Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > R/C Electric Topics - General > Flight Simulators
Flight Simulators Discuss computer flight simulators here
Old 08-06-2006, 07:43 PM   #1
Frodo
Frodo's Avatar
Default How to edit FMS PAR file?
Hello,
I downloaded a Slow Stick so I can practice flying on FMS however the SS PAR file is aileron controlled and not rudder controlled like my real Slow Stick. Is there any way to change this uisng the PAR editor? I tried to change it but have not been successful.
Thanx!
Frodo is offline
Old 08-07-2006, 06:53 PM   #2
ggunners
Send a message via AIM to ggunners
If you downloaded the FKstick8.zip model, it is rudder controlled but the rudder is on the aileron channel. Just change the .par file so that references to channel 3 are changed to channel 1. Many modellers put the rudder on the primary turning channel (ailerons) for 3 channel airplanes that are R/E/T. If you prefer to always have rudder on the rudder stick, make the change, otherwise, keep your primary turning control on the same stick.
//Wing4 <FIN>
-0.4 0 -0.06 //—ƒˆÊ’uX,Y,Z [m]
1 0 0 //Ex X,Y,Z
0 0 -1 //Ey X,Y,Z
2 //polar number
0.18 //span [m]
4 //number of elements
AUTOELEMENT
0 //AttackAngle [deg]
0.26 //chord length at the first end [m]
0.26 //chord length at the second end [m]
0.16 //chord length of the flap [m]
0 //start position of the flap [m]
0.18 //end position of the flap [m]
-44 //Maximum Angle [deg]
3 //channel (change this to channel 1)
You can edit the file with Windows Notepad, the .par editor that comes with FMS, the Plane Field .par editor on my website or Mr. Masuoka's ParEdit.exe editor which I prefer.
-- ggunners
ggunners is offline
Old 08-08-2006, 12:41 AM   #3
Frodo
Frodo's Avatar
Thank you gguners! That is exactly what I need! I'm trying to mimmic my Slow Stick. I practice every day.
Frodo is offline
Old 08-16-2006, 06:08 PM   #4
pjprofili
If you're interested in something that looks more like a Slow Stick - try this: http://h1.ripway.com/pjprofili/SlowStick.zip
Modified from an original work by Shinichiro Nishiya.
pjprofili is offline
Old 09-12-2006, 10:16 PM   #5
trewheeler
Wind Barrier Breaker
trewheeler's Avatar
View trewheeler's Gallery2
Default Some Planes Won't Fly
Has anyone encountered some of the free download airplanes for FMS not responding to controls i.e. they appear and they make a noise but they just don't register/move?
I downloaded a bunch today and most of them just sit there. I have tried recalibrating but as yet no luck.
Thanks,
Tim
trewheeler is offline
Old 09-13-2006, 12:15 AM   #6
ggunners
That happens when you're running airplane models with FMS 2 version 8 .par files with FMS 2 version 7 code. Uninstall the old version and then install the latest FMS 2 version 8.5 and those models should work fine.
-- ggunners
ggunners is offline
Old 10-01-2006, 09:28 PM   #7
ShokWaveRider
ShokWaveRider's Avatar
How do you make a plne larger with the editors. I want to make the slow stick 2 or 3 times the size?
swr
ShokWaveRider is offline
Old 10-06-2006, 04:50 PM   #8
ggunners
You use Metasequoia LE a free 3D graphics package to scale the model larger and then use the .par editor to adjust the flight physics to reflect the correct model behaviour in FMS.
-- ggunners
ggunners is offline
Old 10-06-2006, 05:25 PM   #9
ForestCam
Bad Influence
ForestCam's Avatar
View ForestCam's Gallery3
I've found that with most models it really helps if you can read German or have access to a good language translator.
ForestCam is offline
Old 10-31-2006, 08:36 PM   #10
NightlyNinja2006
BTW, if you haven't already checked out the PAR editor:
http://rcp.web.infoseek.co.jp/fms_e....itor_Converter
Very nice!
// Regards,
// Nate
// NightlyNinja2006@wikichat.com
NightlyNinja2006 is offline
How to make .par files KBLE Flight Simulators 4 09-09-2008 02:03 AM
FMS model file compilations? Winston Flight Simulators 4 03-25-2008 07:19 AM
Modify FMS par files. paco Flight Simulators 0 07-23-2007 06:44 PM
file size loker Aerial Photography 7 07-22-2006 05:35 AM
Page generated in 0.09839 seconds with 37 queries
