper
Friends: (52)
I put a coat of Olympic water based polyurethane over a test patch of Folk Art and Deco Art acrylic metallic craft paints and it's dry to the touch. It looks really good. Nice smooth gloss finish.
Tom
Old 08-05-2006, 04:34 PM   #18
darkside212
sweet
Old 08-27-2006, 10:00 PM   #19
EZ1
EZ1's Avatar
Send a message via Yahoo to EZ1
acrylic paint can set up quick if you're used to using other water based paints in your airbrush. Remember to flush it out well in between sprays to avoid clogging.
EZ1 is offline
Old 08-27-2006, 10:10 PM   #20
pezzer2003
pezzer2003's Avatar
View pezzer2003's Gallery8
Question i have not airbrushed before i was wondering what model of air brush you are all using?
PEZ
pezzer2003 is offline
Old 08-27-2006, 10:32 PM   #21
Friends: (64)
I have a cheap Badger, basic model, I picked up at the LHS. It is a really nice inexpensive gun. I got the whole deal for aroun 40 bucks if I remember right. It works really well for spraying the acrylics.
Old 08-27-2006, 10:52 PM   #22
EZ1
EZ1's Avatar
Have a couple of fancy airbrushes like Paasche and Thayer & Chandler but all I need to paint models is my ole basic Badger...that's what it was made for
EZ1 is offline
Old 08-27-2006, 11:04 PM   #23
darkside212
I got the "el cheapo" testors from walmart for $20 works good...you can hook it up to an aircompressor to.
Old 08-27-2006, 11:44 PM   #24
ForestCam
Bad Influence
ForestCam's Avatar
Got you beat, I got the "el EL cheapo" from Harbor Freight, $9 and it works great too.
Old 09-01-2006, 10:48 AM   #25
rahtware
No more oily right shoes!
rahtware's Avatar
I made the mistake of thinking if the cheap AB will do the job, then an expensive one should do it better... WRONG! An expensive airbrush will do very fine lines better, but for covering large areas the cheap ones are best.
Of course I still haven't learned, I just picked up a gravity feed touch-up gun knowing that... hey, it costs more than my Testors external-feed hobby brush, so it must be better...
Larry Costa
Illigitimi non Carborundum
rahtware is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
glues and paints for foam john339 Foamies 1 04-02-2008 07:40 PM
Elapor safe paints FlyWheel Foamies 2 10-02-2007 06:55 AM
Firbeglass paints? drzoidberg General RC E-Heli Talk 0 05-15-2007 12:51 AM
FOR SALE: Complete Pro Airbrush Kit (compressor and Brush, etc) DIALED/CHUCK General RC items For Sale and WTB 2 05-03-2007 02:52 AM
Airbrush booth help needed rahtware Foamies 20 02-03-2007 02:19 AM
Page generated in 0.51396 seconds with 69 queries
